查看: 3535|回復(fù): 0
【已經(jīng)解決,謝謝】CC2530 uart0 DMA通道1數(shù)據(jù)傳輸問(wèn)題,200元酬謝
ID:210688 發(fā)表于 2017-6-13 10:29 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 sihhepl 于 2017-6-19 22:17 編輯
200元酬謝,請(qǐng)各位大俠幫我調(diào)下程序,謝謝啦!我的QQ:79422195,請(qǐng)標(biāo)注“51黑DMA”
我使用cc2530的DMA channel 1將接收到的串口(uart0)數(shù)據(jù)存儲(chǔ)在uartRxBuf內(nèi),程序如下。在中斷函數(shù)中,根據(jù)DMAIRQ的DMAIF1位是否置1來(lái)判斷是否傳輸完成DATA_COUNT字節(jié)的數(shù)據(jù)。如果DATA_COUNT為1,則程序沒(méi)有問(wèn)題,接收數(shù)據(jù)正常,如果DATA_COUNT大于1,則程序不能產(chǎn)生中斷。請(qǐng)各位大俠幫我看下程序,謝謝啦!
#define HAL_URX0_DMA_CH        1
#define DATA_COUNT              10
uint8 uartRxBuf[15] = {0};
void HalDma_uart( void )
    halDMADesc_t *ch;
    ch = HAL_DMA_GET_DESC1234(HAL_URX0_DMA_CH)
    ch->srcAddrH = HI_UINT16(&X_U0DBUF);
    ch->srcAddrL = LO_UINT16(&X_U0DBUF);
    ch->dstAddrH = HI_UINT16(uartRxBuf);
    ch->dstAddrL = LO_UINT16(uartRxBuf);
    ch->vLen     = 0x00;// Use fixed length DMA transfercount
    ch->lenH     = HI_UINT16(DATA_COUNT);
    ch->lenL     = LO_UINT16(DATA_COUNT);
    ch->wordSize =HAL_DMA_WORDSIZE_BYTE;// Perform 1-byte transfers
    ch->tMode   =HAL_DMA_TMODE_SINGLE;// Single byte transfer per DMA trigger
    ch->trig     = HAL_DMA_TRIG_URX0;// DMA trigger =USARTx RX complete
    ch->srcInc   = HAL_DMA_SRCINC_0;// Do not incrementsource pointer, points to USART U0BUF register.
    ch->destInc  = HAL_DMA_DSTINC_1;// Increment destinationpointer by 1 byte address after each transfer.
    ch->irqMask  = HAL_DMA_IRQMASK_DISABLE;// Enable DMAinterrupt to the CPU
    ch->m8       = HAL_DMA_M8_USE_8_BITS;// Use all 8bits for transfer count
    ch->priority =HAL_DMA_PRI_HIGH;// DMA memory access has low priority
     /* The DMAconfiguration data structure may reside at any location in
     * unified memoryspace, and the address location is passed to the DMA
     * through DMA1CFGH:DMA1CFGL.
            HAL_DMA_CLEAR_IRQ(HAL_URX0_DMA_CH);
            HAL_DMA_SET_ADDR_DESC1234( ch );
    HAL_DMA_ARM_CH(HAL_URX0_DMA_CH); // Arm DMAchannel 1
    //apply 45 NOP's forloading DMA configuration
    asm("NOP");asm("NOP");//45clk periods
    //Enable the DMAinterrupt (IEN1.DMAIE = IEN0.EA = 1),
    //and clear potentialpending DMA interrupt requests (IRCON.DMAIF = 0)
    IEN0 |= 0x80;
    IEN1 |= 0x01;
    IRCON &= ~0x02;
    // Enable UARTx RX
    U0CSR |= 0x40;
相關(guān)帖子
