電子密碼鎖主函數(shù)
#include<reg51.h>
#include<12864.h>
#include<keypad.h>
#include<24C01.h>
sbit LED1=P1^5;
sbit LED2=P1^6;
sbit INIT=P2^2;
sbit SOUND=P1^7;
uchar idata key[6]={0,0,0,0,0,0};
uchar idata iic[6]={0,1,2,3,4,5};
void press(uchar *s)
uchar dat;
P3=0xf0; //保存第一位密碼
while(P3==0xf0);
dat=key_scan();
if((dat!=0x0a)&&(dat!=0x0b))
{ *s=dat;
Left();
star_12864(star,0x05,16);
s++;
P3=0xf0; //保存第二位密碼
while(P3==0xf0);
dat=key_scan();
{ *s=dat;
Left();
star_12864(star,0x05,24);
s++;
P3=0xf0; //保存第三位密碼
while(P3==0xf0);
dat=key_scan();
{ *s=dat;
Left();
star_12864(star,0x05,32);
s++;
P3=0xf0; //保存第四位密碼
while(P3==0xf0);
dat=key_scan();
{ *s=dat;
Left();
star_12864(star,0x05,40);
s++;
P3=0xf0; //保存第五位密碼
while(P3==0xf0);
dat=key_scan();
{ *s=dat;
Left();
star_12864(star,0x05,48);
s++;
P3=0xf0; //保存第六位密碼
while(P3==0xf0);
dat=key_scan();
{ *s=dat;
Left();
star_12864(star,0x05,56);
do{P3=0xf0; //鍵入Enter鍵盤繼續(xù)執(zhí)行下面語句,否則等待
while(P3==0xf0);
dat=key_scan();
}while(dat!=0x0b);
void Delay10ms(void) //延時10ms
uint i,j,k;
for(i=5;i>0;i--)
for(j=4;j>0;j--)
for(k=248;k>0;k--);
uchar dat;
uchar i=0,j=0,k;
uchar x;
LED1=1;
LED2=1;
SOUND=0;
INIT=1;
if(INIT==0) //密碼初始化
x=SendB(iic,0x50,6);
Delay10ms();
} //首先從IIC器件中讀出密碼以供下面輸入密碼進(jìn)行比較
x=ReadB(iic,0x50,6);
Init_12864();
for(i=0;i<150;i++){Delay10ms();}
//**********************************若密碼不正確,循環(huán)執(zhí)行do{}while()********************************************
do{
LED1=1;
System(); //顯示:"請輸入密碼"字幕
press(key);
if((key[0]==iic[0])&&(key[1]==iic[1])&&(key[2]==iic[2])&&(key[3]==iic[3])&&(key[4]==iic[4])&&(key[5]==iic[5])) //密碼比較,若密碼正確責(zé)進(jìn)入系統(tǒng),若密碼不正確則顯示密碼錯誤,重新輸入密碼
true();
do
P3=0xf0; //鍵入1或2繼續(xù)執(zhí)行下面語句,否則等待
while(P3==0xf0);
dat=key_scan();
}while(dat!=0x01&&dat!=0x02);
if(dat==1) //開鎖
LED1=0;
unlock();
for(i=0;i<100;i++){Delay10ms();}
continue;
if(dat==2) //修改密碼
do{
System();
press(key);
again();
press(iic);
succeed(); //修改密碼成功
Delay10ms();
Delay10ms();
x=ReadB(iic,0x50,6);break;
else //修改密碼不成功,重新修改
repeat();
}while(1);
else //密碼不正確,重新輸入密碼
j++;
if(j==3)
for(i=0;i<8;i++)
LED2=0;
for(k=0;k<5;k++){Delay10ms();}
LED2=1;
j=0;
error();
for(i=0;i<50;i++){Delay10ms();}
}while(1);
