查看: 5497|回復(fù): 2
STM32控制PCA9685程序源碼
ID:278905 發(fā)表于 2018-1-23 13:56 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
PCA9685 在stm32下的程序設(shè)計(jì)
  1. #include "pca9685.h"
  2. #include "pca9685_reg.h"    /* Light Driver Chip */
  3. #include "bsp_i2c_gpio.h"
  4. #define MAX_OUTPUT_INDEX        15
  5. #define MAX_OUTPUT_VALUE        0xFFF
  6. /******************************************/
  7. /*                                        */
  8. /*   Probe the I2C bus, and show the      */
  9. /*   user what we have found              */
  10. /*                                        */
  11. /*                                        */
  12. /*                                        */
  13. /******************************************/
  14. /******************************************/
  15. /*                                        */
  16. /* Philips PCA9685 I2C Driver, 16 channel */
  17. /* Lighting controler chip                */
  18. /*                                        */
  19. /*                                        */
  20. /******************************************/
  21. /******************************************/
  22. /*                                        */
  23. /* Init code for the PCA9685              */
  24. /*                                        */
  25. /******************************************/
  26. void init_pca9685(unsigned char address)
  27. {
  28.     unsigned char buf[30];
  29.
  30.     printf("Setting up channel %d\n\r",address);
  31.
  32.     buf[0] = PCA9685_MODE1;
  33.     buf[1] = PCA9685_AI;
  34.    // buf[2] = PCA9685_OUTDRV;
  35.     buf[2] = PCA9685_INVRT;
  36.     i2c_WriteBuffer(address,(char *) buf, 3);
  37. }
  38. /******************************************/
  39. /*                                        */
  40. /* Send data to a given channel of a      */
  41. /* given PCA9685 chip                     */
  42. /*                                        */
  43. /******************************************/
  44. void pca9685_led(unsigned char addr, int led, unsigned char *values)
  45. {
  46.     unsigned char buf[5];
  47.
  48.     if (led == PCA9685_ALL_LEDS) {
  49.         buf[0] = PCA9685_ALL_LED_ON_L;
  50.     } else {
  51.         buf[0] = PCA9685_BASE(led);
  52.     }
  53.     buf[1] = values[0];
  54.     buf[2] = values[1];
  55.     buf[3] = values[2];
  56.     buf[4] = values[3];
  57.     i2c_WriteBuffer(addr, (char *)buf, 5);
  58. }
  59. /******************************************/
  60. /*                                        */
  61. /* Send all the data to a single rgba led */
  62. /* at once to the PCA9685 chip            */
  63. /*                                        */
  64. /*                                        */
  65. /*                                        */
  66. /* color[0] = red (0-255)                 */
  67. /* color[1] = green (0-255)               */
  68. /* color[2] = blue (0-255)                */
  69. /* color[3] = amber (0-100%)              */
  70. /* total brightness = level (0-100%)      */
  71. /******************************************/
  72. void pca9685_rgba_led(unsigned char addr, int rgba_led, unsigned char *color, unsigned char level)
  73. {
  74.     int led;
  75.     unsigned int on, off;
  76.     unsigned char buf[17];
  77.
