查看: 10768|回復(fù): 6
UART串口通信及控制數(shù)碼管顯示的示例
ID:164629 發(fā)表于 2017-2-20 13:12 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = {  //數(shù)碼管顯示字符轉(zhuǎn)換表
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[7] = {  //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū)
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
unsigned char RxdByte = 0;  //串口接收到的字節(jié)
void ConfigTimer0(unsigned int ms);
void ConfigUART(unsigned int baud);
    EA = 1;       //使能總中斷
    ENLED = 0;    //選擇數(shù)碼管和獨(dú)立LED
    ADDR3 = 1;
    ConfigTimer0(1);   //配置T0定時(shí)1ms
    ConfigUART(9600);  //配置波特率為9600
    while (1)
    {   //將接收字節(jié)在數(shù)碼管上以十六進(jìn)制形式顯示出來(lái)
        LedBuff[0] = LedChar[RxdByte & 0x0F];
        LedBuff[1] = LedChar[RxdByte >> 4];
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
    unsigned long tmp;  //臨時(shí)變量
    tmp = 11059200 / 12;      //定時(shí)器計(jì)數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計(jì)算所需的計(jì)數(shù)值
    tmp = 65536 - tmp;        //計(jì)算定時(shí)器重載值
    tmp = tmp + 13;           //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時(shí)器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動(dòng)T0
/* 串口配置函數(shù),baud-通信波特率 */
    SCON  = 0x50;  //配置串口為模式1
    TMOD &= 0x0F;  //清零T1的控制位
    TMOD |= 0x20;  //配置T1為模式2
    TH1 = 256 - (11059200/12/32)/baud;  //計(jì)算T1重載值
    TL1 = TH1;     //初值等于重載值
    ET1 = 0;       //禁止T1中斷
    ES  = 1;       //使能串口中斷
    TR1 = 1;       //啟動(dòng)T1
/* LED動(dòng)態(tài)掃描刷新函數(shù),需在定時(shí)中斷中調(diào)用 */
void LedScan()
    static unsigned char i = 0;  //動(dòng)態(tài)掃描索引
    P0 = 0xFF;             //關(guān)閉所有段選位,顯示消隱
    P1 = (P1 & 0xF8) | i;  //位選索引值賦值到P1口低3位
    P0 = LedBuff[i];       //緩沖區(qū)中索引位置的數(shù)據(jù)送到P0口
    if (i < 6)             //索引遞增循環(huán),遍歷整個(gè)緩沖區(qū)
        i++;
        i = 0;
/* T0中斷服務(wù)函數(shù),完成LED掃描 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;  //重新加載重載值
    TL0 = T0RL;
    LedScan();   //LED掃描顯示
/* UART中斷服務(wù)函數(shù) */
void InterruptUART() interrupt 4
    if (RI)  //接收到字節(jié)
        RI = 0;  //手動(dòng)清零接收中斷標(biāo)志位
        RxdByte = SBUF;  //接收到的數(shù)據(jù)保存到接收字節(jié)變量中
        SBUF = RxdByte;  //接收到的數(shù)據(jù)又直接發(fā)回,叫作-"echo",
                         //用以提示用戶輸入的信息是否已正確接收
    if (TI)  //字節(jié)發(fā)送完畢
        TI = 0;  //手動(dòng)清零發(fā)送中斷標(biāo)志位
收藏收藏2 分享淘帖 頂 踩
相關(guān)帖子
ID:165533 發(fā)表于 2017-2-20 14:36 | 只看該作者
看看
學(xué)習(xí)學(xué)習(xí),代碼寫得不錯(cuò)
ID:166174 發(fā)表于 2017-2-23 14:25 | 只看該作者
代碼寫的很好,學(xué)習(xí)
ID:73030 發(fā)表于 2017-2-28 06:49 來(lái)自觸屏版 | 只看該作者
不錯(cuò),學(xué)習(xí)學(xué)習(xí)。
ID:126297 發(fā)表于 2018-1-28 11:48 | 只看該作者
對(duì)這個(gè)很感興趣!好!能給個(gè)實(shí)際電路圖嗎?
ID:482448 發(fā)表于 2020-3-24 21:20 | 只看該作者
這個(gè)程序我用過(guò),proteus仿真的時(shí)候數(shù)碼管是亂的
