包含:仿真圖+C語(yǔ)言程序+功能說(shuō)明+元器件清單(非實(shí)物)
設(shè)計(jì)說(shuō)明: 用一片51系列單片機(jī)作為主控制器,DS18B20測(cè)量實(shí)時(shí)溫度,現(xiàn)實(shí)范圍為-55到127攝氏度。 用DS1302時(shí)鐘芯片,具有閏年閏月自動(dòng)計(jì)算。用共陰極數(shù)碼管進(jìn)行顯示。74hc138和74hc154進(jìn)行位選驅(qū)動(dòng)數(shù)碼管,用74hc595進(jìn)行傳送數(shù)據(jù)。 按鍵調(diào)整說(shuō)明: 第一次按下調(diào)整鍵,則年的后兩位開(kāi)始閃爍,此時(shí)如果按下加或者減進(jìn)行年的更改,更改之后,如果無(wú)需對(duì)其他時(shí)間更改,直接按下確認(rèn)鍵,即可保存更改后的數(shù)據(jù),并且返回正常的顯示。如果需要對(duì)其的更改,則繼續(xù)按下調(diào)整鍵,第二次按下調(diào)整鍵時(shí),調(diào)整對(duì)象為月,第三次為日,次為時(shí),第五次為分。這里無(wú)需調(diào)整星期,星期的調(diào)整是調(diào)整以后,自動(dòng)計(jì)算星期,并隨著確認(rèn)鍵的按下進(jìn)行刷新的。 元器件清單: STC89C51單片機(jī) | | | | | | | | | | | | | | | | | | | | | | | | | | BUTTON輕觸開(kāi)關(guān) | 4 |
- #include<reg51.h>
- #include<absacc.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define ture 1
- #define fault 0
- sbit SET=P1^7;
- void delay(uchar k) ;
- uchar monthday(uchar a,uchar b);
- void display() ;
- uchar code dayofmonth[]={31,28,31,30,31,30,31,31,30,31,30,31};
- uchar code scan[]={0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,
- 0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
- 0xf8,0xf9,0xfa,0xfb,0xfc,0xfd};
- //掃描的譯碼信號(hào)
- uchar i;
- uchar code table[]={0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0xA7,0xFF,0xEF,0xC0};
- uchar buffer[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
- uchar shuju=0;
- uchar state=0;
- uchar qxiang;
- typedef struct
- uchar year[2];
- uchar month;
- uchar day;
- uchar week;
- }date;
- typedef struct
- uchar hour;
- uchar minute;
- uchar second;
- }time;
- uchar count=0;
- date today={{9,20},4,20,1};
- time now={11,8,10};
- void main()
- TMOD=0x01;
- TL0=(65536-1000)%256;
- TH0=(65536-1000)/256;
- IE=0x82; //EA=1;ET0=1總中斷允許和定時(shí)器中斷允許
- TCON=0x10; //定時(shí)器啟動(dòng)計(jì)數(shù)
- while(1)
- P1=0xff;
- shuju=P1&0xff;
- qxiang=shuju&0x80;
- switch(qxiang)
- case(0x80):switch(shuju)
- case(0xfe) : //秒調(diào)整
- EA=1;
- EX0=1; //IE=0x83; //EA=1;ET0=1;EX0=0總中斷允許,定時(shí)器中斷允許,外中斷允許
- IT0=1; //TCON=0x11; //TR0=1;IT0=1;定時(shí)器啟動(dòng),外中斷為負(fù)邊沿觸發(fā)
- }break;
- case(0xfd) : //分調(diào)整
- EA=1;
- EX0=1; // IE=0x83;
- }break;
- case(0xfb) : //時(shí)調(diào)整
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0xf7) : //星期調(diào)整
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0xef) : //日調(diào)整
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0xdf): //月調(diào)整
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0xbf): //年調(diào)整
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- default: //時(shí)鐘正常計(jì)時(shí)
- EA=1;
- TR0=1;
- EX0=0;
- }break;
- }break;
- case(0x00) :switch(shuju)
- case(0x7e):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x7d):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x7b):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x77):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x6f):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x5f):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- case(0x3f):
- EA=1;
- EX0=1;
- IT0=1;
- }break;
- EA=1;
- TR0=1;
- EX0=0;
- }break;
- }break;
- void inter0() interrupt 0 using 0
- uchar result,z;
- result=shuju;
- switch(qxiang)
- case(0x80): switch(result)
- case(0xfe) : // if(result==0xfe) //秒調(diào)整 +
- now.second++;
- if(now.second>=60)
- now.second=0;
- display();
- }break;
- case(0xfd) : //if(result==0xfd) //分調(diào)整 +
- now.minute++;
- if(now.minute>=60)
- now.minute=0;
- display();
- }break;
- case(0xfb) : //if(result==0xfb) //時(shí)調(diào)整 +
- now.hour++;
- if(now.hour>=24)
- now.hour=0;
- display();
- }break;
