查看: 38580|回復(fù): 117
51單片機(jī)0-30v 4A數(shù)控電源
給51黑論壇的朋友們分享一個(gè)不錯(cuò)的51單片機(jī)0-30v 4A數(shù)控電源.就是成本有點(diǎn)高!兩路輸出:1:0-30V/4A   2: 5V/1.5A(固定輸出)
電壓分辨率0.458mV,電流分辨率0.076mA
電壓步進(jìn)0.0073V,實(shí)際用的是0.1V步進(jìn)調(diào)節(jié)
在制作中發(fā)現(xiàn);C37極性畫反了!還有就是復(fù)位電路是51和AVR都兼容的,不能把四個(gè)原件都焊接上去,
用什么芯片就焊接什么樣的復(fù)位電路 !特此告知!
單片機(jī)源程序:
  1. #include"reg52.h"
  2. #include"math.h"
  3. #include"intrins.h"
  4. #include"function.h"
  5. #define DB P0
  6. sbit RS = P1^4;
  7. sbit RW = P1^5;
  8. sbit E  = P1^6;
  9. uchar code logo[] = {
  10. /*--  調(diào)入了一幅圖像:I:\液晶屏BMP圖\菜單.bmp  --*/
  11. /*--  寬度x高度=128x64  --*/
  12. 0x00,0x00,0x00,0x20,0x20,0x08,0x20,0x20,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
  13. 0x00,0x00,0x00,0x20,0x17,0xFC,0x13,0xF0,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
  14. 0x00,0x00,0x78,0x20,0x50,0x08,0x12,0x20,0x24,0x90,0x00,0x00,0x00,0x00,0x00,0x00,
  15. 0x10,0x00,0x4B,0xFC,0x40,0x08,0x02,0x20,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  16. 0x70,0x00,0x48,0x20,0x47,0xC8,0x02,0x1C,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  17. 0x10,0x00,0x48,0x20,0x44,0x48,0xF4,0x00,0x7F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
  18. 0x10,0x00,0x79,0x20,0x44,0x48,0x1B,0xF0,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  19. 0x10,0x00,0x48,0xA0,0x47,0xC8,0x11,0x10,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  20. 0x10,0x00,0x48,0xA0,0x44,0x48,0x11,0x10,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  21. 0x10,0x00,0x48,0x20,0x44,0x48,0x14,0xA0,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  22. 0x10,0x00,0x78,0x20,0x47,0xC8,0x18,0x40,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  23. 0x10,0x60,0x48,0x20,0x40,0x08,0x10,0xA0,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  24. 0x7C,0x60,0x40,0xA0,0x40,0x28,0x03,0x1C,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  25. 0x00,0x00,0x00,0x40,0x40,0x10,0x0C,0x08,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
  26. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x10,0x00,0x10,0x20,0x20,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x1F,0xF8,0x3F,0xF8,0x13,0xF0,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
  29. 0x00,0x00,0x10,0x10,0x00,0x00,0x12,0x20,0x24,0x90,0x00,0x00,0x00,0x00,0x00,0x00,
  30. 0x3C,0x00,0x1F,0xF0,0x00,0x00,0x02,0x20,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  31. 0x42,0x00,0x10,0x10,0x00,0x08,0x02,0x1C,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  32. 0x42,0x00,0x1F,0xF0,0x7F,0xFC,0xF4,0x00,0x7F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x02,0x00,0x10,0x10,0x01,0x00,0x1B,0xF0,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  34. 0x04,0x00,0x04,0x80,0x09,0x40,0x11,0x10,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  35. 0x08,0x00,0x44,0x88,0x09,0x20,0x11,0x10,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  36. 0x10,0x00,0x24,0x90,0x11,0x10,0x14,0xA0,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  37. 0x20,0x00,0x14,0xA0,0x21,0x08,0x18,0x40,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  38. 0x42,0x60,0x14,0xC0,0x41,0x08,0x10,0xA0,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
  39. 0x7E,0x60,0x04,0x88,0x05,0x00,0x03,0x1C,0x10,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
  40. 0x00,0x00,0xFF,0xFC,0x02,0x00,0x0C,0x08,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x08,0x40,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x00,0x1C,0x40,0x02,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. 0x00,0x00,0xF0,0x40,0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  45. 0x3C,0x00,0x11,0x50,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  46. 0x42,0x00,0xFD,0x48,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  47. 0x42,0x00,0x11,0x44,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  48. 0x04,0x00,0x32,0x44,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  49. 0x18,0x00,0x3A,0x40,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  50. 0x04,0x00,0x52,0x48,0x09,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  51. 0x02,0x00,0x50,0x10,0x18,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  52. 0x42,0x00,0x90,0x20,0x28,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  53. 0x42,0x60,0x10,0x40,0xC9,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  54. 0x3C,0x60,0x11,0x80,0x0A,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  55. 0x00,0x00,0x16,0x00,0x0C,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  57. 