本實驗完成了stm32對uart4串口配置,使用rs485通訊,完成和上位機數(shù)據(jù)交換,使用modbus協(xié)議
單片機源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- #include "usart.h"
- #include "rs485.h"
- //Modbus寄存器和單片機寄存器的映射關系
- vu32 *Modbus_InputIO[100];//輸入開關量寄存器指針(這里使用的是位操作)
- vu32 *Modbus_OutputIO[100];//輸出開關量寄存器指針(這里使用的是位操作)
- 函數(shù)功能:配置io輸出口
- void DO_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOC, ENABLE ); //使能GPIOE
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; //PE8-PE15 作為推挽輸出引腳
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化GPIOE
- GPIO_ResetBits(GPIOE,GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_13; //
- GPIO_Init(GPIOC, &GPIO_InitStructure); //根據(jù)設定參數(shù)初始化GPIOD.5
- GPIO_ResetBits(GPIOC,GPIO_Pin_8|GPIO_Pin_13); //PC.10 輸出高
- //CRC校驗 自己后面添加的
- const u8 auchCRCHi[] = {
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,0x80, 0x41, 0x00, 0xC1, 0x81, 0x40} ;
- const u8 auchCRCLo[] = {
- 0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
- 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
- 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
- 0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
- 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
- 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
- 0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
- 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
- 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
- 0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
- 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
- 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,0x43, 0x83, 0x41, 0x81, 0x80, 0x40} ;
- 函數(shù)功能:生成CRC校驗碼
- u16 CRC_Compute(u8 *puchMsg, u16 usDataLen)
- u8 uchCRCHi = 0xFF ;
- u8 uchCRCLo = 0xFF ;
- u32 uIndex ;
- while (usDataLen--)
- uIndex = uchCRCHi ^ *puchMsg++ ;
- uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex] ;
- uchCRCLo = auchCRCLo[uIndex] ;
- return ((uchCRCHi<< 8) | (uchCRCLo)) ;
- u16 RegNum;
- u8 RS485_TX_BUFF[10];//發(fā)送緩沖區(qū)
- u8 RS485_RX_BUFF[10];//接收緩沖區(qū)
- u16 calCRC;
- u16 startRegAddr; //寄存器起始地址
- u16 recCRC;
- void Modbus_05_Solve(void)
- if(startRegAddr<100)
- if((RS485_RX_BUFF[4]==0xFF)||(RS485_RX_BUFF[5]==0xFF)) *Modbus_OutputIO[startRegAddr]=0x01;
- else *Modbus_OutputIO[startRegAddr]=0x00;
- RS485_TX_BUFF[0]=RS485_RX_BUFF[0];
- RS485_TX_BUFF[1]=RS485_RX_BUFF[1];
- RS485_TX_BUFF[2]=RS485_RX_BUFF[2];
- RS485_TX_BUFF[3]=RS485_RX_BUFF[3];
- RS485_TX_BUFF[4]=RS485_RX_BUFF[4];
- RS485_TX_BUFF[5]=RS485_RX_BUFF[5];
- calCRC=CRC_Compute(RS485_TX_BUFF,6);
- RS485_TX_BUFF[6]=calCRC&0xFF;
- RS485_TX_BUFF[7]=(calCRC>>8)&0xFF;
- RS485_Send_Data(RS485_TX_BUFF,8);
- else
- RS485_TX_BUFF[1]=RS485_RX_BUFF[1]|0x80;
- RS485_TX_BUFF[2]=0x02;
- RS485_Send_Data(RS485_TX_BUFF,3);
- //Modbus功能碼15處理函數(shù)
- void Modbus_15_Solve(void)
- DO_Init();
- RegNum=(((u16)RS485_RX_BUFF[4])<<8)|RS485_RX_BUFF[5];//獲取寄存器數(shù)量
- if((startRegAddr+RegNum)<100)//寄存器地址+數(shù)量在范圍內(nèi)
- if(RS485_RX_BUFF[6]==0x01)
- switch(RS485_RX_BUFF[7])
- case 0x01:
- GPIO_ResetBits(GPIOE,GPIO_Pin_8);
- delay_ms(100); //開機功能
- GPIO_SetBits(GPIOE,GPIO_Pin_8);
- break;
- case 0x02:
- GPIO_ResetBits(GPIOE,GPIO_Pin_10);
- delay_ms(100); //關機
- GPIO_SetBits(GPIOE,GPIO_Pin_10);
- break;
- case 0x04:
- GPIO_ResetBits(GPIOE,GPIO_Pin_9);
- delay_ms(100); //激勵封鎖
- GPIO_SetBits(GPIOE,GPIO_Pin_9);
- break;
- case 0x08:
- GPIO_ResetBits(GPIOE,GPIO_Pin_11);
- delay_ms(500); //復位
- GPIO_SetBits(GPIOE,GPIO_Pin_11);
- break;
- else
- RS485_TX_BUFF[2]=0x02; //異常碼
- else//寄存器地址+數(shù)量不在范圍內(nèi)
- int main(void)
- u8 key;
- u8 i=0;
- u8 rs485buf[10];
- delay_init(); //延時函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優(yōu)先級分組為組2:2位搶占優(yōu)先級,2位響應優(yōu)先級
- uart_init(115200); //串口初始化為115200
- LED_Init(); //初始化與LED連接的硬件接口
- LCD_Init(); //初始化LCD
- KEY_Init(); //按鍵初始化
- RS485_Init(9600); //初始化RS485串口波特率9600
- while(1)
- RS485_Receive_Data(rs485buf,&key);
- if(key)//接收到有數(shù)據(jù)
- if(key>10)key=10;//最大是10個數(shù)據(jù).
- for(i=0;i<key;i++)
- RS485_RX_BUFF[i]=rs485buf[i];
- if(RS485_RX_BUFF[0]==0x01)//地址正確
- if((RS485_RX_BUFF[1]==00)||(RS485_RX_BUFF[1]==02)||(RS485_RX_BUFF[1]==0x03)||(RS485_RX_BUFF[1]==0x05)||(RS485_RX_BUFF[1]==0x06)||(RS485_RX_BUFF[1]==0x15)||(RS485_RX_BUFF[1]==0x16))
- startRegAddr=(((u16)RS485_RX_BUFF[2])<<8)|RS485_RX_BUFF[3];//獲取寄存器地址
- if(startRegAddr<1000)//寄存器地址在范圍內(nèi)
- calCRC=CRC_Compute(RS485_RX_BUFF,8);//計算所接收到數(shù)據(jù)的CRC
- recCRC=RS485_RX_BUFF[9]|(((u16)RS485_RX_BUFF[8])<<8);//????CRC(?????,?????)
- if(calCRC==recCRC)//CRC正確
- switch(RS485_RX_BUFF[1])//判斷功能碼
- case 0x05://寫單個輸出開關量
- Modbus_05_Solve();
- break;
- case 0x15://寫多個輸出開關量
- Modbus_15_Solve();
- break;
- else//CRC錯誤
- RS485_TX_BUFF[2]=0x04; //異常碼
- else//寄存器地址超出范圍
- else//功能碼錯誤
- RS485_TX_BUFF[2]=0x01; //異常碼
- RS485_RX_CNT=0;//清零
- RS485_TX_EN=0;//開始接收
復制代碼
