查看: 3290|回復(fù): 0
讀/寫(xiě)atmega8515內(nèi)部EEPROM的例子
ID:75926 發(fā)表于 2015-4-3 01:04 | 顯示全部樓層 |閱讀模式
  1. /**************************************************************
  2. ;eeprom.c
  3. ;讀/寫(xiě)atmega8515內(nèi)部EEPROM的例子
  4. ;將數(shù)據(jù)0....9寫(xiě)入eeprom中,再讀出用數(shù)碼管顯示出來(lái)
  5. ***************************************************************/
  6. #include "avr/io.h"
  7. #include "avr/eeprom.h"
  8. #define uchar unsigned char
  9. #define Hidden 16
  10. uchar DispTab[17]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
  11. uchar BitTab[6]={0x7F,0xBF,0xDF,0xEF,0xF7,0xFB};
  12. uchar DispBuf[6]; //顯示緩沖區(qū)
  13. unsigned char Counter=0;
  14. static void io_init(void)
  15. {
  16. // PortA
  17. PORTA = 0xff;
  18. DDRA = 0xff;
  19. // PortB
  20. PORTB = 0x0;
  21. DDRB = 0x0;
  22. // PortC
  23. PORTC = 0xfc;
  24. DDRC = 0xfc;
  25. // PortD
  26. PORTD = 0x0;
  27. DDRD = 0x0;
  28. }
  29. void mDelay(uint16_t DelayTim)
  30. { uint16_t i;
  31. for(;DelayTim>0;DelayTim--)
  32. { for(i=0;i<600;i++)
  33. {;}
  34. }
  35. }
  36. void disp()
  37. { static uchar i;
  38. uchar tmp;
  39. if(++i>=6)
  40. i=0;
  41. PORTC=0xff; //關(guān)閉顯示
  42. tmp=DispBuf[i];
  43. PORTA=DispTab[tmp];
  44. tmp=BitTab[i];
  45. PORTC=tmp;
  46. mDelay(1); //延時(shí)1ms
  47. }
  48. int main(void)
  49. { unsigned int Count=0;
  50. unsigned char Addr=1; //向地址1里面寫(xiě)數(shù)字
  51. uint8_t temp=0;
  52. io_init();
  53. DispBuf[0]=Hidden;
  54. DispBuf[1]=Hidden;
  55. DispBuf[2]=Hidden;
  56. DispBuf[3]=Hidden;
  57. DispBuf[4]=0; //次低位顯示0
  58. while(1)
  59. {
  60. temp=eeprom_read_byte (Addr);
  61. DispBuf[5]=temp;
  62. if(++Count==1000)
  63. { Count=0;
  64. Counter++;
  65. eeprom_write_byte(Addr,Counter);
  66. }
  67. if(Counter>=10)
  68. Counter=0; //計(jì)數(shù)值在0~9之間循環(huán)
  69. disp(); //調(diào)用顯示程序
  70. }
  71. }
相關(guān)帖子
