智能小車可以完成循跡避障等功能
- #include<AT89x51.H>
- #include<intrins.h>
- #include<HJ-4WD_PWM.H> //定義函數(shù)
- #define Left_1_led P3_7 //左循跡
- #define Right_1_led P3_6 //右循跡
- #define LeftIRBZ P3_5 //左避障
- #define RightIRBZ P3_4 //右避障
- //#define Left_led p2_2 //左光傳感器
- //#define Right_led p2_4 //右光傳感器
- sbit SB1=P2^3; //定義蜂鳴器
- sbit IRIN=P3^3; //定義紅外接收端口
- unsigned char code LedShowData[]={0x03,0x9F,0x25,0x0D,0x99, //定義數(shù)碼管顯示數(shù)據(jù)
- 0x49,0x41,0x1F,0x01,0x19};//0,1,2,3,4,5,6,7,8,9
- unsigned char code RecvData[]={0x19,0x46,0x15,0x43,0x44,0x40,0x0D,0x0E,0x00,0x0F};
- unsigned char IRCOM[7];
- #define ShowPort P0 //定義數(shù)碼管顯示端口
- unsigned char temp = 1;
- void Delay1ms(unsigned int i)
- unsigned char j,k;
- do{
- j = 10;
- do{
- k = 50;
- do{
- _nop_();
- }while(--k);
- }while(--j);
- }while(--i);
- void delay_nus(unsigned int i) //延時(shí):i>=12 ,i的最小延時(shí)單12 us
- i=i/10;
- while(--i);
- void delay_nms(unsigned int n) //延時(shí)n ms
- n=n+1;
- while(--n)
- delay_nus(900); //延時(shí) 1ms
- void delayms(unsigned char x) //0.14mS延時(shí)
- unsigned char i;
- while(x--)
- for (i = 0; i<13; i++) {} //14mS延時(shí)
- void Delay() //定義延時(shí)子程序
- unsigned int DelayTime=30000;
- while(DelayTime--); //開始進(jìn)行延時(shí)循環(huán)
- return;
- void ControlCar_yaokong(unsigned char ConType) //定義電機(jī)控制子程序
- stop();
- switch(ConType) //判斷設(shè)定電機(jī)形式
- case 1: //前進(jìn) //判斷是否選擇形式1
- stop();
- Delay1ms(150);
- // LeftLed = 0 ;
- run();
- break;
- case 2: //后退 //判斷是否選擇形式2
- stop();
- Delay1ms(150);
- // LeftLed = 1 ;
- back(); //M2電機(jī)反轉(zhuǎn)
- break;
- case 3: //右轉(zhuǎn) //判斷是否選擇形式3
- stop();
- Delay1ms(150);
- rightrun(); //M2電機(jī)正轉(zhuǎn)
- break;
- case 4: //左轉(zhuǎn) //判斷是否選擇形式4
- stop();
- Delay1ms(150);
- leftrun(); //M1電機(jī)正轉(zhuǎn) M2電機(jī)反轉(zhuǎn)
- break;
- case 8: //停止 //判斷是否選擇形式8
- stop();
- break; //退出當(dāng)前選擇
- void Robot_Avoidance() //避障子程序
- if(LeftIRBZ==1&&RightIRBZ ==1) //LeftIRBZ RightIRBZ
- run();
- delay_nms (10);
- SB1=1;
- else
- if(LeftIRBZ==1&&RightIRBZ ==0) //右邊檢測到紅外信號(hào)
- rightrun();
- delay_nms (300);
- if(RightIRBZ ==1&&LeftIRBZ==0)
- leftrun();
- delay_nms (300);
- if(RightIRBZ==0&&LeftIRBZ==0) //兩邊傳感器同時(shí)檢測到紅外
- SB1=0;
- stop(); //停止
- delay_nms (300);
- back(); //調(diào)用電機(jī)后退函數(shù)
- delay_nms (300); //后退50毫秒
- rightrun(); //調(diào)用電機(jī)右轉(zhuǎn)函數(shù)
- delay_nms (400);
- run();
- void Robot_Traction() //循跡子程序
- //SB1=1;
- if(Left_1_led == 0 && Right_1_led == 0) //三個(gè)紅外檢測到黑線,就前進(jìn) Left_1_led Right_1_led
- run(); //左側(cè)沒有信號(hào)時(shí),開始向右轉(zhuǎn)一定的角度
- delay_nms (10);
- SB1=0;
- else if(Left_1_led == 0 && Right_1_led == 1)
- rightrun(); //右側(cè)檢測到黑線,開始向右轉(zhuǎn)一定的角度
- delay_nms (10);
- else if(Left_1_led == 1 && Right_1_led == 0)
