stm32單片機源程序:
- //通過串口實時打印KEY3 KEY4電壓值。
- //每個通道采集50次
- #include "pbdata.h"
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- void USART_Configuration(void);
- void ADC1_Configuration(void);
- void DMA_Configuration(void);
- vu16 AD_Value[N][M]; //用來存放ADC轉(zhuǎn)換結(jié)果,也是DMA的目標地址 define a N line and M row array
- vu16 filterAD[M+1]; //濾波后AD值
- vu16 MM;
- int fputc(int ch,FILE *f)
- USART_SendData(USART1,(u8)ch);
- while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
- return ch;
- int main(void)
- RCC_Configuration();
- GPIO_Configuration();
- USART_Configuration();
- NVIC_Configuration();
- ADC1_Configuration();
- DMA_Configuration();
- while(1)
- delay_ms(10); //延時,防止第一次上電或復位時,ADC沒有轉(zhuǎn)換完成
- filter();
- printf("key3=%f\r\n",filterAD[0]*3.3/4095);
- printf("key4=%f\r\n",filterAD[1]*3.3/4095);
- printf("pot =%f\r\n",filterAD[2]*3.3/4095);
- printf("\r\n");
- delay_ms(1000);
- void filter(void)
- vu32 sum=0; //必須初始化為0,否則初值將保持上次調(diào)用值。
- vu8 i=0,j=0;
- for(i=0;i<M;i++) //M row
- for(j=0;j<N;j++) //N line
- sum+=AD_Value[j][i];
- filterAD[i]=sum/N;
- sum=0;
- SystemInit();//72m
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //GPIOA
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); //USART
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //AFIO
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); //GPIOC
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); //ADC
- RCC_ADCCLKConfig(RCC_PCLK2_Div6); //12M 最大14M
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA傳輸
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3;//ADin: POT K3 K4
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN; //模擬輸入
- GPIO_Init(GPIOC,&GPIO_InitStructure);
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//中斷向量
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //1
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //0
- NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;//中斷向量
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //1
- USART_InitTypeDef USART_InitStructure;
- USART_InitStructure.USART_BaudRate=9600;
- USART_InitStructure.USART_WordLength=USART_WordLength_8b;
- USART_InitStructure.USART_StopBits=USART_StopBits_1;
- USART_InitStructure.USART_Parity=USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
- USART_Init(USART1,&USART_InitStructure);
- USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
- USART_Cmd(USART1,ENABLE);
- USART_ClearFlag(USART1,USART_FLAG_TC);
- ADC_InitTypeDef ADC_InitStructure;
- ADC_DeInit(ADC1); //將外設 ADC1 的全部寄存器重設為缺省值
- ADC_StructInit(&ADC_InitStructure);
- ADC_InitStructure.ADC_Mode=ADC_Mode_Independent; //ADC1 ADC2工作在獨立模式
- ADC_InitStructure.ADC_ScanConvMode=ENABLE; //工作在單通道模式(還是掃描模式:多通道模式)
- ADC_InitStructure.ADC_ContinuousConvMode=ENABLE; //模數(shù)轉(zhuǎn)換工作在單次模式(還是連續(xù)模式)
- ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//轉(zhuǎn)換由軟件而不是外部觸發(fā)啟動
- ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; //ADC數(shù)據(jù)右對齊
- ADC_InitStructure.ADC_NbrOfChannel=M; //順序進行轉(zhuǎn)換的通道數(shù)
- ADC_Init(ADC1, &ADC_InitStructure); //根據(jù)ADC_InitStruct中指定的參數(shù)初始化外設ADCx的寄存器
- //設置指定ADC的規(guī)則組通道,設置它們的轉(zhuǎn)化順序和采樣時間
- //ADC1,ADC通道x,規(guī)則采樣順序值為y,采樣時間為239.5周期
- ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_239Cycles5);//選擇ADC1通道12-PC2 KEY3
- ADC_RegularChannelConfig(ADC1,ADC_Channel_13,2,ADC_SampleTime_239Cycles5);//選擇ADC1通道13-PC3 KEY4
- // ADC_RegularChannelConfig(ADC1,ADC_Channel_10,3,ADC_SampleTime_239Cycles5);//選擇ADC1通道10-PC0 POT
- ADC_InjectedSequencerLengthConfig(ADC1,1);//設置注入組通道的轉(zhuǎn)換序列長度
- //設置指定 ADC 的注入組通道,設置它們的轉(zhuǎn)化順序和采樣時間
- ADC_InjectedChannelConfig(ADC1, ADC_Channel_10, 1,ADC_SampleTime_239Cycles5); //
- ADC_SetInjectedOffset(ADC1,ADC_InjectedChannel_1,0);
- ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None); //選擇定時器 1 的 TRGO 作為注入轉(zhuǎn)換外部觸發(fā)
- ADC_AutoInjectedConvCmd(ADC1, ENABLE); //規(guī)則組轉(zhuǎn)換完成自動轉(zhuǎn)換注入組,適合做ADC通道的擴展。
- // ADC_ExternalTrigInjectedConvCmd(ADC1,ENABLE); //使用外部觸發(fā)轉(zhuǎn)換時使能。
- // ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE); //規(guī)則組中斷使能
- ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE); //注入組中斷使能
- ADC_ClearFlag(ADC1, ADC_FLAG_JEOC); //注入組轉(zhuǎn)換結(jié)束標志位 清零 防止第一次轉(zhuǎn)換時出錯。
- ADC_DMACmd(ADC1, ENABLE); // 開啟ADC的DMA支持(要實現(xiàn)DMA功能,還需獨立配置DMA通道等參數(shù))
- ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
- ADC_ResetCalibration(ADC1); //重置校準器
- while(ADC_GetResetCalibrationStatus(ADC1)); //獲取校準狀態(tài)
- ADC_StartCalibration(ADC1); //開始指定ADC的校準狀態(tài)
- while(ADC_GetCalibrationStatus(ADC1)); //獲取指定ADC的校準程序
- ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能軟件啟動規(guī)則組轉(zhuǎn)換功能
- // ADC_SoftwareStartInjectedConvCmd(ADC1,ENABLE); //使能ADCx 軟件啟動注入組轉(zhuǎn)換功能 啟動轉(zhuǎn)換
- DMA_InitTypeDef DMA_InitStructure;
- DMA_DeInit(DMA1_Channel1); //將DMA的通道1寄存器重設為缺省值
- DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外設ADC基地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA內(nèi)存基地址
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //內(nèi)存作為數(shù)據(jù)傳輸?shù)哪康牡?外設作為數(shù)據(jù)傳輸?shù)膩碓?br />
- DMA_InitStructure.DMA_BufferSize = M*N; //DMA通道的DMA緩存的大小
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外設地址寄存器不變
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內(nèi)存地址寄存器遞增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外設數(shù)據(jù)寬度為16位
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //內(nèi)存數(shù)據(jù)寬度為16位
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循環(huán)緩存模式,當傳輸完一次后,重新接著傳送,永不停息。
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
復制代碼
完整代碼下載:
4 規(guī)則組轉(zhuǎn)換 (DMA 多通道多次采集) - 副本.7z
(191.63 KB, 下載次數(shù): 205)
2021-9-29 03:25 上傳
點擊文件名下載附件