  78.     if (level > 100){
  79.         //printf("Level percentage range 0 - 100 (Trying for %d)\n\r",level);
  80.         return;
  81.         }
  82.     if (color[3] > 100) {
  83.         //printf("Amber percentage range 0 - 100 (Trying for %d)\n\r",color[3]);
  84.         return;
  85.         }
  86.     on=0;
  87.     if (rgba_led == PCA9685_ALL_LEDS) {
  88.         buf[0] = PCA9685_ALL_LED_ON_L;
  89.         if (color[0]==0 || level==0){
  90.             buf[1]=0;
  91.             buf[1+PCA9685_LED_ON_H] = 0;//buf[2]
  92.             buf[3]=0;
  93.             buf[1+PCA9685_LED_OFF_H] = PCA9685_LED_OFF;//buf[4]
  94.             //printf("all on, zero brightness\r\n");
  95.         }
  96.         else if (color[0]==0xff && level==100){
  97.             buf[1]=0;
  98.             buf[1+PCA9685_LED_ON_H] = PCA9685_LED_ON;//buf[2]
  99.             buf[3]=0;
  100.             buf[1+PCA9685_LED_OFF_H] = 0;//buf[4]
  101.             //printf("all on, full brightness\r\n");
  102.         }
  103.         else{
  104.             off = (4096 * color[0]*level) / 0xff / 100;
  105.             buf[1+PCA9685_LED_ON_L] = on & 0xff;//buf[1]
  106.             buf[1+PCA9685_LED_ON_H] = (on >> 8) & 0xf;//buf[2]
  107.             buf[1+PCA9685_LED_OFF_L] = off & 0xff;//buf[3]
  108.             buf[1+PCA9685_LED_OFF_H] = (off >> 8) & 0xf;//buf[4]
  109.         }
  110.         i2c_WriteBuffer(addr, (char *)buf, 5);
  111.         //printf("All leds on\r\n");
  112.         return;
  113.     } else {
  114.         buf[0] = PCA9685_BASE(rgba_led);
  115.     }
  116.     for (led=0;led<=3;led++){
  117.         if (color[led]==0 || level==0){
  118.         buf[led*4+1+PCA9685_LED_ON_H] = 0;
  119.         buf[led*4+1+PCA9685_LED_OFF_H] = PCA9685_LED_OFF;
  120.         continue;
  121.         }
  122.         if (((color[led]==100 && led==3)|| color[led]==0xff)&& level==100) {
  123.         buf[led*4+1+PCA9685_LED_ON_H] = PCA9685_LED_ON;
  124.         buf[led*4+1+PCA9685_LED_OFF_H] = 0;
  125.         continue;
  126.         }
  127.         off = (4096 * color[led]*level) / 0xff / 100;
  128.         buf[led*4+1+PCA9685_LED_ON_L] = on & 0xff;
  129.         buf[led*4+1+PCA9685_LED_ON_H] = (on >> 8) & 0xf;
  130.         buf[led*4+1+PCA9685_LED_OFF_L] = off & 0xff;
  131.         buf[led*4+1+PCA9685_LED_OFF_H] = (off >> 8) & 0xf;
  132.     }
  133.     i2c_WriteBuffer(addr, (char *)buf, 17);
  134. }
  135. /******************************************/
  136. /*                                        */
  137. /* Calculate the register values for a    */
  138. /* given brightness percentage            */
  139. /*                                        */
  140. /******************************************/
  141. void pca9685_brightness(int percent, unsigned char *values)
  142. {
  143.     unsigned int on, off;
  144.     if (percent == 0) {
  145.     values[PCA9685_LED_ON_H] = 0;
  146.     values[PCA9685_LED_OFF_H] = PCA9685_LED_OFF;
  147.     return;
  148.     }
  149.     if (percent == 100) {
  150.     values[PCA9685_LED_ON_H] = PCA9685_LED_ON;
  151.     values[PCA9685_LED_OFF_H] = 0;
  152.     return;
  153.     }
  154.     on = 0;
  155.     off = (4096 * percent) / 100;
  156.     values[PCA9685_LED_ON_L] = on & 0xff;//0
  157.     values[PCA9685_LED_ON_H] = (on >> 8) & 0xf;//1
  158.     values[PCA9685_LED_OFF_L] = off & 0xff;//2
  159.     values[PCA9685_LED_OFF_H] = (off >> 8) & 0xf;//3
  160. }
  161. /******************************************/
  162. /*                                        */
  163. /* Set a given channel to a given level   */
  164. /*                                        */
  165. /******************************************/
  166. void channel_light(unsigned char ch, unsigned char lev)
  167. {
  168.     char            chip,led;     /* Chip Number, channel number */
  169.     unsigned char   v[4];         /* register data for givern level */
  170.
