電路圖:
2020-5-14 19:16 上傳
通過左邊按鍵可以控制電機啟停正反轉(zhuǎn)加減速。而相應的狀態(tài)也會反映在顯示屏上,問題在于顯示只能顯示正轉(zhuǎn)其他都顯示不了。
2020-5-14 19:19 上傳
源程序如下:
- #include <reg52.h>
- #include<string.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit lcdrs=P2^0; //寄存器選擇,0:數(shù)據(jù)寄存器。1:為狀態(tài)/命令寄存器
- sbit lcden=P2^1; //--LCD控制引腳
- sbit speed=P3^2; //測速端口
- sbit ENA=P2^2; //電機使能控制端
- sbit key1=P1^0; //啟動按鍵
- sbit key2=P1^1; //正轉(zhuǎn)按鍵
- sbit key3=P1^2; //反轉(zhuǎn)按鍵
- sbit key4=P1^3; //加速按鍵
- sbit key5=P1^4; //減速按鍵
- sbit key6=P1^5; //停止按鍵
- sbit Zheng=P1^6; //正轉(zhuǎn)輸出端口
- sbit Fan=P1^7; //反轉(zhuǎn)輸出端口
- uchar Timer0_flag=4;
- uchar Timer0_BiaoZhi=0;//初始化占空比為1:3(高:低)
- uchar gewei;
- uchar shiwei;
- uchar baiwei;
- /******標志位設(shè)置*****/
- uchar KEY1=0;//優(yōu)先級標志
- uchar KEY2=0;//加速標志
- uchar INT1_FLAG=0;
- uchar COUNTER_high=0;
- uchar COUNTER_low=0;
- uchar SUM=0;
- uint TIMER1_COUNTER=0;
- uint INT1_tingzhi=0; //在要測速時置0
- /****面板顯示****/
- uchar code lcd_desktop11[]="stop";//停止
- uchar code lcd_desktop12[]="ford";//正轉(zhuǎn)
- uchar code lcd_desktop13[]="fanz";//反轉(zhuǎn)
- uchar code lcd_desktop21[]="speedup";//加速
- uchar code lcd_desktop22[]="speeddn";//減速
- uchar code num[]={'0','1','2','3','4','5','6','7','8','9'};//要顯示的轉(zhuǎn)速數(shù)字。
- //-----lcd液晶屏頭文件-----//
- /**延時函數(shù)**/
- void delayms(uchar xms)
- uchar i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- /****LCD寫命令******/
- void write_command(uchar com)//com寫入命令
- lcdrs=0;
- P0=com;
- delayms(2);
- lcden=1;
- delayms(2);
- lcden=0;
- /**************LCD寫數(shù)據(jù)*********/
- void write_data(uchar date)//數(shù)據(jù)為DATA
- lcdrs=1;
- P0=date;
- delayms(2);
- lcden=1;
- delayms(2);
- lcden=0;
- /********LCD初始化****************/
- void lcd_init()//顯示模式設(shè)置
- lcden=0;
- write_command(0x38);
- write_command(0x0c);
- write_command(0x06);
- write_command(0x01);
- /**電機初始化函數(shù)**/
- void motor_init(void)
- ENA=0; // 停止
- void ZhongDuanKaiQi(void)
- EA=1;
- ET0=1; //計時器0允許中斷。產(chǎn)生脈沖。
- ET1=1; //計時器1允許中斷。對低電平進行計時。
- //EX1=1; //INT0允許中斷。測速。由外部來啟動。
- IT1=1; //低電平觸發(fā)。
- PX1=0; //低級中斷。
- PT0=1;
- PT1=0;
- TMOD=0x12;//定時器工作方式控制
- /***定時器T1初始化。!等待外部脈沖的到來***/
- void Timer1_init(void)
- TH1=0;
- TL1=0; //等待外部脈的到來。INT1
- /*****定時T0初始化*****/
- void Timer0_init(void)
- TH0=0;
- TL0=0;
- TR0=1;
- /********測速模塊,顯示速度*******/
- void speed_test(void)
- // TIMER1_COUNTER;
- COUNTER_high=TH1;
- COUNTER_low=TL1;
- SUM=COUNTER_high*256+COUNTER_low+TIMER1_COUNTER*65536;//得到的是多少us。
- SUM=SUM/1000; //化為毫秒。
- SUM=1000/SUM; //圈每秒。
