當(dāng)前位置:單片機(jī)教程網(wǎng) >> STM32 >> 瀏覽文章
用STM32定時(shí)器控制步進(jìn)電機(jī)實(shí)現(xiàn)頻率任意調(diào)節(jié)
作者:堯   來源:堯的隨筆博客   點(diǎn)擊數(shù):  更新時(shí)間:2014年05月18日   【字體:
//定時(shí)器1初始化 可調(diào)節(jié)頻率/////////
//輸入?yún)?shù)PWM1_Val掌控頻率參數(shù)//
void TIM1_PWM(unsigned int PWM1_Val)
vu16 tim1_Val = PWM1_Val;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_TIM1 , ENABLE); //RCC_APB2Periph_AFIO
TIM_TimeBaseStructure.TIM_Period = tim1_Val;//TIM_Period=65535,計(jì)數(shù)器向上計(jì)數(shù)到65535后產(chǎn)生更新事件,計(jì)數(shù)值歸零
TIM_TimeBaseStructure.TIM_Prescaler = 2; //設(shè)置預(yù)分頻器分頻系數(shù)0
TIM_TimeBaseStructure.TIM_ClockDivision = 0;//設(shè)置了時(shí)鐘分割
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//選擇向上計(jì)數(shù)
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);//根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2 ;//定時(shí)模式
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//輸出使能
//TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//TIM輸出比較極性
//TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//TIM輸出比較極性
//TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
//TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
TIM_OCInitStructure.TIM_Pulse = tim1_Val*0.5;//比較數(shù)
TIM_OC1Init(TIM1, &TIM_OCInitStructure);//初始化定時(shí)1
//TIM_OC1PreloadConfig(TIM1, ENABLE);//使能或者失能TIMx在ARR上的自動(dòng)裝載寄存器
TIM_OC2Init(TIM1, &TIM_OCInitStructure);//初始化定時(shí)1
//TIM_OC2PreloadConfig(TIM1, ENABLE);//使能或者失能TIMx在ARR上的自動(dòng)裝載寄存器
TIM_OC3Init(TIM1, &TIM_OCInitStructure);//初始化定時(shí)1
//TIM_OC3PreloadConfig(TIM1, ENABLE);//使能或者失能TIMx在ARR上的自動(dòng)裝載寄存器
TIM_OC4Init(TIM1, &TIM_OCInitStructure);//初始化定時(shí)1
//TIM_OC4PreloadConfig(TIM1, ENABLE);//使能或者失能TIMx在ARR上的自動(dòng)裝載寄存器
TIM_Cmd(TIM1, ENABLE);//使能定時(shí)器
TIM_CtrlPWMOutputs(TIM1,ENABLE);
這個(gè)已經(jīng)在項(xiàng)目中使用而且效果很好,雖然比較簡(jiǎn)單但是很實(shí)用,對(duì)于做一般項(xiàng)目基本上都能達(dá)到控制的要求。
控制的實(shí)質(zhì)是用高級(jí)定時(shí)器TIM1輸出50%的可調(diào)PWM,實(shí)現(xiàn)通斷電的轉(zhuǎn)換實(shí)現(xiàn)步進(jìn)電機(jī)的控制,最近時(shí)間好緊,沒有時(shí)間去把這個(gè)好好的整理,等這段時(shí)間過去了 ,一定要好好的把這里整理下。
