查看: 5252|回復(fù): 6
avr單片機(jī)m16用一個(gè)定時(shí)器實(shí)現(xiàn)一個(gè)多個(gè)電位器控制多個(gè)舵機(jī)
ID:206921 發(fā)表于 2017-6-1 23:50 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
最近在研究多個(gè)舵機(jī)的控制,上網(wǎng)找了很多資料,編寫(xiě)了一個(gè)程序,用三個(gè)電位器分別控制三個(gè)舵機(jī),只用tc0定時(shí)計(jì)數(shù)器,最后無(wú)法實(shí)現(xiàn),原理是對(duì)的,不知道哪里出了問(wèn)題,程序如下:
#include <iom16v.h>
#include <macros.h>
#include "1602LCD_drive.h"
//unsigned char line1_data[]={"ADC1:"};     //
//unsigned char line2_data[]={"ADC3:"};
//unsigned char line3_data[]={"ADC2:"};
#define  uchar unsigned char
#define  uint  unsigned int
#define OUTPUT PORTC
#define SER0 0x01
#define SER1 0x02
#define SER2 0x04
#define ADCN ADMUX
#define ADC0 0x40
#define ADC1 0x41
#define ADC2 0x42
char Counter=1;
char num=0;
char time=0;
/************延時(shí)函數(shù)***********/
void delay(unsigned int ms)
        unsigned int i,j;
        for(i=0;i<ms;i++)
           for(j=0;j<1141;j++);
/*********端口設(shè)置函數(shù)*********/
void port_init(void)
     PORTB=0XFF;                        //設(shè)置1602端口的
     DDRB=0XFF;
    DDRD=0XFF;
    PORTD=0Xff;
    DDRC=0XFF;               //設(shè)置pc口為舵機(jī)pwm輸出
    PORTC|=0X00;
    DDRA&=0X00;                     //adc口設(shè)為輸入,帶上啦電阻
    PORTA|=0Xff;
void timer0_init()
        SREG=0X80;
        TIMSK|=(1<<TOIE0);                //是能溢出中斷
        TCCR0|=(0<<CS02)|(0<<CS01)|(1<<CS00); //12mhz晶振  無(wú)預(yù)分頻60/12m=5us
        TCNT0=0;                          //計(jì)數(shù)器初值
/**********ad轉(zhuǎn)換函數(shù)**********/
unsigned int adc_()
         unsigned int addata;
         ADMUX=0X40;                                          //AVCC為基準(zhǔn)電,AD0為輸入通道 01000010
         ADCSRA=0XC0;                                         //使能ADC,自動(dòng)連續(xù)轉(zhuǎn)換 11000000
         ADCSRA|=BIT(ADSC);                                //開(kāi)始A/D轉(zhuǎn)換
         while(!(ADCSRA&(BIT(ADIF))));        //等待轉(zhuǎn)換完成
         addata=ADCL;                                //獲取ADC結(jié)果
         addata=addata+ADCH*256;
         return addata;                        //返回ADC值
/**ADC通道轉(zhuǎn)換函數(shù)**/
uint adc_change()
     unsigned int ada, adcx;
         ada=adc_();
         adcx=ada/2.5+100;
         return adcx;
/********************主函數(shù)**********************/
        port_init();
        adc_();
        timer0_init();
        adc_change();
#pragma interrupt_handler timer0_ovf:10
void timer0_ovf()
         TCNT0=196;            //重新賦值256-196=60,溢出一次等于5us
         adc_change();           //adc值轉(zhuǎn)換成counter計(jì)數(shù)值最大值
     Counter++;
         time++;
         if(num==0&&Counter<=1)          //這里
             ADCN=ADC0;                                 //設(shè)置adc通道為adc0
             OUTPUT|=SER0;                                  //輸出口為PC0
                 //k[0]=adc_change()/100;
             //k[1]=(adc_change()%100)/10;
             //LCD_write_char(14,1,k[0]+0x30);
             //LCD_write_char(15,1,k[1]+0x30);
         if(num==1&&Counter<=1)
             ADCN=ADC1;                 //adc通道為adc1
             OUTPUT|=SER1;           //修改輸出口為pc1
             //LCD_write_char(5,1,k[0]+0x30);
             //LCD_write_char(6,1,k[1]+0x30);
if(num==2&&Counter<=1)
             ADCN=ADC2;           //adc通道為adc2
             OUTPUT|=SER2;            //輸出口為pc2
if(Counter>=adc_change())          //如果計(jì)數(shù)值大于adc轉(zhuǎn)換值
                 OUTPUT&=0X00;                   //所有輸出口拉低
                 num=num+1;                     //num+1
                 Counter=0;                      //重新計(jì)數(shù)
                  if(num>=3)                       //num大于三所有c口拉低
                 OUTPUT&=0X00;
         if(time>=4000)                //計(jì)數(shù)達(dá)到4000?4000*5us=20000us=20ms為舵機(jī)周期
                 num=0;                     //全部重新賦值
                 time=0;
                  Counter=0;
小白一個(gè),求大神指教!