- SUM=SUM*60; //圈每分鐘;三位數(shù)。
- gewei=SUM%10;
- shiwei=SUM/10%10;
- baiwei=SUM/100;
- write_command(0xc0);
- write_data(baiwei);
- write_command(0xc1);
- write_data(shiwei);
- write_command(0xc2);
- write_data(gewei);
- SUM=0;
- TIMER1_COUNTER=0;
- /********外中斷1函數(shù)**********/
- void INT1_QIDONG() interrupt 2
- INT1_tingzhi++;
- if(INT1_tingzhi==5)
- INT1_tingzhi=5;EX1=0;//關(guān)閉中斷。
- if(INT1_tingzhi<=4)
- INT1_FLAG++;
- if(INT1_FLAG==2)
- INT1_FLAG=0;TR1=0;speed_test();
- else
- Timer1_init();
- TR1=1;
- /******定時器T1計數(shù)*******/
- void Timer1_QIDONG() interrupt 3
- TIMER1_COUNTER++;
- /**相位測量并輸出!!!!!出現(xiàn)問題???**/
- void xiangwei_test(void)
- uchar i=0,j=0;
- //while((P2^3==0)&&(P2^4==0));
- //if((P2^3==0)&&(P2^4==0))
- //delayms(5);
- if(P2^3==1)
- write_command(0x80);for(i=0;i<=3;i++) write_data(lcd_desktop13[i]);//反轉(zhuǎn)。
- j++;//反轉(zhuǎn)
- if(P2^4==1)
- write_command(0x80);for(i=0;i<=3;i++) write_data(lcd_desktop12[i]);//正轉(zhuǎn)。
- j++;
- /****T0中斷發(fā)出信號并進行通道選擇****/
- void Timer0() interrupt 1
- Timer0_flag--;
- if((Timer0_BiaoZhi)>=(Timer0_flag))
- if(KEY2==0)
- Zheng=1;Fan=0;
- else
- Zheng=0;Fan=1;
- else
- Zheng=0;Fan=0;
- if(Timer0_flag==0) Timer0_flag=5;
- void Guan(void)
- ET0=0;
- EX1=0;
- ET1=0;
- void keyscan() //按鍵掃描函數(shù)
- uint i=0;
- if(key1==0) //按鍵K1啟動按鈕。只有該位啟動時,后面的幾位才有效。啟動T0計數(shù)開始發(fā)出脈沖。
- delayms(10);
- if(key1==0)
- while(!key1);
- KEY1=5;
- Fan=0;
- Zheng=0;
- ENA=1;
- KEY2=0;//初始化為正轉(zhuǎn)。
- Timer0_BiaoZhi=0;
- Timer0_flag=4;
- ZhongDuanKaiQi();//開啟中斷
- Timer0_init();// 初始化并開始發(fā)出脈場外中斷已經(jīng)開啟。
- EX1=1; //外中斷開啟;測速,顯示速度。五次后結(jié)束關(guān)閉外中斷1。出現(xiàn)問題。!
- for(i=0;i<strlen(lcd_desktop11);i++)//顯示正轉(zhuǎn)。
- write_data(lcd_desktop12[i]);
- if((key2==0)&&(KEY1=5)) //按鍵K2按下,(正轉(zhuǎn))只改變轉(zhuǎn)向(標志位改變輸出端口)
- delayms(10);
- if(key2==0)
- while(!key2);
- KEY2=0; //正轉(zhuǎn)標志,電機正向旋轉(zhuǎn)。
- //KEY2=(~1);
- xiangwei_test();
- KEY1=5;
- if((key3==0)&&(KEY1=5)) //按鍵K3按下,(反轉(zhuǎn))只改變轉(zhuǎn)向
- delayms(10);
- if(key3==0)
- while(!key3);
- KEY2=~0; //反轉(zhuǎn)標志。
- //KEY2=(~0);
- xiangwei_test();
- KEY1=5;
- if((key4==0)&&(KEY1==5)) //按鍵K4按下,(加速)改變裝入的數(shù)值?循環(huán)次數(shù)?執(zhí)行if里面的語句,通過size++來改變幅值的頻率
- delayms(10);
- if(key4==0)
- while(!key4);
- if(Timer0_BiaoZhi<4)
- Timer0_BiaoZhi++;
- else
- Timer0_BiaoZhi=4;
- EX1=1;
- KEY1=5;
- if((key5==0)&&(KEY1==5)) //按鍵K5按下,(減速)對其它標志位沒有影響。
- delayms(5);
- if(key5==0)
- while(!key5);
- if(Timer0_BiaoZhi==0)
- Timer0_BiaoZhi=0;
- else
復制代碼 附程序和電路圖,各位大佬可以下載試試仿真,因為自己看不出來有什么問題了,希望有人能解惑!
