用12864顯示,AD芯片采用IIC通訊方式,需要用多路時(shí)要做小許修改。
- #include<reg52.h>
- #include<intrins.h>
- //P0口為12864數(shù)據(jù)輸出口
- #define uchar unsigned char
- #define uint unsigned int
- #define Delay4us(){_nop_();_nop_();_nop_();_nop_();}
- sbit LCD_RS=P2^6;
- sbit LCD_RW=P2^5;
- sbit LCD_EN=P2^7;
- sbit PM=P1^0;
- sbit SCL=P1^1; //I2C時(shí)鐘引腳
- sbit SDA=P1^2;//I2C數(shù)據(jù)輸入輸出引腳
- uchar Recv_Buffer[4];//數(shù)據(jù)接收緩沖
- uint Voltage[]={'0','0','0'};//數(shù)據(jù)分解為電壓x.xx
- bit bdata IIC_ERROR; //I2C錯(cuò)誤標(biāo)志位
- uchar LCD_Line_1[]={"1- . V 2- . V"};
- uchar LCD_Line_2[]={"3- . V 4- . V"};
- //延時(shí)
- void delay(int ms)
- uchar i;
- while(ms--) for(i=0;i<250;i++) Delay4us();
- //LCD忙檢測
- bit LCD_Busy_Check()
- bit Result;
- LCD_RS=0;LCD_RW=1;
- LCD_EN=1;Delay4us();Result=(bit)(P0&0x80);
- LCD_EN=0;
- return Result;
- //寫指令
- void LCD_Write_Command(uchar cmd)
- while(LCD_Busy_Check());
- LCD_RS=0;LCD_RW=0;LCD_EN=0;_nop_();_nop_();
- P0=cmd;Delay4us();
- LCD_EN=1;Delay4us();LCD_EN=0;
- // 寫數(shù)據(jù)
- void LCD_Write_Data(uchar dat)
- LCD_RS=1;LCD_RW=0;LCD_EN=0;P0=dat;Delay4us();
- //初始化
- void LCD_Initialise()
- LCD_Write_Command(0x38);delay(5);
- LCD_Write_Command(0x0c);delay(5);
- LCD_Write_Command(0x06);delay(5);
- LCD_Write_Command(0x01);delay(5);
- //設(shè)置顯示位置
- void LCD_Set_Position(uchar pos)
- //LCD_Write_Command(pos|0x80);
- LCD_Write_Command(pos);
- //顯示一行
- void LCD_Display_A_Line(uchar Line_Addr,uchar s[])
- uchar i;
- LCD_Set_Position(Line_Addr);
- for(i=0;i<16;i++)LCD_Write_Data(s[i]);
- // 將模數(shù)轉(zhuǎn)換后得到的值分解存入緩存
- void Convert_To_Voltage(uchar val)
- uchar Tmp; //最大值為255,對應(yīng)5V,255/5=51
- Voltage[2]=val/51+'0';//整數(shù)部分
- Tmp=val%51*10;// 第一位小數(shù)
- Voltage[1]=Tmp/51+'0';
- Tmp=Tmp%51*10;
- Voltage[0]=Tmp/51+'0';
- //啟動(dòng)I2C總線
- void IIC_Start()
- SDA=1;
- SCL=1;
- Delay4us();
- SDA=0;
- Delay4us();
- SCL=0;
- //停止I2C總線
- void IIC_Stop()
- SDA=0;
- SCL=1;
- Delay4us();
- SDA=1;
- Delay4us();
- SCL=0;
- // 從機(jī)發(fā)送應(yīng)答位
- void Slave_ACK()
- SDA=0;
- SCL=1;
- Delay4us();
- SCL=0;
- SDA=1;
- // 從機(jī)發(fā)送非應(yīng)答位
- void Slave_NOACK()
- SDA=1;
- SCL=1;
- Delay4us();
- SCL=0;
- SDA=0;
- //發(fā)送一字節(jié)
- void IIC_SendByte(uchar wd)
- uchar i;
- for(i=0;i<8;i++) //循環(huán)移入8位
- SDA=(bit)(wd&0x80);_nop_();_nop_();
- SCL=1;Delay4us();SCL=0;wd<<=1;
- Delay4us();
- SDA=1; //釋放總線并準(zhǔn)備讀取應(yīng)答
- SCL=1;
- Delay4us();
- IIC_ERROR=SDA;//IIC_ERROR=1表示無應(yīng)答
- SCL=0;
- Delay4us();
- //接收一字節(jié)
- uchar IIC_ReceiveByte()
- uchar i,rd=0x00;
- for(i=0;i<8;i++)
- SCL=1;
- rd<<=1;
- rd|=SDA;
- Delay4us();
- SCL=0;
- Delay4us();
- SCL=0;
- Delay4us();
- return rd;
