查看: 1718|回復(fù): 0
藍(lán)牙小車程序
ID:197374 發(fā)表于 2017-5-6 19:34 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
uchar tmp;
unsigned char zkb=70 ;
sbit IN1=P2^2;
sbit IN2=P2^3;
sbit ENA=P2^0;
sbit ENB=P2^1;
int t=0;
void dely(int a)
int i,j;
for(i=0;i<a;i++)
for(j=0;j<110;j++);
void Go()
  IN1=1;
  IN2=0;
void Back()
  IN1=0;
  IN2=1;
void Stop()
  IN1=0;
  IN2=0;
void timer0() interrupt 1
        if(t<zkb)
           ENA=1;
           ENB=1;
           ENA=0;
           ENB=0;
        TH0=(65535-50)/256;
        TL0=(65535-50)%256;
        t++;
        if(t>=100)
          {t=0;}
void Init()
        TMOD = 0x21;          //定時器1工作于8位自動重載模式,用于產(chǎn)生波特率
        TH1=TL1=0xFD;          //11.0592M晶振,9600波特率
        SCON = 0x50;     //設(shè)定串行口工作方式1  允許接受
        PCON &= 0x7F;    //波特率不倍增
        TR1 = 1;                     //啟動定時器1
        ES=1;                         //開啟串口中斷
        EA=1;                          //開啟總中斷
    RI=0;
    TH0=(65535-50)/256;
    TL0=(65535-50)%256;
    ET0=1;
    TR0=1;
   Init();                                                //初始化
          switch(tmp)
               case 'F':
                  Go();
                              break;
            case 'B':
                  Back();
                              break;
       case 'S':
                  Stop();
                              break;
       case 'a':
                  zkb=10;
                              break;
            case 'b':
                  zkb=20;
                              break;
            case 'c':
                  zkb=30;
                              break;
            case 'd':
                  zkb=40;
                              break;
            case 'e':
                  zkb=50;
                              break;
            case 'f':
                  zkb=60;
                              break;
            case 'g':
                  zkb=70;
                              break;
            case 'h':
                  zkb=80;
                              break;
            case 'i':
                  zkb=90;
                              break;
            case 'j':
                  zkb=100;
                              break;
void serial_RX() interrupt 4
                if(RI==1)
                 RI = 0;
                 tmp = SBUF;