0x00,0x00,0x20,0x08,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  58. 0x00,0x00,0x17,0xFC,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  59. 0x00,0x00,0x48,0x08,0x3C,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  60. 0x08,0x00,0x42,0x08,0x41,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61. 0x08,0x00,0x5F,0xE8,0x41,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  62. 0x18,0x00,0x42,0x08,0xF9,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  63. 0x28,0x00,0x4F,0xC8,0xA1,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  64. 0x48,0x00,0x4A,0x48,0x21,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  65. 0x48,0x00,0x4A,0x48,0xFD,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  66. 0x7E,0x00,0x4A,0x48,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  67. 0x08,0x00,0x4A,0xC8,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  68. 0x08,0x60,0x42,0x08,0x28,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  69. 0x1E,0x60,0x42,0x28,0x30,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  70. 0x00,0x00,0x40,0x10,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  73. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  76.                      };
  77. /************************************************************************************
  78.                    查忙函數(shù)
  79. ************************************************************************************/
  80. void busy(void)//RS=0;RW=1;wait=0閑;wait!=0忙
  81. {
  82.     uchar wait;
  83.     RS = 0;
  84.     RW = 1;
  85.     E = 1;
  86.     for(;;)
  87.     {
  88.         wait = DB;
  89.         wait &= 0x80;
  90.         if(wait == 0)break;
  91.     }
  92.     E = 0;
  93. }
  94. /************************************************************************************
  95.                    寫指令函數(shù)
  96. ************************************************************************************/
  97. void w_code(uchar c)//RS=0;RW=0;E下降沿
  98. {
  99.     busy();
  100.     RS = 0;
  101.     RW = 0;
  102.     DB = c;
  103.     E = 1;
  104.     E = 0;
  105.     DB = 0xff;
  106. }
  107. /************************************************************************************
  108.                    寫數(shù)據(jù)函數(shù)
  109. ************************************************************************************/
  110. void w_data(uchar d)//RS=1;RW=0;E下降沿
  111. {
  112.     busy();
  113.     RS = 1;
  114.     RW = 0;
  115.     DB = d;
  116.     E = 1;
  117.     E = 0;
  118.     DB = 0xff;
  119. }
  120. /************************************************************************************
  121.                          讀數(shù)據(jù)函數(shù)
  122. ************************************************************************************/
  123. uchar r_data(void)//RS=1;RW=1;E下降沿
  124. {
  125.     uchar rd_lcd;
  126.     busy();
  127.     RS = 1;
  128.     RW = 1;
  129.     E = 1;
  130.     rd_lcd = DB;
  131.     E = 0;
  132.          return rd_lcd;
  133. }
  134. /************************************************************************************
  135.                    寫DGRAM:x_lcd橫坐標(biāo),y_lcd縱坐標(biāo)
  136. ************************************************************************************/
  137. void address(uchar x_lcd,uchar y_lcd)//
  138. {
  139.     w_code(y_lcd);//垂直坐標(biāo)
  140.     w_code(x_lcd);//水平坐標(biāo)
  141. }
  142. /************************************************************************************
  143.                    初始化液晶屏
  144.                                    0:字庫  1:繪圖
  145. ************************************************************************************/
  146. void  lcd_rst(bit a)
  147. {
  148.     if(a)
  149.         {
  150.         w_code(0x01);//   清屏
  151.         w_code(0x32);//   功能設(shè)置---8BIT控制界面,繪圖顯示ON
  152.         w_code(0x36);//   功能設(shè)置---8BIT控制界面,擴(kuò)充指令集
  153.         }
  154.         else
  155.         {
  156.         w_code(0x30);// 功能設(shè)置---8BIT控制界面,基本指令集
  157.         w_code(0x0c);//顯示打開,光標(biāo)關(guān),反白顯示關(guān)
  158.         w_code(0x01);// 清除屏幕顯示,將DDRAM的地址計(jì)數(shù)器歸零
  159.         }
  160. }
  161. /************************************************************************************
  162. ---------------------------寫整屏點(diǎn)陣數(shù)據(jù)
  163. ---------------------------x :圖像數(shù)據(jù)的起始地址
  164. ************************************************************************************/
  165. void  write_lcd_full(uint x )
  166. {
  167.
