查看: 6795|回復(fù): 1
四位數(shù)碼管9999秒倒計時程序
ID:75005 發(fā)表于 2015-3-21 16:39 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uint numt,num;
uint ge,shi,bai,qian;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delayms(uint xms)
  int i,j;
  for(i=xms;i>0;i--)
     for(j=110;j>0;j--);
  num=9999;
  TMOD=0x01;
  EA=1;
  ET0=1;
  TH0=(65536-45872)/256;
  TH1=(65536-45872)%256;
  TR0=1;
      ge=num%10;
      shi=num%1000%100/10;
      bai=num%1000/100;
      qian=num/1000;
      dula=1;
      P0=table[qian];
      dula=0;
      P0=0xff;
      wela=1;
      P0=0xfb;
      wela=0;
      delayms(1);
      dula=1;
      P0=table[bai];
      dula=0;
      P0=0xff;
      wela=1;
      P0=0xf7;
      wela=0;
      delayms(1);
      dula=1;
      P0=table[shi];
      dula=0;
      P0=0xff;
      wela=1;
      P0=0xef;
      wela=0;
      delayms(1);
      dula=1;
      P0=table[ge];
      dula=0;
      P0=0xff;
      wela=1;
      P0=0xdf;
      wela=0;
      delayms(1);
void T0time() interrupt 1
  numt++;
  if(numt==20)
      numt=0;
       num- -;
       if(num==0)
         num=9999;
ID:54731 發(fā)表于 2015-3-24 16:05 | 顯示全部樓層
請問樓主有線路圖嗎?還有是不是郭老師的?
