查看: 2169|回復(fù): 0
求助c51單片機(jī)與Arduino的串口通信
ID:188933 發(fā)表于 2017-5-7 12:33 | 顯示全部樓層 |閱讀模式
想實(shí)現(xiàn)Arduino發(fā)送信息,c51接收信息,比如當(dāng)c51收到A后LED1一直亮,當(dāng)收到B后LED1滅LED2一直亮
自己寫的程序不對(duì),實(shí)現(xiàn)不了  求助大神
arduino程序
void setup()
Serial.begin(9600);
void loop()
     Serial.write('A');
     delay(5000);
     Serial.write('B');
     delay(5000);
C51程序
#include <reg52.h>
sbit LED1 = P1^0;
sbit LED2 = P1^1;
unsigned char UART_buff;
bit New_rec = 0;
bit Send_ed = 1;
void delay(int x)
  int i,j;
  for(i=0;i<x;i++)
    for(j=0;j<110;j++);
void main (void)
SCON = 0x50;//串口方式1, 8-n-1, 允許接收.
TMOD = 0x20;//T1方式2
TH1 = 0xFD; //9600bps@11.0592MHz
TL1 = 0xFD;
TR1 = 1;
ES= 1;   //開中斷.
EA= 1;
  if ((New_rec == 1) && (Send_ed == 1))//如果收到新數(shù)據(jù)及發(fā)送完畢
     SBUF = UART_buff; //那就發(fā)送.
     New_rec = 0;
     Send_ed = 0;
/***************中斷服務(wù)函數(shù)*********************/
void ser_int (void) interrupt 4
if(RI == 1)     //如果收到.
    RI = 0;          //清除標(biāo)志.
    New_rec = 1;
    UART_buff = SBUF;  //接收.
    if(UART_buff == '0')
