main.c文件: #include "stm32f10x_it.h"
#include"hw_conf.h"
#include "spi_flash.h"
void delay(int d); u8 DataByte=0; u8 Tx_Buffer[] = {0x72,0x62,0x02,0x78,0x60,0x96,0x86,0x79,0x85,0x24,0x36,0x48};
u8 Rx_Buffer[BufferSize]; vu32 FLASH_ID = 0; int main(void)
#ifdef DEBUG
debug();
#endif Setup_System();
SPI_FLASH_Init();
//SPI_FLASH_ByteWrite(0x72, 0x01F01F);
//DataByte = SPI_FLASH_ByteRead(0x01F01F);
//DataByte = SPI_Flash_ReadStatusRegister();
//SPI_FLASH_SectorErase(0x01F01F);
//SPI_FLASH_BulkErase(0x01F01F);
//SPI_FLASH_ChipErase();
//DataByte = SPI_FLASH_FasttRead(0x01F01F);
//DataByte = SPI_FLASH_ReadDeviceID();
//SPI_FLASH_ReadManuID_DeviceID(0x000000);
//SPI_FLASH_ReadJedecID();
SPI_FLASH_PageWrite(Tx_Buffer, 0x01F01F, 10);
SPI_FLASH_BufferRead(Rx_Buffer, 0x01F01F, 4);
while (1)
if(Rx_Buffer[0]==0x72)
GPIO_WriteBit(GPIOC,GPIO_Pin_6,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_6)));
delay(100);
if(Rx_Buffer[1]==0x62)
GPIO_WriteBit(GPIOC,GPIO_Pin_7,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_7)));
delay(100);
if(Rx_Buffer[2]==0x02)
GPIO_WriteBit(GPIOC,GPIO_Pin_4,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_4)));
delay(100);
if(Rx_Buffer[3]==0x78)
GPIO_WriteBit(GPIOC,GPIO_Pin_5,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_5)));
delay(100);
void delay(int d)
int i = 0;
for ( ;d;--d)
for (i = 0;i<10000;i++);
Flash.c文件: #include "stm32f10x_spi.h"
#define SPI_FLASH_PageSize 256 void SPI_FLASH_Init(void)
SPI_FLASH_CS_HIGH();
SPI_Flash_WP_HIGH();
SPI_Flash_HOLD_HIGH();
} void SPI_FLASH_WriteEnable(void)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(WriteEnable);
} void SPI_FLASH_WriteDisable(void)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(WriteDisable);
} u8 SPI_Flash_ReadStatusRegister(void)
u8 StatusRegister = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReadStatusRegister);
StatusRegister = SPI_FLASH_ReceiveByte();
return StatusRegister;
} void SPI_Flash_WriteStatusRegister(u8 Byte)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(WriteStatusRegister);
SPI_FLASH_SendByte(Byte);
} u8 SPI_FLASH_SendByte(u8 byte)
while(SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE) == RESET);
SPI_SendData(SPI1, byte); while(SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET);
return SPI_ReceiveData(SPI1);
} u8 SPI_FLASH_ReceiveByte(void)
return (SPI_FLASH_SendByte(Dummy_Byte));
} u8 SPI_FLASH_ByteRead(u32 ReadAddr)
u32 Temp = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(Read_Data);
SPI_FLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((ReadAddr& 0xFF00) >> 8);
SPI_FLASH_SendByte(ReadAddr & 0xFF);
Temp = SPI_FLASH_ReceiveByte();
//Temp = SPI_FLASH_SendByte(Dummy_Byte);
return Temp;
} u8 SPI_FLASH_FasttRead(u32 ReadAddr)
u32 Temp = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(FastReadData);
return Temp;
} void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReadAddr & 0xFF); while(NumByteToRead--)
