查看: 1926|回復(fù): 2
我這個是用stm32通過定時器中斷驅(qū)動hcsr04,但是驅(qū)動不了
ID:660005 發(fā)表于 2021-8-6 17:22 | 顯示全部樓層 |閱讀模式
void HCSR04(void)
        GPIO_InitTypeDef GPIO_Initure;
        __HAL_RCC_GPIOB_CLK_ENABLE();//開啟GPIOB時鐘
         GPIO_Initure.Pin=GPIO_PIN_13;                         //PB13
   GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP;  //推挽輸出
   GPIO_Initure.Pull=GPIO_PULLUP;          //上拉
   GPIO_Initure.Speed=GPIO_SPEED_FREQ_HIGH;//高速
   HAL_GPIO_Init(GPIOB,&GPIO_Initure);
         GPIO_Initure.Pin=GPIO_PIN_14;                         //PB14
   GPIO_Initure.Mode=GPIO_MODE_EVT_FALLING;  //輸入
對hcsr04的定義
extern int time;
long long d=0;
int main(void)
    HAL_Init();                                     //初始化HAL庫
    Stm32_Clock_Init(RCC_PLL_MUL9);           //設(shè)置時鐘,72M
                delay_init(72);                               //初始化延時函數(shù)
                uart_init(115200);                                        //初始化串口
    HCSR04();                TIM3_Init(71,65535);
                            delay_ms(100);      //消抖                                d=time*170*0.000000001;
                        printf("距離為:%d cm\r\n",d);//打印總的距離
以上是主函數(shù)
int time=0;
TIM_HandleTypeDef TIM3_Handler;      //定時器句柄
//通用定時器3中斷初始化
//arr:自動重裝值。
//psc:時鐘預(yù)分頻數(shù)
//定時器溢出時間計算方法:Tout=((arr+1)*(psc+1))/Ft us.
//Ft=定時器工作頻率,單位:Mhz
//這里使用的是定時器3!
void TIM3_Init(u16 arr,u16 psc)
    TIM3_Handler.Instance=TIM3;                          //通用定時器3
    TIM3_Handler.Init.Prescaler=psc;                     //分頻系數(shù)
    TIM3_Handler.Init.CounterMode=TIM_COUNTERMODE_UP;    //向上計數(shù)器
    TIM3_Handler.Init.Period=arr;                        //自動裝載值
    TIM3_Handler.Init.ClockDivision=TIM_CLOCKDIVISION_DIV1;//時鐘分頻因子
    HAL_TIM_Base_Init(&TIM3_Handler);
    HAL_TIM_Base_Start_IT(&TIM3_Handler); //使能定時器3和定時器3更新中斷:TIM_IT_UPDATE
//定時器底冊驅(qū)動,開啟時鐘,設(shè)置中斷優(yōu)先級
//此函數(shù)會被HAL_TIM_Base_Init()函數(shù)調(diào)用
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef *htim)
    if(htim->Instance==TIM3)
                __HAL_RCC_TIM3_CLK_ENABLE();            //使能TIM3時鐘
                HAL_NVIC_SetPriority(TIM3_IRQn,1,3);    //設(shè)置中斷優(yōu)先級,搶占優(yōu)先級1,子優(yōu)先級3
                HAL_NVIC_EnableIRQ(TIM3_IRQn);          //開啟ITM3中斷
//定時器3中斷服務(wù)函數(shù)
void TIM3_IRQHandler(void)
    HAL_TIM_IRQHandler(&TIM3_Handler);
//回調(diào)函數(shù),定時器中斷服務(wù)函數(shù)調(diào)用
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
    if(htim==(&TIM3_Handler))
                        HAL_GPIO_WritePin(GPIOB,GPIO_PIN_12,GPIO_PIN_RESET);
//        delay_us(10);
                HAL_GPIO_WritePin(GPIOB,GPIO_PIN_12,GPIO_PIN_SET);
                delay_us(10);
       if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_14)==0)
                         TIM3->CNT=0;
                        if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_14)==1)
                                time=TIM3->CNT;
以上定時器
哪里出問題了?
ID:584195 發(fā)表于 2021-8-6 20:53 | 顯示全部樓層
中斷里面不能有delay!
ID:660005 發(fā)表于 2021-8-7 15:02 | 顯示全部樓層
zyluglugl 發(fā)表于 2021-8-6 20:53
中斷里面不能有delay!
那個問題不大吧,我修改了,它也沒有改變呀