  171.     led = ch%16;
  172.     v[0]=0;
  173.     v[1]=0;
  174.     v[2]=0;
  175.     v[3]=0;
  176.
  177.     if(lev > 100){
  178.         printf("Level percentage range 0 - 100 (Trying for %d)\n\r",lev);
  179.         return;
  180.     }
  181.
  182.     switch(ch/16){
  183.         case    0    :
  184.             chip=LEDDRV1;
  185.             break;
  186.         case    1    :
  187.             chip=LEDDRV2;
  188.             break;
  189.         case    2    :
  190.             chip=LEDDRV3;
  191.             break;
  192.         case    3    :
  193.             chip=LEDDRV4;
  194.             break;
  195.         case    4    :
  196.             chip=LEDDRV5;
  197.             break;
  198.         case    5    :
  199.             chip=LEDDRV6;
  200.             break;
  201.         default      :
  202.             printf("Error unknown chip %d\n\r",ch/16);
  203.             return;
  204.     }
  205.
  206.     printf("Setting channel %d to brightness level %d chip = %d(%d),%d\n\r",
  207.         ch,lev,chip,ch/16,led);
  208.     pca9685_brightness(lev,v);    /* Calculate the brightness level */
  209.     printf("Brightness level is %02x,%02x,%02x,%02x\n\r",v[0],v[1],v[2],v[3]);
  210.     pca9685_led(chip,led,v);      /* Send to chip */
  211. }
  212. void PCA9685_SetOutput(uint8_t Address, uint8_t Output, uint16_t OnValue, uint16_t OffValue)
  213. {
  214.
  215.         // Optional: PCA9685_I2C_SlaveAtAddress(Address), might make things slower
  216.         if (Output <= MAX_OUTPUT_INDEX && OnValue <= MAX_OUTPUT_VALUE && OffValue <= MAX_OUTPUT_VALUE)
  217.         {
  218.            uint8_t temp[4];
  219.                  temp[0]=OnValue & 0xFF;
  220.                  temp[1]=(OnValue >> 8) & 0xF;
  221.                  temp[2]=OffValue & 0xFF;
  222.                  temp[3]=(OffValue >> 8) & 0xF;
  223.                  i2c_ReadBuffer(Address,LEDn_ON_L(Output),4,temp);
  224.         }
  225. }
  1.   #include "stm32f10x.h"
  2. #include "bsp_usart1.h"
  3. #include "bsp_i2c_ee.h"
  4. #include "bsp_i2c_gpio.h"
  5. #include "pca9685_reg.h"
  6. #include "pca9685.h"
  7. #define address 0x94//pca9685 i2c器件地址,需要硬件上設(shè)置
  8. /**
  9.   * @brief  主函數(shù)
  10.   * @param  無(wú)
  11.   * @retval 無(wú)
  12.   */
  13. int main(void)
  14. {
  15.         /* USART1 config 115200 8-N-1 */
  16.         unsigned char date[4];
  17.         unsigned char rx[4],buf,i;
  18.         unsigned int delay;
  19.         USART1_Config();
  20.         // i2c_probe();//搜索iic器件id
  21.
  22.   init_pca9685(address);
  23.
  24.
  25.         pca9685_brightness(100,date);//把轉(zhuǎn)空比為100%的數(shù)據(jù)填入date
  26.         pca9685_led(address,14,date);//把占空比為100%的數(shù)據(jù)寫入pca9685控制14號(hào)燈
  27.         pca9685_brightness(100,date);
  28.         pca9685_led(address,15,date);
  29.                 for(;;)                {
  30.                 }
  31. }
  32. ……………………
  33. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
stm32-pca9685.rar (311.59 KB, 下載次數(shù): 91)
ID:309183 發(fā)表于 2018-6-14 17:33 | 只看該作者
謝謝分享,最近在弄PCA9685,,,搞機(jī)器人
ID:413119 發(fā)表于 2019-4-2 22:41 | 只看該作者
謝謝樓主分享,感謝
