下面是仿真圖:
2016-10-21 16:58 上傳
2016-10-21 16:58 上傳
2016-10-21 16:58 上傳
2016-10-21 16:58 上傳
- /****************************************Copyright (c)**************************************************
- ** File Name :
- ** Version : V1.0.0
- ** Description :
- * 【外部晶振】: 11.0592mhz
- * 【主控芯片】: STC89C52
- * 【編譯環(huán)境】: Keil μVisio4
- * 【程序功能】:
- * 【使用說明】:
- ** Author : Creavalia
- ** Date : 2016年10月19日
- ** Modify Person:
- ** Modify Date :
- ** Description :
- // Includes --------------------------------------------------------------------------------------------
- #include<reg51.h>
- ** Marcos define
- #define MotorTabNum 5
- unsigned char T0_NUM;
- //IO設(shè)置
- sbit K1 = P3^5; // 啟動
- sbit K2 = P3^4; // 反向
- sbit K3 = P3^3; // 加速
- sbit K4 = P3^2; // 減速
- sbit FX = P2^4; // 方向
- sbit MotorEn = P2^5; // 使能
- sbit CLK = P2^6; // 脈沖
- //----數(shù)碼管---------------
- sbit SMG1 = P2^0; //數(shù)碼管第一位定義
- sbit SMG2 = P2^1; //數(shù)碼管第二位定義
- sbit SMG3 = P2^2; //數(shù)碼管第三位定義
- sbit SMG4 = P2^3; //數(shù)碼管第四位定義
- int table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; //共陰極數(shù)碼管段值
- //int table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,}; //共陽極數(shù)碼管段值
- unsigned char g_MotorSt = 0; // 啟停
- unsigned char g_MotorDir = 0; // 正反
- //unsigned char MotorTab[6] = {200, 160, 120, 80, 40, 20};
- unsigned char MotorTab[6] = {12, 10, 8, 6, 4, 2};
- //unsigned char MotorTab[6] = {6, 5, 4, 3, 2, 1};
- signed char g_MotorNum = 0;
- void delayms(xms);
- void mDelay(unsigned int DelayTime); //延時函數(shù)
- void T0_Init();
- void KeyScan(void);
- void Display(void);
- // 主程序 main()
- void main(void)
- unsigned char i;
- T0_Init(); // 定時器0 初始化
- MotorEn = 0; // L297 使能(只有智能,才能正常工作,否則停止)
- FX = 0;
- while(1)
- KeyScan(); // 按鍵
- for(i=0; i<10; i++)
- Display();
- /********定時器初始化***********************************************************/
- void T0_Init()
- TMOD = 0x01;
- TH0 = (65535-100)/256; // 1ms
- TL0 = (65535-100)%256;
- EA = 1;
- ET0 = 1;
- // TR0 = 1;
- /********定時器中斷*****************/
- void T0_time() interrupt 1
- // TR0 = 0;
- T0_NUM++;
- if(T0_NUM >= MotorTab[g_MotorNum]) // 增加按鍵g_MotorNum++ 減小按鍵g_MotorNum--
- T0_NUM = 0;
- CLK=CLK^0x01; // 輸出脈沖
- // TR0 = 1;
- //-----按鍵控制---------------------
- if(K1 == 0)
- delayms(5); // 軟件延時消抖
- if(K1 == 0)
- while(!K1){Display();};
- g_MotorSt = g_MotorSt ^ 0x01;
- MotorEn ^= 1;
- TR0 = 1;
- if(K2 == 0)
- delayms(10); // 軟件延時消抖
- if(K2 == 0)
- // while(!K2){Display();};
- g_MotorDir = g_MotorDir ^ 0x01;
- FX ^= 1;
