查看: 4424|回復(fù): 1
單片機(jī)數(shù)字電壓表仿真,量程(1-150v)誤差±1v,帶匯編源碼
采用adc0804來進(jìn)行模數(shù)轉(zhuǎn)換.
由于算法原因,顯示到160v時(shí),數(shù)碼管動(dòng)態(tài)顯示會(huì)很不穩(wěn)定,所以將其量程限制到150v,誤差精度為(±1v),誤差原因:adc0804 參考電壓懸空,導(dǎo)致其測(cè)量精度為19.53mv,為了計(jì)算方便,選取19.5mv,導(dǎo)致誤差~
匯編程序如下:
  1. AD_RD   BIT    P3.3
  2.           AD_WR   BIT    P3.4
  3.           AD_INTR  BIT    P3.5
  4.           ORG         00H
  5. SETUP:
  6.           MOV         R6,#0
  7.           MOV         30H,#0
  8.           MOV         31H,#0
  9.            MOV         32H,#0
  10. MAIN:
  11.           MOV         P1,#0FFH
  12.            CLR         AD_WR
  13.           SETB        AD_WR
  14. D5:
  15.           JB          AD_INTR,D5
  16.           CLR         AD_RD
  17.           MOV         A,P1
  18.           CALL        START
  19.           CALL        DIS
  20.           SETB        AD_RD
  21.           JMP         MAIN
  22. START:
  23.           MOV         A,P1
  24.           MOV         B,#195
  25.           MUL         AB
  26.           MOV         R0,A
  27.           MOV         R1,B
  28.           MOV         R2,#0
  29. AA:
  30.           CLR         C
  31.             MOV         A,R0
  32.           SUBB        A,#200
  33.            MOV         R0,A
  34.           MOV         A,R1
  35.           SUBB        A,#0
  36.           MOV         R1,A
  37.           JC          BB
  38.           INC         R2
  39.           JMP         AA
  40. BB:
  41.              MOV         A,R2
  42.              MOV         B,#100
  43.              DIV         AB
  44.              MOV         30H,A
  45.
  46.              MOV         A,B
  47.              MOV         B,#10
  48.              DIV         AB
  49.               MOV         31H,A
  50.              MOV         32H,B
  51.
  52.              RET
  53. DIS:
  54.              MOV         DPTR,#TAB
  55.              MOV         A,30H
  56.              CJNE        A,#0,D9
  57.              INC         R6
  58.               JMP         D10
  59. D9:          MOVC        A,@A+DPTR
  60.               MOV         P0,A
  61.              CLR         P2.0
  62.               CALL        DEL
  63. D10:             SETB        P2.0
  64.              MOV         A,31H
  65.              CJNE        R6,#1,D8
  66.              CJNE        A,#0,D8
  67.              JMP         D7
  68. D8:             MOVC        A,@A+DPTR
  69.              MOV         P0,A
  70.              CLR         P2.1
  71.               CALL        DEL
  72. D7:             SETB        P2.1
  73.              MOV         R6,#0
  74.
  75.              MOV         A,32H
  76.              MOVC        A,@A+DPTR
  77.              MOV         P0,A
  78.              CLR         P2.2
  79.               CALL        DEL
  80.              SETB        P2.2
  81.              MOV         A,#0C1H
  82.              MOV         P0,A
  83.              CLR         P2.3
  84.              CALL        DEL
  85.               SETB        P2.3
  86.              RET
  87. DEL:
  88.              MOV          R7,#20
  89.                DJNZ         R7,$
  90.              RET
  91.
  92. TAB:
  93. DB           0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
  94. END
數(shù)字電壓表代碼與圖.zip
20.99 KB, 下載次數(shù): 38, 下載積分: 黑幣 -5
相關(guān)帖子
ID:438003 發(fā)表于 2018-12-6 22:35 來自觸屏版 | 只看該作者
感謝分享
