當(dāng)前位置:單片機(jī)教程網(wǎng) >> STM32 >> 瀏覽文章
基于stm32rbt6 頭文件f10x.h串口中斷例程
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年04月25日   【字體:
 希望一次就可以調(diào)通。
代碼如下
頭文件
#include "stm32f10x.h"
#include "stm32_eval.h"
#include "stm32f10x_it.h"
#include
void RCC_Configuration(void);
void NVIC_Configuration(void);
void USART_Config(void);
unsigned char USART1_ReceiveChar(void);//接收一個字符
char tmpvv=0;
char rbuff[100];
配置函數(shù)
ErrorStatus HSEStartUpStatus;
    RCC_ClocksTypeDef RccClocks;
  RCC_DeInit();
  RCC_HSEConfig(RCC_HSE_ON);
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    RCC_PCLK2Config(RCC_HCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div2);
    FLASH_SetLatency(FLASH_Latency_2);
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08);
    RCC_GetClocksFreq(&RccClocks);
     GPIO_InitTypeDef GPIO_InitStructure; //io口初始化聲明
     USART_InitTypeDef USART_InitStructure; //串口初始化聲明
USART_ClockInitTypeDef  USART_ClockInitStructure;    //定義USART時鐘初始化結(jié)構(gòu)體聲明
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING;
//包括所有串口的配置
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
//提升USART時鐘時使能還是失能,鐘低電平活動
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
//指定SLCK引腳上時鐘的極性
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
//時鐘第二個邊緣進(jìn)行數(shù)據(jù)捕獲
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
//在SCLK引腳上輸出最后發(fā)送的那個數(shù)據(jù)字的脈沖不從SCLK輸出
USART_ClockInit(USART1, &USART_ClockInitStructure);
    //USART工作在異步模式下 包括所有串口
    USART_InitStructure.USART_BaudRate = 9600;//波特率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//數(shù)據(jù)位數(shù)
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
    USART_InitStructure.USART_Parity = USART_Parity_No ;//無奇偶校驗位
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件控制流
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//發(fā)送接收均使能
    USART_Init(USART1, &USART_InitStructure);//初始化串口1  可以在這打開串口2
    USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);//打開串口1的接收中斷
   // USART_ITConfig(USART1,USART_IT_TXE,ENABLE);  //打開串口1的發(fā)送中斷
    USART_Cmd(USART1, ENABLE); //打開串口1中斷
uint8_t uart_putchar(uint8_t ch)
            USART_SendData(USART1, (uint8_t) ch);
            while (!(USART1->SR & USART_FLAG_TXE));
 uint32_t uart_send( uint8_t *pdata, uint16_t length)
while(length--)
        uart_putchar(*pdata++);
return length;
NVIC_InitTypeDef  NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
NVIC_SetVectorTable(NVIC_VectTab_FLASH+ 0x4000 , 0x4000);
#endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//配置優(yōu)先級組為第1組(搶占式優(yōu)先級有1位,副優(yōu)先級有3位)
//配置USART中斷
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//中斷通道為RTC全局中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;//搶占優(yōu)先級為1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;//副優(yōu)先級為0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//中斷通道使能
NVIC_Init(&NVIC_InitStructure);//初始化NVIC結(jié)構(gòu)?
main函數(shù)如下
int main(void)
 uint16_t uid[]={0};
  RCC_Configuration();
  NVIC_Configuration();
  USART_Config();
  while (1)
  // uart_send(rbuff,5);
中斷函數(shù)在it.c中添加
extern void USART1_Putc(char c);//輸出一個字符
extern unsigned char USART1_ReceiveChar(void);//接收一個字符
extern char rbuff[100];
extern char tmpvv;
void USART1_IRQHandler(void)
  if ( USART_GetITStatus(USART1, USART_IT_RXNE)!= RESET)//查詢是否為秒中斷標(biāo)志
    char i=0,j;
    char t=0x00;
USART_ClearITPendingBit(USART1,USART_IT_RXNE); //清中斷標(biāo)識
     tmpvv= USART_ReceiveData(USART1);
USART_SendData(USART1,t);
  // USART_SendData(USART1,tmp );
//  rbuff[i++] = USART_ReceiveData(USART1);  //全局變量
