通電后進(jìn)入掉電模式,電流大概4uA,
按鍵后,中斷喚醒,電流大概30mA,
然后。。。!
理論上講這時(shí)候應(yīng)該重新變成掉電模式的4uA
但是用萬(wàn)用表測(cè)電流發(fā)現(xiàn),電流從30mA跳到28mA后,以0.1mA每秒的速度往下掉
這是為什么呀?
unsigned char key0 = 1;
unsigned char key1 = 1;
unsigned char key_tc = 1;
/**************中斷******************/
void INT0_Routine()interrupt 0 //左邊key0
PCON = 0x00;
key1 = 0;
void INT1_Routine()interrupt 2 //右邊key1
key0 = 0;
void INT3_Routine()interrupt 11
key_tc = 0;
/**************主程序****************/
P1M1 = 0xCF; // 1.7,1.6,1.3,1.2,1.1,1.0高阻輸入
P1M0 = 0x00; //
P3M1 = 0x0C; // key1和key2高阻輸入
P3M0 = 0x00;
IT0 = 1; //使能INT0下降沿中斷
EX0 = 1; //使能INT0中斷
IT1 = 1; //使能INT1下降沿中斷
EX1 = 1; //使能INT1中斷
INTCLKO = 0x20; //使能INT3下降沿中斷
ES = 1; //使能串口中斷
EA = 1;
led = 1;
PCON = 0x02; //掉電模式,低功耗模式
if(key_tc == 0)
led = 0;
Delay30ms(); //按鍵防抖
up();
read_id();
Delay30ms();
led = 1;
key_tc = 1;
PCON = 0x02;
if(key0 == 0)
led = 0;
Delay30ms(); //按鍵防抖
up();
Delay30ms();
led = 1;
key0 = 1;
PCON = 0x02;
if(key1 == 0)
led = 0;
Delay30ms(); //按鍵防抖
down();
Delay30ms();
led = 1;
key1 = 1;
PCON = 0x02;