- while(!K2){Display();};
- if(K3 == 0) // 加速
- if(K3 == 0)
- while(!K3){Display();};
- g_MotorNum++;
- if(g_MotorNum > MotorTabNum)
- g_MotorNum = MotorTabNum;
- if(K4 == 0) // 減速
- if(K4 == 0)
- while(!K4){Display();};
- g_MotorNum--;
- if(g_MotorNum < 0)
- g_MotorNum = 0;
- * 名稱: Set_Display()
- * 功能: 數(shù)碼管顯示函數(shù)
- * 輸入: 無
- * 輸出: 無
- * 說明:
- unsigned char b1, b2;
- b1=g_MotorNum/10;
- b2=g_MotorNum%10;
- if(FX == 0)
- P0=0x71;//顯示F
- else
- P0=0x79;
- SMG1=0;
- delayms(3);
- SMG1=1;
- P0=0x40;
- SMG2=0; //顯示--
- delayms(3);
- SMG2=1;
- P0=table[b1];
- SMG3=0; //顯示十位
- delayms(3);
- SMG3=1;
- P0=table[b2];
- SMG4=0;
- delayms(3); //顯示個位
- SMG4=1;
- /********************************延時函數(shù)***********************************************************/
- void delayms(xms)
- unsigned int x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- ** End Of File
1、步進電機控制系統(tǒng)的主程序在對整個系統(tǒng)初始化后主要完成讀鍵盤和處理鍵盤的功能,如圖3-1所示: 圖3-1 步進電機控制系統(tǒng)主程序流程圖 系統(tǒng)上電復(fù)位后,先調(diào)用初始化子程序,對步進電機各端口,相關(guān)參數(shù)進行初始化,設(shè)置T0、T1工作方式控制字和時間常數(shù)。初始化完成后,步進電機處于停止?fàn)顟B(tài),T0、T1定時器處于關(guān)閉狀態(tài)。然后循環(huán)調(diào)用讀鍵盤子程序和鍵盤處理子程序,等待中斷,以便實現(xiàn)步進電機轉(zhuǎn)動控制和轉(zhuǎn)速的動態(tài)顯示。
2、讀鍵盤子程序流程圖讀鍵盤子程序流程圖如圖3-2所示: 圖3-2讀鍵盤子程序流程圖 首先初始化實際鍵值參數(shù)為0FH,然后掃描P3口,與初始值比較,相等則說明沒有鍵按下,不相等則軟件消抖,以便確認是否真的有鍵按下。延時10ms后再次掃描P3口,第二次與初始值比較,若相等則表明前一次比較不相等是由抖動產(chǎn)生;如果相等則表明確實有鍵按下。此時保存鍵值到臨時變量。接著第三次掃描鍵盤并與臨時變量比較,若相等則循環(huán),這是為了確保每一次按鍵只執(zhí)行一次相應(yīng)的處理程序。最后從臨時變量取出鍵值送實際鍵值參數(shù),為鍵盤處理子程序做準(zhǔn)備。 3、 鍵盤處理子程序流程圖按鍵處理子程序流程圖如圖3-3所示: 圖3-3鍵盤處理子程序流程圖 鍵盤處理子程序開始時要從存放實際鍵值的參數(shù)中取出剛讀取到的鍵值送到累加器A,依次判斷累加器A的低四位。若檢測到低電平,則說明與該位對應(yīng)的按鍵按下,從而轉(zhuǎn)到相應(yīng)的處理子程序段,完成相應(yīng)的操作,實現(xiàn)相應(yīng)的功能后返回。若沒有檢測到高電平,則返回。 步進電機的啟?刂仆ㄟ^啟停定時器0來實現(xiàn),因為定時器0控制著脈沖信號的輸出,關(guān)閉定時器0也就阻止了脈沖信號的輸出。 4、 電機控制中斷程序流程圖定時器中斷0服務(wù)程序流程圖如圖3-4所示: 圖3-4定時器中斷0服務(wù)程序流程圖 定時器中斷0服務(wù)程序的中斷時間由當(dāng)前的轉(zhuǎn)速決定。進入中斷程序后,首先要保護現(xiàn)場,再根據(jù)當(dāng)前速度進行計算并查表得到T0定時時間常數(shù),設(shè)置TH0和TL0的值。然后判斷轉(zhuǎn)動方向控制位的值,如果是0則控制脈沖信號循環(huán)左移并輸出,如果是1則控制脈沖信號循環(huán)右移并輸出。最后恢復(fù)現(xiàn)場,返回,等待下次中斷。 通過用當(dāng)前轉(zhuǎn)速控制中斷時間,控制了脈沖的輸出頻率,也就到達了控制步進電機轉(zhuǎn)動速度的目的;通過檢測方向控制位的電平,選擇脈沖信號的循環(huán)左移或循環(huán)右移,控制了步進電機各引出端的接通順序,也就到實現(xiàn)了步進電機轉(zhuǎn)動方向的控制。 5、 數(shù)碼顯示中斷程序流程圖定時中斷1服務(wù)程序流程圖如圖3-5所示: 圖3-5定時中斷1服務(wù)程序流程圖 數(shù)碼顯示中斷程序的定時時間為1ms。進入中斷程序后,首先要保護現(xiàn)場,然后關(guān)閉個位數(shù)碼管,根據(jù)當(dāng)前轉(zhuǎn)速求出十位與個位的值。查表得到十位的字段碼送P1口,控制十位上的數(shù)碼管顯示。然后延時1ms,接著關(guān)閉十位數(shù)碼管,查表得到個位的字段碼送P1口,控制個位上的數(shù)碼管顯示。最后重新設(shè)置定時時間,恢復(fù)現(xiàn)場并返回。
