數(shù)字溫度計(jì)
2016-6-22 22:24 上傳
 #include "reg51.h" #include "intrins.h" //_nop_();延時(shí)函數(shù)用 #define dm P0 //段碼輸出口 #define uchar unsigned char #define uint unsigned int sbit DQ=P3^7; //溫度輸入口 sbit w0=P2^3; //數(shù)碼管4 sbit w1=P2^2; //數(shù)碼管3 sbit w2=P2^1; //數(shù)碼管2 sbit w3=P2^0; //數(shù)碼管1 sbit beep=P1^2; //蜂鳴器 sbit set=P2^7; //溫度設(shè)置切換鍵 sbit add=P2^6; //溫度加 sbit dec=P2^5; //溫度減 int temp1=0; //顯示當(dāng)前溫度和設(shè)置溫度的標(biāo)志位為0時(shí)顯示當(dāng)前溫度 uint h; uint temp; uchar r; uchar high=30,low=15; //溫度范圍設(shè)置為15-30度 uchar sign; uchar q=0; uchar tt=0; uchar scale; //**************溫度小數(shù)部分用查表法***********// uchar code ditab[16]={0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09}; //小數(shù)斷碼表 uchar code table_dm[12]={~0x3f,~0x06,~0x5b,~0x4f,~0x66,~0x6d,~0x7d,~0x07,~0x7f,~0x6f,~0x00,~0x40}; //共陽(yáng)極數(shù)碼管LED段碼表 "0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "不亮" "-" uchar table_dm1[]={~0xbf,~0x86,~0xdb,~0xcf,~0xe6,~0xed,~0xfd,~0x87,~0xff,~0xef}; //個(gè)位帶小數(shù)點(diǎn)的斷碼表 uchar data temp_data[2]={0x00,0x00}; //讀出溫度暫放 uchar data display[5]={0x00,0x00,0x00,0x00,0x00}; //顯示單元數(shù)據(jù),共4個(gè)數(shù)據(jù)和一個(gè)運(yùn)算暫用 /*****************11us延時(shí)函數(shù)*************************/ void delay(uint t) { for (;t>0;t--); } void scan() { int j; for(j=0;j<4;j++) { switch (j) { case 0: dm=table_dm[display[0]];w0=0;delay(50);w0=1;//xiaoshu case 1: dm=table_dm1[display[1]];w1=0;delay(50);w1=1;//gewei case 2: dm=table_dm[display[2]];w2=0;delay(50);w2=1;//shiwei case 3: dm=table_dm[display[3]];w3=0;delay(50);w3=1;//baiwei // else{dm=table_dm[b3];w3=0;delay(50);w3=1;} } } } //***************DS18B20復(fù)位函數(shù)************************/ ow_reset(void) { char presence=1; while(presence) { while(presence) { DQ=1;_nop_();_nop_();//從高拉倒低 DQ=0; delay(50); //550 us DQ=1; delay(6); //66 us presence=DQ; //presence=0 復(fù)位成功,繼續(xù)下一步 } delay(45); //延時(shí)500 us presence=~DQ; } DQ=1; //拉高電平 } /****************DS18B20寫命令函數(shù)************************/ //向1-WIRE 總線上寫1個(gè)字節(jié) void write_byte(uchar val) { uchar i; for(i=8;i>0;i--) { DQ=1;_nop_();_nop_(); //從高拉倒低 DQ=0;_nop_();_nop_();_nop_();_nop_(); //5 us DQ=val&0x01; //最低位移出 delay(6); //66 us val=val/2; //右移1位 } DQ=1; delay(1); } /****************DS18B20讀1字節(jié)函數(shù)************************/ //從總線上取1個(gè)字節(jié) uchar read_byte(void) { uchar i; uchar value=0; for(i=8;i>0;i--) { DQ=1;_nop_();_nop_(); value>>=1; DQ=0;_nop_();_nop_();_nop_();_nop_(); //4 us DQ=1;_nop_();_nop_();_nop_();_nop_(); //4 us if(DQ)value|=0x80; delay(6); //66 us } DQ=1; return(value); } /*****************讀出溫度函數(shù)************************/ read_temp() { ow_reset(); //總線復(fù)位 delay(200); write_byte(0xcc); //發(fā)命令 write_byte(0x44); //發(fā)轉(zhuǎn)換命令 ow_reset(); delay(1); write_byte(0xcc); //發(fā)命令 write_byte(0xbe); temp_data[0]=read_byte(); //讀溫度值的第字節(jié) temp_data[1]=read_byte(); //讀溫度值的高字節(jié) temp=temp_data[1]; temp<<=8; temp=temp|temp_data[0]; // 兩字節(jié)合成一個(gè)整型變量。 