#include<reg51.h> //頭文件
#define uchar unsigned char //宏定義,為方便編程
#define LED P0 //宏定義,將P1口定義為LED
uchar led_value[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0x00}; //定義一數(shù)組,內(nèi)存放跑馬燈數(shù)據(jù)
uchar *p=led_value; //定義指針,指向跑馬燈數(shù)組首地址
void delay() //延遲函數(shù),與跑馬燈跳動頻率有關
uchar ii,jj;
for(ii=0;ii<200;ii++)
for(jj=0;jj<200;jj++);
void run_led() //跑馬燈運行函數(shù)
while(*p!=0x00)
LED=*p; //將數(shù)組中數(shù)據(jù)取出賦給P1口
p++; //預取下一數(shù)據(jù)
delay(); //延遲
p=led_value;
char code SST516[3] _at_ 0x003b; //仿真器保留
main() //主函數(shù)
run_led(); //上電即運行跑馬燈程序
