查看: 2226|回復(fù): 1
(改1)矩陣鍵盤16*16(用了延時函數(shù))低效率
ID:76556 發(fā)表于 2015-4-10 02:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 nius 于 2015-4-10 02:49 編輯
單片機電路圖:http://www.torrancerestoration.com/f/ks51.pdf
#include<reg51.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit KEY_IN1 = P2^4;
sbit KEY_IN2 = P2^5;
sbit KEY_IN3 = P2^6;
sbit KEY_IN4 = P2^7;
sbit KEY_OUT1 = P2^3;
sbit KEY_OUT2 = P2^2;
sbit KEY_OUT3 = P2^1;
sbit KEY_OUT4 = P2^0;
void timer(unsigned int x)
unsigned int s,d;
for(s=0;s<110;s++)
        for(d=0;d<x;d++);
unsigned char code LedChar[]={0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E};
        ENLED = 0;
        ADDR3 = 1;
        ADDR2 = 0;
        ADDR1 = 0;
        ADDR0 = 0;
        P0 = LedChar[0];
        KEY_OUT4=1;
        P2=0xff;
        unsigned Num1,ss;
        switch(Num1)
                case 0:        KEY_OUT4=1;KEY_OUT1=0;
                                 if(KEY_IN1==0){timer(10);if(KEY_IN1==0){ ss=0;while(!KEY_IN1);};};
                                 if(KEY_IN2==0){timer(10);if(KEY_IN2==0){ss=1;while(!KEY_IN2);}};
                                 if(KEY_IN3==0){timer(10);if(KEY_IN3==0){ss=2;while(!KEY_IN3);};};
                                  if(KEY_IN4==0){timer(10);if(KEY_IN4==0){ss=3;while(!KEY_IN4);};};
                break;
                case 1:        KEY_OUT1=1;KEY_OUT2=0;
                                 if(KEY_IN1==0){timer(10);if(KEY_IN1==0){ss=4;while(!KEY_IN1);};};
                                 if(KEY_IN2==0){timer(10);if(KEY_IN2==0){ss=5;while(!KEY_IN2);};};
                                 if(KEY_IN3==0){timer(10);if(KEY_IN3==0){ss=6;while(!KEY_IN3);};};
                                 if(KEY_IN4==0){timer(10);if(KEY_IN4==0){ss=7;while(!KEY_IN4);};};
                break;
                case 2:        KEY_OUT2=1;KEY_OUT3=0;
                                 if(KEY_IN1==0){timer(10);if(KEY_IN1==0){ss=8;while(!KEY_IN1);};};
                                 if(KEY_IN2==0){timer(10);if(KEY_IN2==0){ss=9;while(!KEY_IN2);};};
                                 if(KEY_IN3==0){timer(10);if(KEY_IN3==0){ss=10;while(!KEY_IN3);};};
                                 if(KEY_IN4==0){timer(10); if(KEY_IN4==0){ss=11;while(!KEY_IN4);};};
                break;
                case 3:        KEY_OUT3=1;KEY_OUT4=0;
                                    if(KEY_IN1==0){timer(10);if(KEY_IN1==0){ss=12;while(!KEY_IN1);};};
                                 if(KEY_IN2==0){timer(10);if(KEY_IN2==0){ss=13;while(!KEY_IN2);};};
                                 if(KEY_IN3==0){timer(10);if(KEY_IN3==0){ss=14;while(!KEY_IN3);};};
                                 if(KEY_IN4==0){timer(10);if(KEY_IN4==0){ss=15;while(!KEY_IN4);};};
                break;
        P0 = LedChar[ss];
        Num1++;
        Num1=Num1&0x03;
這個程序跟上一個程序功能一樣但是改的更簡潔了一點
設(shè)計者:薛羽豪
ID:76556 發(fā)表于 2015-4-10 02:47 | 只看該作者
這個程序跟上一個程序功能一樣,但是整個程序改的更簡潔了一點
運行效率有了稍微的提高(只要用了延時函數(shù)效率就一定大大降低,但是這種低級算法怎么改也無法解決程序運行一次占用的時間較長的問題)