*pBuffer = SPI_FLASH_ReceiveByte();
pBuffer++;
} void SPI_FLASH_SectorErase(u32 SectorAddr)
SPI_FLASH_WriteEnable();
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(SectorErace);
SPI_FLASH_SendByte((SectorAddr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((SectorAddr & 0xFF00) >> 8);
SPI_FLASH_SendByte(SectorAddr & 0xFF);
SPI_FLASH_WaitForWriteEnd();
} void SPI_FLASH_BulkErase(u32 BlockAddr)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(BlockErace);
SPI_FLASH_SendByte((BlockAddr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((BlockAddr & 0xFF00) >> 8);
SPI_FLASH_SendByte(BlockAddr & 0xFF);
} void SPI_FLASH_ChipErase(void)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ChipErace);
} void SPI_FLASH_PowerDown()
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(Power_Down);
} void SPI_FLASH_ReleasePowerDown()
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReleacePowerDown);
} u8 SPI_FLASH_ReadDeviceID(void)
u8 DeviceID = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReadDeviceID);
DeviceID = SPI_FLASH_ReceiveByte();
return DeviceID;
} u16 SPI_FLASH_ReadManuID_DeviceID(u32 ReadManu_DeviceID_Addr)
u16 ManuID_DeviceID = 0;
u8 ManufacturerID = 0, DeviceID = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReadManuIDDeviceID);
SPI_FLASH_SendByte((ReadManu_DeviceID_Addr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((ReadManu_DeviceID_Addr & 0xFF00) >> 8);
SPI_FLASH_SendByte(ReadManu_DeviceID_Addr & 0xFF);
if(ReadManu_DeviceID_Addr==1)
ManufacturerID = SPI_FLASH_ReceiveByte();
ManuID_DeviceID = ((ManufacturerID<<8) | DeviceID);
return ManuID_DeviceID;
u32 SPI_FLASH_ReadJedecID(void)
u32 JEDECID = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(ReadJedec_ID);
Temp0 = SPI_FLASH_ReceiveByte();
Temp1 = SPI_FLASH_ReceiveByte();
Temp2 = SPI_FLASH_ReceiveByte();
JEDECID = (Temp0 << 16) | (Temp1 << 8) | Temp2;
return JEDECID;
void SPI_FLASH_ByteWrite(u8 Byte, u32 WriteAddr)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(Page_Program);
SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
SPI_FLASH_SendByte(WriteAddr & 0xFF);
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
SPI_FLASH_CS_LOW();
while(NumByteToWrite--)
SPI_FLASH_SendByte(*pBuffer);
pBuffer++;
} void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0; Addr = WriteAddr % SPI_FLASH_PageSize;
count = SPI_FLASH_PageSize - Addr;
NumOfPage = NumByteToWrite / SPI_FLASH_PageSize;
NumOfSingle = NumByteToWrite % SPI_FLASH_PageSize;
if(Addr == 0) /* WriteAddr is SPI_FLASH_PageSize aligned */
if(NumOfPage == 0) /* NumByteToWrite < SPI_FLASH_PageSize */
SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumByteToWrite);
else /* NumByteToWrite > SPI_FLASH_PageSize */
while(NumOfPage--)
SPI_FLASH_PageWrite(pBuffer, WriteAddr, SPI_FLASH_PageSize);
WriteAddr += SPI_FLASH_PageSize;
pBuffer += SPI_FLASH_PageSize;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumOfSingle);