- leftrun(); //左側(cè)檢測到黑線,開始向左轉(zhuǎn)一定的角度
- delay_nms (10);
- else if(Left_1_led == 1 && Right_1_led == 1)
- SB1=1;
- stop(); //左側(cè)檢測到黑線,開始向左轉(zhuǎn)一定的角度
- delay_nms (10);
- //----------紅外遙控-------------------------------------------------------------
- void IR_IN() interrupt 2 using 0 //定義INT2外部中斷函數(shù)
- unsigned char j,k,N=0; //定義臨時(shí)接收變量
- EX1 = 0; //關(guān)閉外部中斷,防止再有信號(hào)到達(dá)
- delayms(15); //延時(shí)時(shí)間,進(jìn)行紅外消抖
- if (IRIN==1) //判斷紅外信號(hào)是否消失
- EX1 =1; //外部中斷開
- return; //返回
- while (!IRIN) //等IR變?yōu)楦唠娖剑^9ms的前導(dǎo)低電平信號(hào)。
- delayms(1); //延時(shí)等待
- for (j=0;j<4;j++) //采集紅外遙控器數(shù)據(jù)
- for (k=0;k<8;k++) //分次采集8位數(shù)據(jù)
- while (IRIN) //等 IR 變?yōu)榈碗娖,跳過4.5ms的前導(dǎo)高電平信號(hào)。
- while (!IRIN) //等 IR 變?yōu)楦唠娖?br />
- while (IRIN) //計(jì)算IR高電平時(shí)長
- N++; //計(jì)數(shù)器加加
- if (N>=30) //判斷計(jì)數(shù)器累加值
- EX1=1; //打開外部中斷功能
- return; //返回
- IRCOM[j]=IRCOM[j] >> 1; //進(jìn)行數(shù)據(jù)位移操作并自動(dòng)補(bǔ)零
- if (N>=8) //判斷數(shù)據(jù)長度
- IRCOM[j] = IRCOM[j] | 0x80; //數(shù)據(jù)最高位補(bǔ)1
- N=0; //清零位數(shù)計(jì)錄器
- if (IRCOM[2]!=~IRCOM[3]) //判斷地址碼是否相同
- EX1=1; //打開外部中斷
- return; //返回
- for(j=0;j<10;j++) //循環(huán)進(jìn)行鍵碼解析
- if(IRCOM[2]==RecvData[j]) //進(jìn)行鍵位對應(yīng)
- // ControlCar(j);
- ControlCar_yaokong(j); //數(shù)碼管顯示相應(yīng)數(shù)碼
- EX1 = 1; //外部中斷開
- //----------尋光子程序-------------------------------------------------------------
- void Robot_Lightseek()
- //unsigned char i;
- P1=0X00; //關(guān)電車電機(jī)
- /*TMOD=0X01;
- TH0= 0XFc; //1ms定時(shí)
- TL0= 0X18;
- TR0= 1;
- ET0= 1;
- EA = 1; */ //開總中斷
- while(1) //無限循環(huán)
- //有信號(hào)為0 沒有信號(hào)為1
- if(Left_led==0&&Right_led==0)
- run(); //調(diào)用前進(jìn)函數(shù)
- else
- if(Left_led==1&&Right_led==0) //右邊檢測到紅外信號(hào)
- rightrun(); //調(diào)用小車右轉(zhuǎn)函數(shù)
- delay(40);
- if(Right_led==1&&Left_led==0) //左邊檢測到紅外信號(hào)
- leftrun(); //調(diào)用小車左轉(zhuǎn)函數(shù)
- delay(40);
- if(Right_led==1&&Left_led==1) //兩邊傳感器沒有檢測到光
- stop(); //調(diào)用電機(jī)停止函數(shù)
- delay(40);
- //------------------------------超聲波避障、測距---------------------------------------------------------
- void main() //主程序入口
- TMOD=0X01;
- TL0= 0X18;
- TR0= 1;
- ET0= 1;
- EA = 1; //開總中斷
- //EX1=1; //同意開啟外部中斷1
- IT1=1;
- //設(shè)定外部中斷1為低邊緣觸發(fā)類型
- while(1) //程序主循環(huán)
- if(P3_2 == 0)
- if(temp<=4)
- temp=temp+1;
- while(!P3_2);
- if(temp>4)
- temp=1;
- switch(temp)
- case 1: ShowPort = LedShowData[1];Robot_Traction();EX1 = 0;break;
- case 2: ShowPort = LedShowData[2];Robot_Avoidance();EX1 = 0;break;
- case 3: ShowPort = LedShowData[3];SB1 = 1; EX1 = 1;break;
- case 4: ShowPort = LedShowData[4];Robot_Lightseek();EX1 = 0;break;
循跡、避障、遙控綜合.zip
(49.75 KB, 下載次數(shù): 11)
2019-6-24 10:57 上傳
點(diǎn)擊文件名下載附件
智能小車程序
