查看: 2631|回復: 0
單片機電子琴代碼
ID:788227 發(fā)表于 2020-6-23 22:42 | 顯示全部樓層 |閱讀模式
#include <reg51.h>//頭文件的引用
void T0_init();//定義初值
void Key();        //按鍵掃描函數(shù)
void yingyue(); //音樂播放函數(shù)
void delay(unsigned char t) ;
void Display();
void Delay_ms(unsigned int t);
sbit beep=P2^7;//定義蜂鳴器
sbit DO=P1^0;//DO音符端口
sbit RE=P1^1;//RE音符端口
sbit MI=P1^2;//MI音符端口
sbit FA=P1^3;//FA音符端口
sbit SO=P1^4;//SO音符端口
sbit LA=P1^5;//LA音符端口
sbit SI=P1^6;//SI音符端口
sbit key1=P2^4;//低音按鍵功能
sbit key2=P2^5;//中音按鍵功能
sbit key3=P2^6;//高音按鍵功能
sbit led_song=P2^2;//音樂播放模式指示燈
sbit led_dz=P2^3;//電子琴模式指示燈
sbit  SW1=P2^0;//控制位選碼
sbit  SW2=P2^1;//控制位選碼
unsigned char code yinfu_table[]={0X40,0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //0-9的段碼(共陽)
unsigned char code yindiao_table[]={0X40,0xc0,0xf9,0xa4,0xb0}; //0-4的段碼(共陽)
unsigned char time1, time2, time;
unsigned int index=0,j=0;
unsigned char i=0;
unsigned int k=0 ;
unsigned char Tone_H8[22]={        0X00,
                           0xf8,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc,//低音的DO~SI初值高八位
                           0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe,//中音的DO~SI初值高八位
                                                   0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xff };//高音的DO~SI初值高八位
unsigned char Tone_L8[22]={0X00,
                         0x44,0xAC,0x09,0x34,0x82,0xC8,0x06, //低音的DO~SI初值低八位
                         0x44,0xac,0x09,0x34,0x82,0xc8,0x06 , // 中音的DO~SI初值低八位
                                                 0x22,0x56,0x85,0x88,0xc1,0xe4,0x02 };//高音的DO~SI初值低八位
code unsigned char song[]={
5,10,9, 10,3,8, 7,6,6, 9,8,9,
6,8,9, 9,9,9,8, 10,10,9, 9,5,10,
9,10,3, 8,7,6, 5,6,8, 8,8,9,
10,9,8, 7,8,8,
-1
};//感恩的心音調
unsigned char len[]={
2,4,2, 6,2,4, 2,6,2, 4,2,5,
1,1,2, 1,1,2, 1,1,2, 2,4,2,
4,2,6, 2,4,2, 6,2,2, 1,1,2,
2,2,4, 2,2,2,8,
-1};//感恩的心節(jié)拍
   void main(void)//主函數(shù)
        T0_init();//初始化函數(shù)調用
                while(1){
        if(i==0){
         led_song=1;
         led_dz=0;
         Key();//按鍵掃描函數(shù)的調用
         Display();
        if(i==1){
                k++;
        time1=Tone_H8[song[k]];
        time2=Tone_L8[song[k]];
        time=len[k]; //節(jié)拍
            led_song=0;
            led_dz=1;
        yingyue();//發(fā)出一個音符
void Display()//音符音調顯示函數(shù)
        SW1=1;
        SW2=0;
        P0=yinfu_table[(index-1)%7];//顯示按鍵音符
        Delay_ms(10);
        P0=0x00;
        SW1=0;
        SW2=1;
        P0=yindiao_table[(index-1)/7];//顯示按鍵音調
        Delay_ms(10);
        P0=0x00;
void T0_int(void) interrupt 1 //T0中斷程序,控制發(fā)音的音符
    TH0= Tone_H8[index];
        TL0= Tone_L8[index];
        beep=~beep;
void t0int() interrupt 3         //T1中斷程序,控制發(fā)音的音符
    TR1= 1;
    TH1 = time1;
    TL1 = time2;
        beep=~beep;
void T0_inter()interrupt 0         //外部中斷0程序,控制功能的選擇
          i++;
          i=i%2;
         if(i==0) //選擇彈奏音樂
           k=0;
         time1=0;
         time2=0;
         time=0;
         if(i==1){         //選擇演奏音樂
         TR0=0;
         TR1=1;
         index=0;
    if(i==100)i=0;
//中斷初始化程序
void T0_init(){
           EA=1; //開總中斷
        TMOD=0x11;//在TMOD寄存器中設置T0,T1的工作方式
        ET1=1;
        ET0=1;
        EX0=1;
        IT0=1;
        PX0=1;
void delay(unsigned char t) //延時程序,控制發(fā)音的時間長度
    unsigned char t1;
    unsigned long t2;
    for(t1=0;t1<t;t1++)    //雙重循環(huán), 共延時t個半拍
    for(t2=0;t2<6000;t2++); //延時期間, 可進入T0中斷去發(fā)音
    TR1=0;                                          //關閉T0, 停止發(fā)音
//延時函數(shù)
void yingyue()                      //演奏一個音符
    TH1=time1;  //控制音調
    TL1=time2;
    TR1=1; //啟動T0, 由T0輸出方波去發(fā)音
    delay(time); //控制時間長度
void Delay_ms(unsigned int t)                //@12.000MHz
        unsigned char i, j, k;
        for(k=0;k<t;k++){
                i = 12;
                j = 169;
                do
                        while (--j);
                } while (--i);
//按鍵掃描函數(shù)
void Key()
                if(key1==0)          //低音按鍵功能
                        Delay_ms(20);
                        if(key1==0)
                {        TR0=0;
                        j=0;
                 if(key2==0)           //中音按鍵功能
                        Delay_ms(20);
                        if(key2==0)
                        {TR0=0;
                                j=7;
                         if(key3==0)                 //高音按鍵功能
                        Delay_ms(20);
                        if(key3==0)
                        TR0=0;
                        j=14;
                if(P1!=0xFF)
                        Delay_ms(20);
                        switch(P1)
                                case  0xFE: index=j+1;TR0=1;break;//DO
                                case  0xFD: index=j+2;TR0=1;break;//RE
                                case  0xFB: index=j+3;TR0=1;break;//MI
                                case  0xF7: index=j+4;TR0=1;break;//FA
                                case  0xEF: index=j+5;TR0=1;break;//SO
                                case  0xDF: index=j+6;TR0=1;break;//LA
                                case  0xBF: index=j+7;TR0=1;break;//SI
Powered by 單片機教程網