else /* WriteAddr is not SPI_FLASH_PageSize aligned */
if(NumOfPage== 0) /* NumByteToWrite < SPI_FLASH_PageSize */
if(NumOfSingle > count) /* (NumByteToWrite + WriteAddr) > SPI_FLASH_PageSize */
temp = NumOfSingle - count;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, count);
WriteAddr += count;
pBuffer += count;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, temp);
NumByteToWrite -= count;
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
if(NumOfSingle != 0)
void SPI_FLASH_WaitForWriteEnd(void)
u8 FLASH_Status = 0;
SPI_FLASH_CS_LOW();
do
FLASH_Status = SPI_FLASH_SendByte(Dummy_Byte);
} while((FLASH_Status & WriteStatusRegister) == SET); SPI_FLASH_CS_HIGH();
} Flash.h文件:#include "stm32f10x_lib.h"
#ifndef __SPI_FLASH_H
#define __SPI_FLASH_H #define BufferSize (countof(Tx_Buffer)-1)
#define countof(a) (sizeof(a) / sizeof(*(a)))
#define Dummy_Byte 0xA5
#define SPI_FLASH_CS_LOW() GPIO_ResetBits(GPIOA, GPIO_Pin_4)
#define SPI_FLASH_CS_HIGH() GPIO_SetBits(GPIOA, GPIO_Pin_4)
#define SPI_Flash_WP_LOW() GPIO_ResetBits(GPIOC, GPIO_Pin_0)
#define SPI_Flash_WP_HIGH() GPIO_SetBits(GPIOC, GPIO_Pin_0) #define SPI_Flash_HOLD_LOW() GPIO_ResetBits(GPIOC, GPIO_Pin_1)
#define SPI_Flash_HOLD_HIGH() GPIO_SetBits(GPIOC, GPIO_Pin_1)
#define WriteEnable 0x06 //寫(xiě)使能,設(shè)置狀態(tài)寄存器
#define WriteDisable 0x04 //寫(xiě)禁止
#define ReadStatusRegister 0x05 //讀狀態(tài)寄存器
#define WriteStatusRegister 0x01 //寫(xiě)狀態(tài)寄存器
#define Read_Data 0x03 //讀取存儲(chǔ)器數(shù)據(jù)
#define FastReadData 0x0B //快速讀取存儲(chǔ)器數(shù)據(jù)
#define FastReadDualOutput 0x3B //快速雙端口輸出方式讀取存儲(chǔ)器數(shù)據(jù)
#define Page_Program 0x02 //頁(yè)面編程--寫(xiě)數(shù)據(jù)
#define BlockErace 0xD8 //塊擦除
#define SectorErace 0x20 //扇區(qū)擦除
#define ChipErace 0xC7 //片擦除
#define Power_Down 0xB9 //掉電模式 #define ReleacePowerDown 0xAB //退出掉電模式
#define ReadDeviceID 0xAB //獲取設(shè)備ID信息
#define ReadDeviceID 0xAB //退出掉電模式、設(shè)備ID信息
#define ReadManuIDDeviceID 0x90 //讀取制造廠(chǎng)商ID信息和設(shè)備ID信息
#define ReadJedec_ID 0x9F //JEDEC的ID信息
void SPI_FLASH_Init(void);
void SPI_FLASH_WriteEnable(void);
void SPI_FLASH_WriteDisable(void);
u8 SPI_Flash_ReadStatusRegister(void);
void SPI_Flash_WriteStatusRegister(u8 Byte); u8 SPI_FLASH_SendByte(u8 byte);
u8 SPI_FLASH_ReceiveByte(void); u8 SPI_FLASH_ByteRead(u32 ReadAddr);
u8 SPI_FLASH_FasttRead(u32 ReadAddr);
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead);
void SPI_FLASH_SectorErase(u32 SectorAddr);
void SPI_FLASH_BulkErase(u32 BlockAddr);
void SPI_FLASH_ChipErase(void); void SPI_FLASH_PowerDown();
void SPI_FLASH_ReleasePowerDown();
u8 SPI_FLASH_ReadDeviceID(void);
u16 SPI_FLASH_ReadManuID_DeviceID(u32 ReadManu_DeviceID_Addr);
u32 SPI_FLASH_ReadJedecID(void); void SPI_FLASH_ByteWrite(u8 Byte, u32 WriteAddr);
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite);
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite); void SPI_FLASH_WaitForWriteEnd(void);
#endif
