查看: 4629|回復(fù): 4
12864+gps校時(shí)+dht11+stc8a8k單片機(jī)程序,12864是7567芯片串口屏
制作出來的實(shí)物圖如下:
最終的顯示效果,
單片機(jī)采用stc8a8k32s4a12。7567芯片串口屏幕,加上DHt11溫濕度采集,
供電電壓直接由單片機(jī)AD采集增加電量顯示
附件中保留DS1302部分程序,DS1302時(shí)間誤差太大,最終舍棄。采用GPS校時(shí)方式。
發(fā)個(gè)帖子賺點(diǎn)積分 12864 tft.rar (174.87 KB, 下載次數(shù): 85)
  1. #include "stc8.h"
  2. #include <intrins.h>
  3. #include "GPS.h"
  4. unsigned char RX_Buffer[120]={0};
  5. unsigned char RX_Count = 0;
  6. unsigned char Hour = 0,Min_High = 0,Min_Low = 0,Sec_High = 0,Sec_Low = 0,Min=0,Sec=0;
  7. unsigned char Month = 0,Day = 0,Month_High = 0, Month_Low = 0,Day_Low = 0,Day_High = 0, Year_High = 0,Year_Low = 0;
  8. unsigned int Year = 0;
  9. bit Flag_GPS_OK = 0;
  10. unsigned char MaxDay = 0;
  11. bit Page = 0;
  12. unsigned char xdata Display_GPGGA_Buffer[120]={0};
  13. unsigned char xdata Display_GPRMC_Buffer[120]={0};
  14. bit Flag_OV = 0;
  15. bit Flag_Calc_GPGGA_OK = 0;
  16. bit Flag_Calc_GPRMC_OK = 0;
  17. void gps(void)
  18. {
  19.   int ii;
  20.   int jj;
  21.   Flag_OV =0;
  22.   if(RX_Buffer[0]==0x24&Flag_GPS_OK==1&RX_Buffer[1]==0x47&RX_Buffer[2]==0x50&RX_Buffer[4]==0x47&RX_Buffer[5]==0x41&RX_Buffer[6]==0x2C&RX_Buffer[17]==0x2C)                        //確定是否收到"GPGGA"這一幀數(shù)據(jù)
  23.     {
  24.         Flag_GPS_OK=0;
  25. //        Flag_OV =1;
  26.       for( ii = 0; ii < 120 ; ii++)
  27.         {
  28.           Display_GPGGA_Buffer[ii] = RX_Buffer[ii];
  29.         }
  30.
  31.
  32.     }
  33.
  34.   if(RX_Buffer[56]==0X2c&RX_Buffer[63]==0x2c&Flag_GPS_OK==1&RX_Buffer[18] == 0x41&RX_Buffer[0] == 0x24 & RX_Buffer[1] == 0x47 & RX_Buffer[2] == 0x50& RX_Buffer[3] == 0x52& RX_Buffer[4] == 0x4d& RX_Buffer[5] == 0x43)                        //確定是否收到"GPRMC"這一幀數(shù)據(jù)
  35.     {
  36.                 Flag_GPS_OK=0;
  37.                 Flag_OV =1;
  38.       for( jj = 0; jj < 120 ; jj++)
  39.         {
  40.           Display_GPRMC_Buffer[jj] = RX_Buffer[jj];
  41.         }
  42.       Year_High = Display_GPRMC_Buffer[61];
  43.       Year_Low = Display_GPRMC_Buffer[62];
  44.       Month_High = Display_GPRMC_Buffer[59];
  45.       Month_Low = Display_GPRMC_Buffer[60];
  46.       Day_High = Display_GPRMC_Buffer[57];
  47.       Day_Low = Display_GPRMC_Buffer[58];
  48.            Min_High = Display_GPRMC_Buffer[9];
  49.       Min_Low = Display_GPRMC_Buffer[10];
  50.       Sec_High = Display_GPRMC_Buffer[11];
  51.       Sec_Low = Display_GPRMC_Buffer[12];
  52.
  53. // Day = (Day_High - 0x30) * 10 + (Day_Low-0x30);                //日  加一
  54.   Month = (Month_High - 0x30) * 10 + (Month_Low - 0x30);
  55.   Year =  (Year_High - 0x30) * 10 + (Year_Low - 0x30);
  56.    Hour = ((Display_GPRMC_Buffer[7]-0x30)*10+(Display_GPRMC_Buffer[8]-0x30)+8)%24;                        //UTC時(shí)間轉(zhuǎn)換到北京時(shí)間                UTC+8
  57.       //0x30為ASCII轉(zhuǎn)換為數(shù)字
  58.            if(Hour<=7)
  59.            {
  60.             Day = (Day_High - 0x30) * 10 + (Day_Low-0x30)+1;                //日  加一
  61.            }
  62.            else
  63.            {
  64.            Day = (Day_High - 0x30) * 10 + (Day_Low-0x30);
  65.            }
  66.        Min = (Display_GPRMC_Buffer[9]-0x30)*10+(Display_GPRMC_Buffer[10]-0x30);
  67.        Sec= (Display_GPRMC_Buffer[11]-0x30)*10+(Display_GPRMC_Buffer[12]-0x30);
  68.
  69.
  70.
  71.     }
  72.
  73.   }
  74. void UTCDate2LocalDate(void)
  75. {
  76.   Day = (Day_High - 0x30) * 10 + (Day_Low-0x30) + 1;                //日  加一
  77.   Month = (Month_High - 0x30) * 10 + (Month_Low - 0x30);
  78.   Year = 2000 + (Year_High - 0x30) * 10 + (Year_Low - 0x30);
  79.
  80. }
收藏收藏3 分享淘帖 頂 踩
ID:46065 發(fā)表于 2021-2-18 17:54 | 只看該作者
GPS校時(shí)方式 要用什么模塊?
ID:689627 發(fā)表于 2021-2-19 08:48 | 只看該作者
wxxl 發(fā)表于 2021-2-18 17:54
我用的GPS模塊一直發(fā)送報(bào)文,報(bào)文包含時(shí)間和位置信息。
ID:689627 發(fā)表于 2021-2-19 08:56 | 只看該作者
4塊錢網(wǎng)上淘的拆機(jī)模塊,TTL電平串口一直發(fā)送報(bào)文
ID:46065 發(fā)表于 2021-2-19 10:46 | 只看該作者
pengyi900921 發(fā)表于 2021-2-19 08:56
能發(fā)個(gè)賣家店名嗎?