相關(guān)帖子
ID:207004 發(fā)表于 2017-6-2 10:49 | 只看該作者
你可以用pmw波控制舵機(jī)
參與人數(shù) 1黑幣 +20 收起 理由
ID:207029 發(fā)表于 2017-6-2 11:44 | 只看該作者
你的問(wèn)題很籠統(tǒng)!具體怎么無(wú)法實(shí)現(xiàn)?有哪些錯(cuò)誤?體現(xiàn)在哪里?原理圖可否曬出來(lái),否則怎么幫助你?單片機(jī)這個(gè)東西定制性很強(qiáng),你單單拿出個(gè)程序我想神仙也幫不了你!
ID:206921 發(fā)表于 2017-6-2 13:07 | 只看該作者
jlqiu 發(fā)表于 2017-6-2 10:50
你可以用pmw波控制舵機(jī)
那個(gè)我會(huì),現(xiàn)在要實(shí)現(xiàn)的是多個(gè)電位器分別控制多個(gè)舵機(jī),采用的是模擬pwm波形,而不是用定時(shí)器的快速pwm
ID:206921 發(fā)表于 2017-6-2 14:05 | 只看該作者
zt2017 發(fā)表于 2017-6-2 11:44
你的問(wèn)題很籠統(tǒng)!具體怎么無(wú)法實(shí)現(xiàn)?有哪些錯(cuò)誤?體現(xiàn)在哪里?原理圖可否曬出來(lái),否則怎么幫助你?單片機(jī)這 ...
你說(shuō)的對(duì),具體如下
m16芯片,12mhz晶振,電位器3個(gè),舵機(jī)三個(gè),
單片機(jī)的PA0~PA2口作為ADC輸入通道,分別接三個(gè)電位器,采用單端接入法,
PC0~PC2為舵機(jī)信號(hào)輸出腳,分別鏈接三個(gè)舵機(jī)的信號(hào)線
程序思路是這樣
設(shè)置定時(shí)器溢出中斷,使能ADC轉(zhuǎn)換,把得到的ADC值0~1000,通過(guò)adc_change()函數(shù)轉(zhuǎn)化成100~500,100*5us=0.5ms,500*5us=2.5ms,就是一個(gè)舵機(jī)的脈沖周期,
例如第一次轉(zhuǎn)換是ADC0,舵機(jī)通道SER0(pc0)電平拉高,得到的adc_change()的值為200(相當(dāng)于脈沖周期200*5us=1ms),賦給Counter,定時(shí)器TCNT0初值為196,經(jīng)過(guò)200次溢出,Counter的值達(dá)到200,
執(zhí)行Counter清零,ADCN(ADC輸入通道選擇)重新賦值為ADC1,舵機(jī)通道SER1(pc1)拉高,
此時(shí)讀取ADC1的值,賦給Counter,再執(zhí)行如上指令,直到第三通道的舵機(jī)脈沖完成,num大于3,所有pc口拉低
程序中每次計(jì)數(shù)器溢出,time+1,溢出4000次(4000*5us=20ms),為一個(gè)舵機(jī)控制周期,超過(guò)4000,次,time,Counter等清0,重新計(jì)數(shù)。
程序最后測(cè)試結(jié)果為,pc0端口保持高點(diǎn)平,pc1,pc2保持低電平,舵機(jī)就沒(méi)反應(yīng),電位器都檢查了,電路連接良好?赡苁浅绦虺鲥e(cuò)。
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎(jiǎng)勵(lì)!
ID:207004 發(fā)表于 2017-6-5 15:52 | 只看該作者
HYH520 發(fā)表于 2017-6-2 13:07
用仿真軟件調(diào)試過(guò)嗎?輸出方波符合舵機(jī)波形嗎?
ID:206921 發(fā)表于 2017-6-12 12:26 | 只看該作者
已實(shí)現(xiàn)八個(gè)電位器分別同時(shí)控制八個(gè)舵機(jī),請(qǐng)看新帖
