查看: 4243|回復(fù): 1
at89c51單片機(jī)輸出8路脈沖Proteus仿真+程序
頻率分別位100hz,50,25,20,10,5,2,1  文件內(nèi)含c程序和protues仿真圖
  1. #include <reg51.h>
  2. #define unit unsigned int
  4. sbit p10=P1^0;//P1^0輸出100HZ波形
  5. sbit p11=P1^1;//P1^1輸出50HZ波形
  6. sbit p12=P1^2;//P1^2輸出25HZ波形
  7. sbit p13=P1^3;//P1^3輸出20HZ波形
  8. sbit p14=P1^4;//P1^4輸出10HZ波形
  9. sbit p15=P1^5;//P1^5輸出5HZ波形
  10. sbit p16=P1^6;//P1^6輸出2HZ波形
  11. sbit p17=P1^7;//P1^7輸出1HZ波形
  12. uchar count0;//計(jì)數(shù)
  13. uchar count1;
  14. uchar count2;
  15. uchar count3;
  16. uchar count4;
  17. uchar count5;
  18. uchar count6;
  19. uchar count7;
  20. void main()
  21. {
  22.         count0=1;
  23.         count1=2;
  24.         count2=4;
  25.         count3=5;
  26.         count4=10;
  27.         count5=20;
  28.         count6=50;
  29.         count7=100;
  30.         TMOD=0X01;//定時(shí)器0 方式1
  31.         TH0=(65536-5000)/256;//5000個(gè)機(jī)器周期  5ms
  32.         TL0=(65536-5000)%256;
  33.         EA=1;
  34.         ET0=1;
  35.         TR0=1;
  36.         while(1)
  37.         {
  38.                 if(count0==0){count0=1;p10=!p10;}
  39.                 if(count1==0){count1=2;p11=!p11;}
  40.                 if(count2==0){count2=4;p12=!p12;}
  41.                 if(count3==0){count3=5;p13=!p13;}
  42.                 if(count4==0){count4=10;p14=!p14;}
  43.                 if(count5==0){count5=20;p15=!p15;}
  44.                 if(count6==0){count6=50;p16=!p16;}
  45.                 if(count7==0){count7=100;p17=!p17;}
  46.
  47.         }
  48. }
  49. void counter()interrupt 1
  50. {
  51.         TH0=(65536-4994)/256;
  52.         TL0=(65536-4994)%256;
  53.         count0--;
  54.         count1--;
  55.         count2--;
  56.         count3--;
  57.         count4--;
  58.         count5--;
  59.         count6--;
  60.         count7--;
  61. }
8路脈沖.zip (29.54 KB, 下載次數(shù): 34)
收藏收藏3 分享淘帖 頂 踩
ID:1022674 發(fā)表于 2022-10-17 10:23 | 只看該作者
謝謝,文件很好,很實(shí)用