  168.           uchar  i,j,a;
  169.           j = 0x80; //Y地址寄存器
  170.           for(a = 0;a < 32;a++)
  171.                   {
  172.                 w_code(j);
  173.                 j++;
  174.                 w_code(0x80);//X地址寄存器
  175.                   for(i = 0;i < 16;i ++)
  176.                           {
  177.                         w_data(logo[x]);
  178.                         x++;
  179.                         }
  180.                 }
  181.           j = 0x80; //Y地址寄存器
  182.           for(a = 0;a < 32;a++)
  183.                   {
  184.                 w_code(j);
  185.                 j++;
  186.                 w_code(0x88);//X地址寄存器
  187.                   for(i = 0;i < 16;i ++)
  188.                           {
  189.                         w_data(logo[x]);
  190.                         x++;
  191.                         }
  192.                 }
  193. }
數(shù)控電源的所有資料下載:
0-30V 4A數(shù)控穩(wěn)壓電源資料.zip (2.37 MB, 下載次數(shù): 1229)
參與人數(shù) 14黑幣 +251 收起 理由
sunlei058378 + 30
zlgmo + 15
wofei1314 + 2 共享資料的黑幣獎(jiǎng)勵(lì)!
ko44 + 5 贊一個(gè)!
光柵 + 30 共享資料的黑幣獎(jiǎng)勵(lì)!
vvv64 + 5 共享資料的黑幣獎(jiǎng)勵(lì)!
chit100 + 5 贊一個(gè)!
mcu明明 + 5 贊一個(gè)!
map0391 + 30
lgjdqm + 8 回帖助人的獎(jiǎng)勵(lì)!
隨易而安 + 5 共享資料的黑幣獎(jiǎng)勵(lì)!
邰夏留 + 3 共享資料的黑幣獎(jiǎng)勵(lì)!
xmd1972 + 8 共享資料的黑幣獎(jiǎng)勵(lì)!
admin + 100 共享資料的黑幣獎(jiǎng)勵(lì)!
收藏收藏67 分享淘帖 頂9 踩
ID:138155 發(fā)表于 2016-9-15 16:11 | 只看該作者
51黑有你更精彩~~!
ID:69271 發(fā)表于 2016-10-11 10:43 | 只看該作者
這個(gè)文檔不得不說,太全了,什么都有,我就喜歡這樣的帖子。謝謝,樓主辛苦了!
ID:69271 發(fā)表于 2016-10-11 15:47 | 只看該作者
但是好像沒有PID的內(nèi)容,在單片機(jī)內(nèi)的程序里。
ID:143914 發(fā)表于 2016-11-8 06:27 來自觸屏版 | 只看該作者
厲害啊,我才剛開始學(xué),不知啥時(shí)候能到這水平啊
ID:147195 發(fā)表于 2016-11-11 09:30 | 只看該作者
我最想做出來的一樣?xùn)|西,可惜水平差太多,先收藏了
ID:134868 發(fā)表于 2016-11-12 18:44 | 只看該作者
業(yè)余愛好,正在做這個(gè)準(zhǔn)備自用,以后自己維修方便點(diǎn),正在做電壓電流取樣部分,想看看你的資料差點(diǎn)積分
ID:79034 發(fā)表于 2016-11-21 08:39 | 只看該作者
謝謝樓主分享,下載了就頂貼,養(yǎng)成良好的習(xí)慣,也方便新手學(xué)習(xí)
ID:154111 發(fā)表于 2016-12-12 14:00 | 只看該作者
資料還不錯(cuò)哦,謝謝樓主分享。。。。。。。。!
