接受程序:
- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit MOSI = P1^5;
- sbit MISO = P1^6;
- sbit SCK = P1^7;
- sbit CE = P1^3; //模式
- sbit CSN = P1^2; //SPI en
- sbit IRQ = P3^2;
- //sbit LCD_RS = P2^0; //LCD1602操作線
- //sbit LCD_RW = P2^1;
- //sbit LCD_E = P2^2;
- sbit LED0 = P1^0;
- // SPI(nRF24L01) commands
- #define READ_REG 0x00 // Define read command to register
- #define WRITE_REG 0x20 // Define write command to register
- #define RD_RX_PLOAD 0x61 // Define RX payload register address
- #define WR_TX_PLOAD 0xA0 // Define TX payload register address
- #define FLUSH_TX 0xE1 // Define flush TX register command
- #define FLUSH_RX 0xE2 // Define flush RX register command
- #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
- #define NOP 0xFF // Define No Operation, might be used to read status register
- // SPI(nRF24L01) registers(addresses)
- #define CONFIG 0x00 // 'Config' register address
- #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
- #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
- #define SETUP_AW 0x03 // 'Setup address width' register address
- #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
- #define RF_CH 0x05 // 'RF channel' register address
- #define RF_SETUP 0x06 // 'RF setup' register address
- #define STATUS 0x07 // 'Status' register address
- #define OBSERVE_TX 0x08 // 'Observe TX' register address
- #define CD 0x09 // 'Carrier Detect' register address
- #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
- #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
- #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
- #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
- #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
- #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
- #define TX_ADDR 0x10 // 'TX address' register address
- #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
- #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
- #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
- #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
- #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
- #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
- #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
- #define TX_ADR_WIDTH 5 // 5字節(jié)寬度的發(fā)送/接收地址
- #define TX_PLOAD_WIDTH 1 // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
- //#define LED P1
- uchar TX_ADDRESS[TX_ADR_WIDTH] = {0x01,0x43,0x10,0x10,0x12};
- uchar RX_ADDRESS0[5] = {0x01,0x43,0x10,0x10,0x12}; // 定義一個靜態(tài)發(fā)送地址
- uchar RX_ADDRESS1[5]= {0x02,0x43,0x10,0x10,0x12}; //接收地址1
- uchar RX_ADDRESS2[1]= {0x03}; //接收地址2
- uchar RX_ADDRESS3[1]= {0x04}; //接收地址3
- uchar RX_ADDRESS4[1]= {0x05}; //接收地址4
- uchar RX_ADDRESS5[1]= {0x06}; //接收地址5
- uchar RX_BUF[TX_PLOAD_WIDTH];
- uchar TX_BUF[TX_PLOAD_WIDTH];
- uchar temp;
- uchar Table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- uchar bdata sta;
- sbit RX_DR = sta^6;
- sbit TX_DS = sta^5;
- sbit MAX_RT = sta^4;
- uchar Number[4];
- void init_io(void)
- CE = 0; // 待機
- CSN = 1; // SPI禁止
- SCK = 0; // SPI時鐘置低
- IRQ = 1; // 中斷復位
- //LED = 0xff; // 關(guān)閉指示燈
- void delay_ms(char x)
- int j;
- while(x--)
- j = 1000;
- while(--j);
- void delay_us(int x)
- while(x--);
- /*uchar Read_LCD1602()
- uchar busy = 0x80;
- LCD_RS = 0;
- LCD_RW = 1;
- delay_ms(1);
- LCD_E = 1;
- delay_ms(1);
- busy = P0;
- delay_ms(1);
- LCD_E = 0;
- return(busy);
- void Write_Data(uchar dat)
- while(Read_LCD1602()&0x80);
- LCD_RW = 0;
- LCD_RS = 1;
- P0 = dat;
- delay_ms(1);
- LCD_E = 1;
- delay_ms(1);
- LCD_E = 0;
- void Write_Com(uchar com)
- while(Read_LCD1602() & 0x80);
- LCD_RW = 0;
- LCD_RS = 0;
- P0 = com;
- delay_ms(1);
- LCD_E = 1;
- delay_ms(1);
- LCD_E = 0;
- void Write_Add_Dat(uchar add, uchar dat)
- Write_Com(add);
- Write_Data(dat);
- void LCD_Init()
- Write_Com(0x38);
- Write_Com(0x0c);
- Write_Com(0x06);
- Write_Com(0x01);
- uchar SPI_RW(uchar byte)
- uchar i;
- for(i=0; i<8; i++) // 循環(huán)8次
- MOSI = (byte & 0x80); // byte最高位輸出到MOSI
- byte <<= 1; // 低一位移位到最高位
- SCK = 1; // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時從MISO輸出1位數(shù)據(jù)
- byte |= MISO; // 讀MISO到byte最低位
- SCK = 0; // SCK置?