- //連續(xù)讀入4路通道的A/D轉(zhuǎn)換結(jié)果并保存到Recv_Buffer
- void ADC_PCF8591(uchar CtrlByte)
- uchar i;
- IIC_Start();
- //PCF8591地址定義1001****,高四位固定1001
- //第3,2,1位對應(yīng)A2,A1,A0第0位為讀寫標(biāo)志位,1為讀0為寫
- //下面代碼中0x90,0x91分別為10010000,10010001
- IIC_SendByte(0x90);// 發(fā)送寫地址
- if(IIC_ERROR==1)return;
- // IIC_SendByte(CtrlByte);//發(fā)送控制字節(jié)
- //if(IIC_ERROR==1)return;
- //屏蔽上面兩行會(huì)產(chǎn)生警告
- IIC_Start();//重新發(fā)送開始命令
- IIC_SendByte(0x91);// 發(fā)送讀地址
- IIC_ReceiveByte();//空讀一次,調(diào)整讀順序
- Slave_ACK(); //收到一字節(jié)后發(fā)送一個(gè)應(yīng)答位
- 個(gè)人認(rèn)為下面句子有問題,但是不知道怎么改,如果把
- Recv_Buffer[i++]=IIC_ReceiveByte();中的++去掉,整個(gè)四組都是一個(gè)結(jié)果
- 但是加上好像有些重復(fù),并且13組相同,還是不很好啊
- for(i=0;i<4;i++)
- Slave_ACK();//收到一個(gè)字節(jié)后發(fā)送一個(gè)應(yīng)答位
- Slave_NOACK();
- IIC_Stop();//收到一個(gè)字節(jié)后發(fā)送一個(gè)非應(yīng)答位
- // 向 PCF8591發(fā)送1字節(jié)進(jìn)行AD轉(zhuǎn)換
- void DAC_PCF8591(uchar CtrlByte,uchar dat)
- IIC_Start();
- Delay4us();//啟動(dòng)I2C
- IIC_SendByte(0x90); //發(fā)送地址字節(jié)
- IIC_SendByte(CtrlByte); //發(fā)送控制字節(jié)
- IIC_SendByte(dat);//發(fā)送待轉(zhuǎn)換為模擬量的數(shù)值
- IIC_Stop();
- Delay4us();
- Delay4us();
- void timer0init()
- PM=0;//傳感器的輸入信號(hào)
- TMOD=0x11;//設(shè)置定時(shí)器0為工作方式1
- TH0=(65536-40)/256;
- TL0=(65536-40)%256;
- ET0=1;//開定時(shí)器0中斷
- TR0=1;//啟動(dòng)定時(shí)器0
- EA=0; //開總中斷
- //主程序
- PCF8591控制字節(jié)定義:0***0***,第3,7位固定為0
- 第6位取0時(shí)為模擬輸入,取1時(shí)為模擬輸出
- 第4,5位為00表示4路單端的模擬輸入
- 第二位為自動(dòng)遞增標(biāo)志,取1時(shí)自動(dòng)遞增
- 第0,1位取值為00,01,10,11分別表示通道0,1,2,3
- 調(diào)用ADC_PCF8591時(shí)參數(shù)為00000100,即0x04
- 調(diào)用DAC_PCF8591時(shí)參數(shù)為01000000,即0x40
- void main()
- LCD_Initialise();
- timer0init();
- while(1)
- ADC_PCF8591(0x04);
- Convert_To_Voltage(Recv_Buffer[0]);
- LCD_Line_1[2]=Voltage[2];
- LCD_Line_1[4]=Voltage[1];
- LCD_Line_1[5]=Voltage[0];
- Convert_To_Voltage(Recv_Buffer[1]);
- LCD_Line_1[11]=Voltage[2];
- LCD_Line_1[13]=Voltage[1];
- LCD_Line_1[14]=Voltage[0];
- Convert_To_Voltage(Recv_Buffer[2]);
- LCD_Line_2[2]=Voltage[2];
- LCD_Line_2[4]=Voltage[1];
- LCD_Line_2[5]=Voltage[0];
- Convert_To_Voltage(Recv_Buffer[3]);
- LCD_Line_2[11]=Voltage[2];
- LCD_Line_2[13]=Voltage[1];
- LCD_Line_2[14]=Voltage[0];
- // 液晶兩行顯示四個(gè)通道的轉(zhuǎn)換結(jié)果
- LCD_Display_A_Line(0x80, LCD_Line_1);
- LCD_Display_A_Line(0x90, LCD_Line_2);
- // 將0通道模擬轉(zhuǎn)換后的數(shù)值重新轉(zhuǎn)換為模擬量并從Aout輸出
- //通過LED亮度表現(xiàn)出來
- // DAC_PCF8591(0x40,Recv_Buffer[0]);
- void timer0() interrupt 1
- int N;
- N++;
- //if(N==7)
- //PM=1;
- if(N==8)
- PM=0;
- if(N>=250)
- PM=1;
- N=0;
pcf8591.zip
2018-6-18 13:05 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
2.4 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
主要文件,工程需自建
