查看: 3874|回復(fù): 1
IIC-24C04與蜂鳴器的單片機(jī)仿真圖與程序
蜂鳴器。。有用的
仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. #define NOP4() {_nop_();_nop_();_nop_();_nop_();}
  6. sbit SCL = P1^0;
  7. sbit SDA = P1^1;
  8. sbit SPK = P3^0;
  9. uchar code HI_LIST[] =
  10. {
  11.         0,226,229,232,233,236,238,240,241,242,245,246,247,248
  12. };
  13. uchar code LO_LIST[] =
  14. {
  15.         0,4,13,10,20,3,8,6,2,23,5,26,1,4,3
  16. };
  17. uchar code Song_24C04[] =
  18. {
  19.         1,2,3,1,1,2,3,1,3,4,5,3,4,5
  20. };
  21. uchar sidx;
  22. void DelayMS(uint x)
  23. {
  24.         uchar t;
  25.         while(x--)
  26.         {
  27.                  for(t=120;t>0;t--);
  28.         }
  29. }
  30. void Start()
  31. {
  32.         SDA=1;SCL=1;NOP4();SDA=0;NOP4();SCL=0;
  33. }
  34. void Stop()
  35. {
  36.         SDA=0;SCL=0;NOP4();SCL=1;NOP4();SDA=1;
  37. }
  38. void RACK()
  39. {
  40.         SDA=1;NOP4();SCL=1;NOP4();SCL=0;
  41. }
  42. void NO_ACK()
  43. {
  44.         SDA=1;SCL=1;NOP4();SCL=0;SDA=0;
  45. }
  46. void Write_A_Byte(uchar b)
  47. {
  48.         uchar i;
  49.         for(i=0;i<8;i++)
  50.         {
  51.                  b<<=1;SDA=CY;_nop_();SCL=1;NOP4();SCL=0;
  52.         }
  53.         RACK();
  54. }
  55. void Write_IIC(uchar addr,uchar dat)
  56. {
  57.         Start();
  58.         Write_A_Byte(0xa0);
  59.         Write_A_Byte(addr);
  60.         Write_A_Byte(dat);
  61.         Stop();
  62.         DelayMS(10);
  63. }
  64. uchar Read_A_Byte()
  65. {
  66.         uchar i,b;
  67.         for(i=0;i<8;i++)
  68.         {
  69.                  SCL=1;b<<=1;B|=SDA;SCL=0;
  70.         }
  71.         return b;
  72. }
  73. uchar Read_Current()
  74. {
  75.         uchar d;
  76.         Start();
  77.         Write_A_Byte(0xa1);
  78.         d=Read_A_Byte();
  79.         NO_ACK();
  80.         Stop();
  81.         return d;
  82. }
  83. uchar Random_Read(uchar addr)
  84. {
  85.         Start();
  86.         Write_A_Byte(0xa0);
  87.         Write_A_Byte(addr);
  88.         Stop();
  89.         return Read_Current();
  90. }
  91. void T0_INT() interrupt 1
  92. {
  93.         SPK=!SPK;
  94.         TH0=HI_LIST[sidx];
  95.         TL0=LO_LIST[sidx];
  96. }
  97. void main()
  98. {
  99.         uchar i;
  100. ……………………
  101. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
05 IIC-24C04與蜂鳴器.zip (36.1 KB, 下載次數(shù): 25)
相關(guān)帖子
ID:566128 發(fā)表于 2019-8-9 20:32 | 只看該作者
程序出不了效果哎
