#include <reg52.H>//器件配置文件
#include <intrins.h>
//傳感器接口
sbit RX = P3^2;
sbit TX = P3^3;
//按鍵聲明
sbit S1 = P1^4;
sbit S2 = P1^5;
sbit S3 = P1^6;
//蜂鳴器
sbit Feng= P2^0;
sbit W1=P1^0;
sbit W2=P1^1;
sbit W3=P1^2;
sbit W4=P1^3;
//變量聲明
unsigned int time=0;
unsigned int timer=0;
unsigned char posit=0;
unsigned long S=0;
unsigned long BJS=50;//報警距離80CM
//模式 0正常模式 1調(diào)整
char Mode=0;
bit flag=0;
bit flag_KEY=0;
unsigned char const discode[] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0xff/*-*/}; //數(shù)碼管顯示碼0123456789-和不顯示
//unsigned char const positon[4]={0xfd,0xfb,0xf7,0xfe}; //位選
unsigned char disbuff[4] ={0,0,0,0}; //數(shù)組用于存放距離信息
unsigned char disbuff_BJ[4] ={0,0,0,0};//報警信息
void Display();
//延時20ms(不精確)
void delay(void)
unsigned char a,b,c;
for(c=2;c>0;c--)
for(b=38;b>0;b--)
for(a=60;a>0;a--);
//按鍵掃描
void Key_()
if(flag_KEY==0)
if(Mode!=0)
if(S1==0)
delay(); //延時去抖
if(S1==0)
BJS++; //報警值加
flag_KEY=1;
if(BJS>=151) //最大151
BJS=0;
// while(S1==0)
// Display();
if(S2==0)
delay();
if(S2==0)
BJS--; //報警值減
flag_KEY=1;
if(BJS<=1) //最小1
BJS=150;
// while(S2==0)
// Display();
//功能
if(S3==0) //設(shè)置鍵
delay();
if(S3==0)
Mode++; //模式加
flag_KEY=1;
if(Mode>=2) //加到2時清零
Mode=0;
// while(S3==0)
// Display();
if((P1&0x70)==0x70)
flag_KEY=0;
//掃描數(shù)碼管
void Display(void)
//正常顯示
if(Mode==0)
P0=0x00; //關(guān)閉顯示
if(posit==1)//數(shù)碼管的小數(shù)點
P0=(discode[disbuff[posit]])|0x80;//按位或,最高位變?yōu)?,顯示小數(shù)點
else if(posit==0)
P0=~discode[11];
P0=discode[disbuff[posit]];
switch(posit)
case 0 : W1=0;W2=1;W3=1;W4=1; break;
case 1 : W1=1;W2=0;W3=1;W4=1; break;
case 2 : W1=1;W2=1;W3=0;W4=1; break;
case 3 : W1=1;W2=1;W3=1;W4=0; break;
posit++;
if(posit>3) //每進一次顯示函數(shù),變量加1
posit=0; //加到3時清零
//報警顯示
P0=0x00;
P0=(discode[disbuff_BJ[posit]])|0x80;
else if(posit==0)
P0=0x76; //顯示字母
P0=discode[disbuff_BJ[posit]];
switch(posit)
posit++;
if(posit>3)
posit=0;
//計算
void Conut(void)
time=TH0*256+TL0; //讀出T0的計時數(shù)值
TH0=0;
TL0=0; //清空計時器
S=(time*1.7)/100; //算出來是CM
//聲音的速度是340m/s,時間的單位是us,計算到秒需要將時間數(shù)據(jù)/1000000,
//長度=速度*時間,340*time/1000000,長度數(shù)據(jù)單位是m轉(zhuǎn)換成cm需要乘以100得到340*time/10000,
//小數(shù)點都向左移兩位得到3.4*time/100,因為超聲波是往返了,所以再除以2,得到距離數(shù)據(jù)(time*1.7)/100
if(Mode==0) //非設(shè)置狀態(tài)時
if((S>=700)||flag==1) //超出測量范圍顯示“-”
Feng=0; //蜂鳴器報警
flag=0;
disbuff[1]=10; //“-”
disbuff[2]=10; //“-”
disbuff[3]=10; //“-”
//距離小于報警距
if(S<=BJS)
Feng=0; //報警
else //大于
Feng=1; //關(guān)閉報警
disbuff[1]=S%1000/100; //將距離數(shù)據(jù)拆成單個位賦值
disbuff[2]=S%1000%100/10;
disbuff[3]=S%1000%10 %10;
Feng=1;
disbuff_BJ[1]=BJS%1000/100;
disbuff_BJ[2]=BJS%1000%100/10;
disbuff_BJ[3]=BJS%1000%10 %10;
//定時器0
void zd0() interrupt 1 //T0中斷用來計數(shù)器溢出,超過測距范圍
flag=1; //中斷溢出標(biāo)志
//定時器1
void zd3() interrupt 3 //T1中斷用來掃描數(shù)碼管和計800MS啟動模塊
TH1=0xf8;
TL1=0x30; //定時2ms
Key_(); //掃描按鍵
Display(); //掃描顯示
timer++; //變量加
if(timer>=400) //400次就是800ms
timer=0;
TX=1; //800MS 啟動一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
//主函數(shù)
void main(void)
TMOD=0x11; //設(shè)T0為方式1
TH0=0;
TL0=0;
TH1=0xf8; //2MS定時
TL1=0x30;
ET0=1; //允許T0中斷
ET1=1; //允許T1中斷
TR1=1; //開啟定時器
EA=1; //開啟總中斷
while(!RX); //當(dāng)上次接收完波后,RX引腳是低電平,取反就是1,此while成立,反復(fù)判斷RX狀態(tài)。當(dāng)RX沒有接收到返回波時是高電平,取反就是0,此while不成立,跳出
TR0=1; //開啟計數(shù)
while(RX); //當(dāng)RX沒有接收到返回波,此while成立,程序停在這里一直判斷RX狀態(tài)。當(dāng)RX接收到返回波,RX引腳變?yōu)榈碗娖,此while不成立,跳出
TR0=0; //停止計數(shù)
Conut(); //計算
原理圖.pdf
2017-6-20 21:55 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
61.73 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
原理圖
原理圖.doc
2017-6-20 21:54 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
104 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
原理圖