- case(0xf7) : // if(result==0xf7) //星期調(diào)整 +
- today.week++;
- if(today.week>=8)
- today.week=1;
- display();
- }break;
- case(0xef) : //if(result==0xef) //日期調(diào)整 +
- today.day++;
- z = monthday( today.year[1] , today.year[0] );
- if((z==1)&&(today.month==2))
- if(today.day>=30)
- today.day=1;
- else if (today.day>dayofmonth[today.month-1])
- today.day=1;
- display();
- }break;
- case(0xdf) : //if(result==0xdf) //月調(diào)整 +
- today.month++;
- if(today.month>=13)
- today.month=1;
- display();
- } break;
- case(0xbf) : //if(result==0xbf) //年調(diào)整 +
- today.year[0]=today.year[0]+1;
- if(today.year[0]>=100)
- today.year[0]=0;
- today.year[1]=today.year[1]+1;
- if(today.year[1]>=100)
- today.year[1]=0;
- display();
- }break;
- EA=1;
- TR0=1;
- EX0=0;
- }break;
- }break;
- case(0x00): switch(result)
- case(0x7e): //if(result==0x7f) //秒調(diào)整—
- if(now.second>0)
- now.second=now.second-1;
- else now.second=59;
- display();
- }break;
- case(0x7d): //if(result==0x7d) //分調(diào)整—
- if(now.minute>0)
- now.minute=now.minute-1;
- else now.minute=59;
- display();
- } break;
- case(0x7b) : //if(result==0x7b) // 時(shí)調(diào)整-
- if(now.hour>0)
- now.hour=now.hour-1;
- else now.hour=23 ;
- display();
- }break;
- case(0x77) : //if(result==0x77) // 周調(diào)整—
- if(today.week>1)
- today.week=today.week-1;
- else today.week=7;
- display();
- }break;
- case(0x6f): //if(result==0x6f) // 日期調(diào)整—
- if(today.day>1)
- today.day=today.day-1;
- else today.day=29;
- else {
- if(today.day>1)
- else today.day=dayofmonth[today.month-1];
- display();
- }break;
- case(0x5f): //if(result==0x5f) // 月調(diào)整—
- if(today.month>1)
- today.month=today.month-1;
- else today.month=12;
- display();
- }break;
- case(0x3f) : // 年調(diào)整——
- if(today.year[0]>0)
- today.year[0]=today.year[0]-1;
- else
- today.year[0]=99;
- today.year[1]=today.year[1]-1;
- display();
- }break;
- EA=1;
- TR0=1;
- EX0=0;
- }break;
- }break;
- void timer0_int() interrupt 1 using 1
- uchar c;
- TL0=(65536-1000)%256; //中斷時(shí)間是10ms
- TR0=1;
- count++;
- if(count==35)
- count=0;
- now.second=now.second+1;
- now.second=0;
- now.minute++;
- now.minute=0;
- now.hour++;
- if(now.hour>=24)
- now.hour=0;
- today.week++;
- today.day++;
- if(today.week>=8)
- today.week=1;
- c=monthday( today.year[1], today.year[0]);
- if((c==1)&&(today.month==2))
- if(today.day>=30)
- today.day=1;
- today.month++;
- else if(today.day>=(dayofmonth[today.month-1]+1))
- today.day=1;
- today.month++;
- today.month=1;
- today.year[0]=0;
- today.year[1]=0;
- display();
- uchar m,n;
- for(m=0;m<=k;m++)
- for(n=0;n<=40;n++);
- // 計(jì)算年份程序
- uchar x,y;
- x=a*100+b;
- if(x%4!=0)
- y=0;
- else if(x%100!=0)
- y=1;
- else if(x%400!=0)
- y=0;
- else y=1;
- //if((x%4==0 && x%100!=0)|| (x%400==0))
- // y=1;
- // else y=0;
- return(y) ;
- void display()
- buffer[0]=now.second%10;
- buffer[1]=now.second/10;
- buffer[2]=10;
- buffer[3]=now.minute%10;
- buffer[4]=now.minute/10;
- buffer[5]=10;
- buffer[6]=now.hour%10;
- buffer[7]=now.hour/10;
- buffer[8]=today.week%10;
- buffer[9]=today.week/10;
- buffer[10]=10;
- buffer[11]=today.day%10;
- buffer[12]=today.day/10;
- buffer[13]=10;
- buffer[14]=today.month%10;
- buffer[15]=today.month/10;
- buffer[16]=10;
- buffer[17]=today.year[0]%10;
- buffer[18]=today.year[0]/10;
- buffer[19]=today.year[1]%10;
- buffer[20]=today.year[1]/10;
- buffer[21]=10;
- for(i=0;i<=21;i++)
- P0=table[buffer[i]];
- P2=scan[i];
- delay(8);
- P2=0xFF;
所有資料下載:
51單片機(jī)萬(wàn)年歷3個(gè)數(shù)碼管顯示.rar
(80.18 KB, 下載次數(shù): 339)
2016-10-11 00:31 上傳
點(diǎn)擊文件名下載附件
