程序- #include<reg51.h>
- #include<intrins.h>
- #include <absacc.h>
- #include <math.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define BUSY 0x80 //常量定義
- #define DATAPORT P0
- sbit ADCS =P3^5;
- sbit ADDI =P3^7;
- sbit ADDO =P3^7;
- sbit ADCLK =P3^6;
- sbit LCM_RS=P2^0;
- sbit LCM_RW=P2^1;
- sbit LCM_EN=P2^2;
- uint x1,y1,z1=0,w1,temp1;
- uchar ad_data,k,n,m,e,num,s; //采樣值存儲
- sbit beep =P3^0;
- char press_data; //標(biāo)度變換存儲單元
- unsigned char ad_alarm; //報(bào)警值存儲單元
- unsigned char press_ge=0; //顯示值百位
- unsigned char press_shifen=0; //顯示值十位
- unsigned char press_baifen=0; //顯示值個(gè)位
- unsigned char press_qianfen=0; //顯示值十分位
- uchar code str0[]={"Weight: . Kg "};
- uchar code str2[]={"Price: "};
- uchar code str3[]={"Total: "};
- uchar code table2[]={0x37,0x38,0x39,0xfd,0x34,0x35,0x36,0x78,0x31,0x32,0x33,0x2d,0x3d,0x30,0x2e,0x2b}; //鍵盤碼
- void delay(uint);
- void lcd_wait(void);
- void delay_LCM(uint); //LCD延時(shí)子程序
- void initLCM( void); //LCD初始化子程序
- void lcd_wait(void); //LCD檢測忙子程序
- void WriteCommandLCM(uchar WCLCM,uchar BusyC); //寫指令到ICM子函數(shù)
- void WriteDataLCM(uchar WDLCM); //寫數(shù)據(jù)到LCM子函數(shù)
- void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示指定坐標(biāo)的一個(gè)字符子函數(shù)
- void DisplayListChar(uchar X,uchar Y,uchar code *DData); //顯示指定坐標(biāo)的一串字符子函數(shù)
- void weishu(uint m);
- void weishu1(uint m);
- void display(void);
- uchar Adc0832(unsigned char channel);
- void alarm(void);
- void data_pro(void);
- /**********main funcation************/
- void main(void)
- delay(500); //系統(tǒng)延時(shí)500ms啟動
- //ad_data=0; //采樣值存儲單元初始化為0
- initLCM( );
- WriteCommandLCM(0x01,1); //清顯示屏
- DisplayListChar(0,0,str0);
- DisplayListChar(0,1,str2);
- while(1)
- ad_data =Adc0832(0); //采樣值存儲單元初始化為0
- alarm();
- data_pro();
- display();
- if(k==1)
- DisplayOneChar((s+7),1,table2[num-1]);
- x1=m;
- y1=n;
- y1=y1*10+x1;
- if(k=='*')
- data_pro();
- weishu(z1);
- k=0;
- if(k=='=')
- z1=z1*temp1;
- DisplayListChar(0,1,str3);
- s=0;
- weishu1(765);
- k=0;
- if(k==' ')
- WriteCommandLCM(0x80+0x40,1);
- z1=0;
- s=0; //防止清零時(shí)指針后移動
- /*********延時(shí)K*1ms,12.000mhz**********/
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++)
- for(j=0;j<100;j++);
- /**********寫指令到ICM子函數(shù)************/
- if(BusyC)
- lcd_wait();
- DATAPORT=WCLCM;
- LCM_RS=0; // 選中指令寄存器
- LCM_RW=0;
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********寫數(shù)據(jù)到LCM子函數(shù)************/
- lcd_wait( ); //檢測忙信號
- DATAPORT=WDLCM;
- LCM_RS=1; // 選中數(shù)據(jù)寄存器
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /***********lcm內(nèi)部等待函數(shù)*************/
- DATAPORT=0xff; //讀LCD前若單片機(jī)輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會有顯示邏輯黃色
- LCM_EN=1;
- LCM_RS=0;
- LCM_RW=0;
- LCM_RW=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- while(DATAPORT&BUSY)
- { LCM_EN=0;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********LCM初始化子函數(shù)***********/
- void initLCM( )
- LCM_EN=0;
- DATAPORT=0;
- delay(15);
- WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號
- delay(5);
- delay(5);
- delay(5);
- WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測忙信號
- WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測忙信號
- WriteCommandLCM(0x01,1); //清屏,檢測忙信號
- WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測忙信號
- WriteCommandLCM(0x0c,1); //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測忙信號
- TMOD=0x11;
- EA=1;
- ET1=1;
- TR1=1;
- k=0;
- x1=0;
- y1=0;
- z1=0;
- /****顯示指定坐標(biāo)的一個(gè)字符子函數(shù)****/
- Y&=0x01;
- X&=0x0f;
- if(Y)
- X|=0x40; //若y為1(顯示第二行),地址碼+0X40
- X|=0x80; //指令碼為地址碼+0X80
- WriteCommandLCM(X,1);
- WriteDataLCM(DData);
- /*******顯示指定坐標(biāo)的一串字符子函數(shù)*****/
- uchar ListLength=0;
- Y&=0x01;
- X&=0x0f;
- while(X<16)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- /*****************系統(tǒng)顯示子函數(shù)*****************/
- //DisplayListChar(0,1,str2);