return temp; //返回溫度值 } /****************溫度數(shù)據(jù)處理函數(shù)************************/ //二進(jìn)制高字節(jié)的低半字節(jié)和低字節(jié)的高半字節(jié)組成一字節(jié),這個(gè) //字節(jié)的二進(jìn)制轉(zhuǎn)換為十進(jìn)制后,就是溫度值的百、十、個(gè)位值,而剩 //下的低字節(jié)的低半字節(jié)轉(zhuǎn)化成十進(jìn)制后,就是溫度值的小數(shù)部分 /********************************************************/ work_temp(uint tem) { uchar n=0; if(tem>6348) // 溫度值正負(fù)判斷 {tem=65536-tem;n=1;} // 負(fù)溫度求補(bǔ)碼,標(biāo)志位置1 display[4]=tem&0x0f; // 取小數(shù)部分的值 display[0]=ditab[display[4]]; // 存入小數(shù)部分顯示值 display[4]=tem>>4; // 取中間八位,即整數(shù)部分的值 display[3]=display[4]/100; // 取百位數(shù)據(jù)暫存 display[1]=display[4]%100; // 取后兩位數(shù)據(jù)暫存 display[2]=display[1]/10; // 取十位數(shù)據(jù)暫存 display[1]=display[1]%10; //個(gè)位數(shù)據(jù) r=display[1]+display[2]*10+display[3]*100; /////符號(hào)位顯示判斷///// if(!display[3]) { display[3]=0x0a; //最高位為0時(shí)不顯示 if(!display[2]) { display[2]=0x0a; //次高位為0時(shí)不顯示 } } if(n){display[3]=0x0b;} //負(fù)溫度時(shí)最高位顯示"-" } void BEEP() { if((r>=high&&r<129)||r<low) { beep=!beep; beep=0; } else { beep=1; } } //*********設(shè)置溫度顯示轉(zhuǎn)換************// void xianshi(int horl) { int n=0; if(horl>128) { horl=256-horl;n=1; } display[3]=horl/100; display[3]=display[3]&0x0f; display[2]=horl%100/10; display[1]=horl%10; display[0]=0; if(!display[3]) { display[3]=0x0a; //最高位為0時(shí)不顯示 if(!display[2]) { display[2]=0x0a; //次高位為0時(shí)不顯示 } } if(n) { display[3]=0x0b; //負(fù)溫度時(shí)最高位顯示"-" } } //*********按鍵查詢程序**************// void keyscan() { int temp1; //最高溫度和最低溫度標(biāo)志位 if(set==0) { while(1) { delay(500);//消抖 if(set==0) { temp1++; while(!set) scan(); } if(temp1==1) { xianshi(high); scan(); if(add==0) { while(!add) scan(); high+=1; } if(dec==0) { while(!dec) scan(); high-=1; } } if(temp1==2) { xianshi(low); if(add==0) { while(!add) scan(); low+=1; } if(dec==0) { while(!dec) scan(); low-=1; } scan(); } if(temp1>=3) { temp1=0; break; } } } } /****************主函數(shù)************************/ void main() { dm=0x00; //初始化端口 w0=1; w1=1; w2=1; w3=1; for(h=0;h<4;h++) //開(kāi)機(jī)顯示"0000" { display[h]=0; } ow_reset(); //開(kāi)機(jī)先轉(zhuǎn)換一次 write_byte(0xcc); //Skip ROM write_byte(0x44); //發(fā)轉(zhuǎn)換命令 for(h=0;h<100;h++) //開(kāi)機(jī)顯示"0000" { scan(); } while(1) { if (temp1==0) { work_temp(read_temp()); //處理溫度數(shù)據(jù) BEEP(); scan(); //顯示溫度值 keyscan(); } else keyscan(); } } |