ID:74784 發(fā)表于 2016-12-19 16:40 | 只看該作者
有壇友做出來的嗎?
說說效果咋樣?
ID:124995 發(fā)表于 2016-12-19 18:11 | 只看該作者
高手哇,新手來學(xué)習(xí)
ID:157346 發(fā)表于 2016-12-24 15:08 | 只看該作者
還差一點(diǎn)就可以看樓主的資料了
ID:59611 發(fā)表于 2016-12-26 18:32 | 只看該作者
謝謝樓主分享 下載學(xué)習(xí)學(xué)習(xí)
ID:157505 發(fā)表于 2016-12-29 23:02 | 只看該作者
新手學(xué)習(xí)了
ID:158812 發(fā)表于 2016-12-30 09:34 | 只看該作者
不錯(cuò)的東西,但是黑幣不夠
新手學(xué)習(xí)了
ID:139856 發(fā)表于 2016-12-31 17:04 | 只看該作者
這個(gè)可以
ID:73762 發(fā)表于 2017-1-4 21:48 | 只看該作者
不錯(cuò)的東西
ID:160455 發(fā)表于 2017-1-6 16:14 | 只看該作者
高手啊,學(xué)習(xí)一下,參考參考。
ID:159575 發(fā)表于 2017-1-7 15:50 來自觸屏版 | 只看該作者
學(xué)習(xí)了,改天做一個(gè)
ID:153194 發(fā)表于 2017-1-12 08:23 | 只看該作者
喜歡這樣的帖子。謝謝,樓主辛苦了!
ID:159122 發(fā)表于 2017-1-22 07:53 來自觸屏版 | 只看該作者
初學(xué)者膜拜
ID:162916 發(fā)表于 2017-1-25 11:33 | 只看該作者
很好的資料
ID:161527 發(fā)表于 2017-1-28 19:39 | 只看該作者
該電源真好,可惜本人水平有限,看不懂。但是也要謝謝。
ID:113020 發(fā)表于 2017-2-10 10:59 | 只看該作者
謝謝樓主分享
ID:96881 發(fā)表于 2017-2-26 21:46 | 只看該作者
非常感謝分享,學(xué)習(xí)一下
ID:56054 發(fā)表于 2017-5-15 09:51 | 只看該作者
很滿意的資料
ID:201207 發(fā)表于 2017-5-16 09:05 | 只看該作者
ID:86001 發(fā)表于 2017-6-12 22:05 | 只看該作者
非常感謝正需要這部分資料
ID:225934 發(fā)表于 2017-8-9 09:06 | 只看該作者
先收藏了   有時(shí)間了做一個(gè)試試
ID:231788 發(fā)表于 2017-9-7 22:02 | 只看該作者
做DC/DC參考一下
ID:198608 發(fā)表于 2017-9-15 18:40 | 只看該作者
樓主有沒有元件清單
ID:237459 發(fā)表于 2017-10-6 13:41 | 只看該作者
主要是電路,電路很好
ID:242891 發(fā)表于 2017-10-27 20:43 | 只看該作者
強(qiáng)烈要求有75V25A的,300塊錢求購成品。
ID:244044 發(fā)表于 2017-10-29 22:40 | 只看該作者
新手學(xué)習(xí)中  點(diǎn)贊
ID:244062 發(fā)表于 2017-10-30 00:27 來自觸屏版 | 只看該作者
不錯(cuò),又做出實(shí)物的嘛
ID:154669 發(fā)表于 2017-10-30 08:32 | 只看該作者
這個(gè)電路板怎么買還是自己做的
ID:244719 發(fā)表于 2017-10-31 21:16 | 只看該作者
大部分都是來混分,水經(jīng)驗(yàn)的,只有我是認(rèn)真回帖的
ID:96218 發(fā)表于 2017-11-1 08:46 | 只看該作者
追求精度,成本就上去了。
ID:245291 發(fā)表于 2017-11-2 14:02 | 只看該作者
正要 做 這方面的東西 用你 資料來驗(yàn)證一下,做出來后 來展示一下成果