- DisplayOneChar(8,0,press_ge+0x30);
- DisplayOneChar(10,0,press_shifen+0x30);
- DisplayOneChar(11,0,press_baifen+0x30);
- DisplayOneChar(12,0,press_qianfen+0x30);
- delay(1000); //穩(wěn)定顯示
- 讀ADC0832函數(shù)
- //采集并返回
- uchar Adc0832(unsigned char channel) //AD轉(zhuǎn)換,返回結(jié)果
- uchar i=0;
- uchar j;
- uint dat=0;
- uchar ndat=0;
- if(channel==0)channel=2;
- if(channel==1)channel=3;
- ADDI=1;
- _nop_();
- _nop_();
- ADCS=0;//拉低CS端
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿1
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=channel&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿2
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=(channel>>1)&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿3
- ADDI=1;//控制命令結(jié)束
- _nop_();
- _nop_();
- dat=0;
- for(i=0;i<8;i++)
- dat|=ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- ADCLK=0;//形成一次時(shí)鐘脈沖
- _nop_();
- _nop_();
- dat<<=1;
- if(i==7)dat|=ADDO;
- for(i=0;i<8;i++)
- j=0;
- j=j|ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- j=j<<7;
- ndat=ndat|j;
- if(i<7)ndat>>=1;
- ADCS=1;//拉低CS端
- ADCLK=0;//拉低CLK端
- ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
- dat<<=8;
- dat|=ndat;
- return(dat); //return ad k
- unsigned int;
- float press;
- if(0<ad_data<256)
- int vary=ad_data;
- press=(0.019531*vary);
- temp1=(int)(press*1000); //放大1000倍,便于后面的計(jì)算
- press_ge=temp1/1000; //取壓力值百位
- press_shifen=(temp1%1000)/100; //取壓力值十位
- press_baifen=((temp1%1000)%100)/10; //取壓力值個(gè)位
- press_qianfen=((temp1%1000)%100)%10; //取壓力值十分位
- /*****************報(bào)警子函數(shù)*******************/
- void alarm(void)
- if(ad_data>=256)
- beep=0; //則啟動報(bào)警
- else
- beep=1;
- uchar wei4,wei3,wei2,wei1,wei0;
- wei4=m/10000;
- wei3=m%10000/1000;
- wei2=m%1000/100;
- wei1=m%100/10;
- wei0=m%10;
- DisplayOneChar(7,1,0x30+wei4);
- DisplayOneChar(8,1,0x30+wei3);
- DisplayOneChar(10,1,0x30+wei2);
- //DisplayOneChar(10,1,'.');
- DisplayOneChar(11,1,0x30+wei1);
- DisplayOneChar(12,1,0x30+wei0);
- uchar wei5,wei4,wei3,wei2,wei1,wei0;
- wei5=m/100000;
- wei4=m%100000/10000;
- wei2=m%1000/100;
- wei1=m%100/10;
- wei0=m%10;
- DisplayOneChar(9,1,'.');
- void temer1() interrupt 3
- { uchar temp;
- EX1=0;
- P1=0xfe;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(5);
- temp=P1;
- temp=temp&0xf0;
- while(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xee:num=1;n=7;k=1,s++;break;
- case 0xde:num=2;n=8;k=1,s++;break;
- case 0xbe:num=3;n=9;k=1,s++;break;
- case 0x7e:num=4;k='/',s++;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- //DisplayOneChar((s+6),1,table2[num-1]);
- P1=0xfd;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(5);
- temp=P1;
- temp=temp&0xf0;
- while(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xed:num=5;n=4;k=1;s++;break;
- case 0xdd:num=6;n=5;k=1;s++;break;
- case 0xbd:num=7;n=6;k=1;s++;break;
- case 0x7d:num=8;k='*';s++;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- //DisplayOneChar(k+6,1,table2[num-1]);
- P1=0xfb;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(5);
- temp=P1;
- temp=temp&0xf0;
- while(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xeb:num=9;n=1;k=1;s++;break;
- case 0xdb:num=10;n=2;k=1;s++;break;
- case 0xbb:num=11;n=3;k=1;s++;break;
- case 0x7b:num=12;k='-';s++;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- // DisplayOneChar(k+6,1,table2[num-1]);
- P1=0xf7;
- temp=P1;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(5);
- temp=P1;
- temp=temp&0xf0;
- while(temp!=0xf0)
- temp=P1;
- switch(temp)
- case 0xe7:num=13;k=' ';break;
- case 0xd7:num=14;n=0;k=1;s++;;break;
- case 0xb7:num=15;k='=';s++;break;
- case 0x77:num=16;k='+';s++;;break;
- while(temp!=0xf0)
- temp=P1;
- temp=temp&0xf0;
- EX1=1;
LCD+ADC0832 電子秤.zip
2021-3-9 01:16 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
186.81 KB, 下載次數(shù): 40, 下載積分: 黑幣 -5