- return(byte); // 返回讀出的一字節(jié)
- uchar SPI_RW_Reg(uchar reg, uchar value)
- uchar status;
- CSN = 0; // CSN置低,開始傳輸數(shù)據(jù)
- status = SPI_RW(reg); // 選擇寄存器,同時返回狀態(tài)字
- SPI_RW(value); // 然后寫數(shù)據(jù)到該寄存器
- CSN = 1; // CSN拉高,結(jié)束數(shù)據(jù)傳輸
- return(status); // 返回狀態(tài)寄存器
- uchar SPI_Read(uchar reg)
- uchar reg_val;
- SPI_RW(reg); // 選擇寄存器
- reg_val = SPI_RW(0); // 然后從該寄存器讀數(shù)據(jù)
- return(reg_val); // 返回寄存器數(shù)據(jù)
- uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes)
- uchar status, i;
- for(i=0; i<bytes; i++)
- pBuf[ i] = SPI_RW(0); // 逐個字節(jié)從nRF24L01讀出
- uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
- uchar status, i;
- SPI_RW(pBuf[ i]); // 逐個字節(jié)寫入nRF24L01
- void RX_Mode(void)
- CE = 0;// 接收設(shè)備接收通道0使用和發(fā)送設(shè)備相同的發(fā)送地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);//寫接收通道0的接收地址,與發(fā)送地址相同
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P1, RX_ADDRESS1, TX_ADR_WIDTH); //寫接收通道1的接收地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P2, RX_ADDRESS2, 1);//寫接收通道2的接收地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P3, RX_ADDRESS3, 1);//寫接收通道3的接收地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P4, RX_ADDRESS4, 1);//寫接收通道4的接收地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P5, RX_ADDRESS5, 1);//寫接收通道5的接收地址
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0選擇和發(fā)送通道相同有效數(shù)據(jù)寬度,32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + RX_PW_P1, TX_PLOAD_WIDTH);//32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + RX_PW_P2, TX_PLOAD_WIDTH);//32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + RX_PW_P3, TX_PLOAD_WIDTH);//32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + RX_PW_P4, TX_PLOAD_WIDTH);//32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + RX_PW_P5, TX_PLOAD_WIDTH);//32字節(jié)長度
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x3f); // 使能所有接收通道自動應答
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x3f); // 使能所有接收通道
- SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 選擇射頻通道0x40
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 數(shù)據(jù)傳輸率1Mbps,發(fā)射功率0dBm,低噪聲放大器增益
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校驗,上電
- SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a); // 自動重發(fā)延時等待250us+86us,自動重發(fā)10次
- CE = 1; // 拉高CE啟動接收設(shè)備
- delay_us(200);
- uchar Check_ACK(bit clear)
- while(IRQ);
- sta = SPI_RW(NOP); // 返回狀態(tài)寄存器
- if(MAX_RT)
- if(clear) // 是否清除TX FIFO,沒有清除在復位MAX_RT中斷標志后重發(fā)
- SPI_RW(FLUSH_TX);
- SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中斷標志
- IRQ = 1;
- if(TX_DS)
- return(0x00);
- else
- return(0xff);
- unsigned char nRF24L01_RxPacket(unsigned char *RX_BUF)
- unsigned char revale=0;
- //SetRX_Mode();
- sta = SPI_Read(STATUS); //read register STATUS's value
- temp = sta;
- if(RX_DR) //if receive data ready (RX_DR) interrupt
- SPI_Read_Buf(RD_RX_PLOAD,RX_BUF,TX_PLOAD_WIDTH); // read receive payload from RX_FIFO buffer
- revale =1;
- //we have receive data
- SPI_RW_Reg(WRITE_REG+STATUS,sta); // clear RX_DR or TX_DS or MAX_RT interrupt flag
- return revale;
- void main(void)
- uchar reveal;
- init_io();
- RX_Mode(); // 初始化IO
- // 設(shè)置為接收模式
- //LCD_Init();
- while(1)
- reveal=nRF24L01_RxPacket(RX_BUF);
- if(reveal==1) // 接受完成
- LED0 = ~LED0;
- reveal = 0;
- /* Write_Add_Dat(0x80,0x30+RX_BUF[0]/100);
- Write_Add_Dat(0x81,0x30+RX_BUF[0]%100/10);
- Write_Add_Dat(0x82,0x30+RX_BUF[0]%10);
- Write_Add_Dat(0x85,0x30+RX_BUF[1]/100);
- Write_Add_Dat(0x86,0x30+RX_BUF[1]%100/10);
- Write_Add_Dat(0x87,0x30+RX_BUF[1]%10);
- Write_Add_Dat(0x8A,0x30+RX_BUF[2]/100);
- Write_Add_Dat(0x8B,0x30+RX_BUF[2]%100/10);
- Write_Add_Dat(0x8C,0x30+RX_BUF[2]%10);
- Number[0]=RX_BUF[0];
- P2=0XFD;
- P0=Table[RX_BUF[0]/100];
- delay_ms(2);
- P2=0XFB;
- P0=Table[RX_BUF[0]%100/10];
- delay_ms(2);
- P2=0XF7;
- P0=Table[RX_BUF[0]%10];
- delay_ms(2);
- P2=0XFE;
- delay_ms(2);
- P2=0X7F;
- delay_ms(2);
- P2=0XBF;
- delay_ms(2);
復制代碼 |
