查看: 2506|回復: 1
將18b20中采集的溫度如何寫進12864,急!
ID:85085 發(fā)表于 2015-7-8 15:21 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit T_IO=P2^1;
sbit T_RST=P2^0;
sbit T_CLK=P2^2;
sbit k1=P2^3;
sbit k2=P2^4;
sbit shu=P2^5;
sbit k3=P2^6;
sbit D=P2^7;
sbit rs=P1^0; //數(shù)據(jù)/指令選擇
sbit rw=P1^1; //讀寫選擇
sbit e=P1^2;  //讀寫使能
sbit psb=P1^3; //串并口選擇
void delay(uint z)
    uint u,a0;
    for(u=z;u>0;u--)
        for(a0=124;a0>0;a0--);
uchar code tables[]="新的一天,新的開始,早睡早起身體好!";
uchar code table[]="0123456789";
uchar code we[]="年月日星期溫度*C:.";
uchar code uu[]="定時小時制鈴聲";
uchar miao,fen,shi,yue,ri,nian,xq,
                        eshi,efen,emiao,dshi,dfen,dmiao,count,time,temp;
uchar nian1,nian2,yue1,yue2,ri1,ri2,y,c,pp,mb,j,sc,fp,ko,
        shi1,shi2,fen1,fen2,miao1,miao2;
uchar w1,w2,w3,m1,nb,op,ss,u,vv,s1,aa,w,x,k,m,cb;
uint a;
uchar code week_code[]={0,3,3,6,1,4,6,2,5,0,3,5};
void Write1302(unsigned char ); //向1302寫一個字節(jié)數(shù)據(jù)
void WriteSet1302(unsigned char ,unsigned char );//根據(jù)命令字,向1302寫一個字節(jié)數(shù)據(jù)
unsigned char Read1302(void);//從1302讀一個字節(jié)數(shù)據(jù)
unsigned  char  ReadSet1302(unsigned char Cmd);//根據(jù)命令字從1302讀取一個字節(jié)數(shù)據(jù)
void InitDS1302(void);//初始化1302
void dingshi();
void xiao();
void xiaoshi();
void sh();
void Conver_week()
        uchar temp1,temp2,year,month,day;
        year=nian&0x7f;
        month=yue;
        day=ri;
        if(nian>>7==0)
                year+=0x64;
        } //如果為21世紀,年份數(shù)加100
        temp1=year/0x4; //所過閏年數(shù)只算1900年之后的
        temp2=(year+temp1)%0x7; //為節(jié)省資源,先進行一次取余,避免數(shù)大于0xff
        temp2=temp2+day+week_code[month-1];
        if(year%0x4==0&&month<3)temp2-=1; //如果是閏年但不到3月則減一天
        xq=temp2%0x7; //將星期數(shù)據(jù)寫到指定星期變量Tim[9]
void Write1302(uchar dat)//向1302寫指令
    uchar i;
    T_CLK=0;            //拉低T_CLK,為脈沖上升沿寫入數(shù)據(jù)做好準備
    for(i=0;i<8;i++)      //連續(xù)寫8個二進制位數(shù)據(jù)
        T_IO=dat&0x01;    //取出dat的第0位數(shù)據(jù)寫入1302
        T_CLK=1;           //上升沿寫入數(shù)據(jù)
        T_CLK=0;           //重新拉低T_CLK,形成脈沖
        dat>>=1;          //將dat的各數(shù)據(jù)位右移1位,準備寫入下一個數(shù)據(jù)位
void WriteSet1302(uchar Cmd,uchar dat)
    T_RST=0;           //禁止數(shù)據(jù)傳遞
    T_CLK=0;          //確保寫數(shù)居前T_CLK被拉低
    T_RST=1;           //啟動數(shù)據(jù)傳輸
    Write1302(Cmd);  //寫入命令字
    Write1302((dat/10<<4)|(dat%10));  //寫數(shù)據(jù)
    T_CLK=1;          //將時鐘電平置于已知狀態(tài)
uchar Read1302(void)
    uchar i,dat;
    for(i=0;i<8;i++)   //連續(xù)讀8個二進制位數(shù)據(jù)
        dat>>=1;       //將dat的各數(shù)據(jù)位右移1位,因為先讀出的是字節(jié)的最低位
        if(T_IO==1)    //如果讀出的數(shù)據(jù)是1
        dat|=0x80;    //將1取出,寫在dat的最高位
        T_CLK=1;       //將T_CLK置于高電平,為下降沿讀出
        T_CLK=0;       //拉低T_CLK,形成脈沖下降沿
    return dat;        //將讀出的數(shù)據(jù)返回
uchar  ReadSet1302(uchar Cmd)
    uchar temp,dat1,dat2;
    T_RST=0;                 //拉低T_RST
    temp=Read1302();       //讀出數(shù)據(jù)
    dat1=temp/16;        //16進制轉(zhuǎn)成BCD
    dat2=temp%16;
    temp=dat1*10+dat2;   //轉(zhuǎn)換成10進制數(shù)字
    return (temp);          //將讀出的數(shù)據(jù)返回
void delay50us(uint t)
        uint j;
        for(t;t>0;t--)
                for(j=19;j>0;j--);
void delay50ms(uint t)
        uint j;
        for(;t>0;t--)
                for(j=6245;j>0;j--);
void w12864com(uint com)
        rw=0;
        rs=0;
        delay50us(1);
        P0=com;
        e=1;
        delay50us(10);
        e=0;
        delay50us(2);
void w12864dat(uint dat)
        rw=0;
        rs=1;
        delay50us(1);
        P0=dat;
        e=1;
        delay50us(10);
        e=0;
        delay50us(2);
void initinal()
        delay50ms(2);
        w12864com(0x30);
        delay50us(4);
        w12864com(0x30);
        delay50us(4);
        w12864com(0x0c);
        delay50us(4);
        w12864com(0x01);
        delay50us(240);
        w12864com(0x06);
        delay50us(10);
void display()
        uchar i;
        w12864com(0x00);
        delay(2);
        w12864com(0x80);//
        w12864dat(table[2]);
        w12864dat(table[0]);
        w12864com(0x82);//年
        for(i=0;i<2;i++)
                w12864dat(we[i]);
        w12864com(0x84);//月
        for(i=0;i<2;i++)
                w12864dat(we[i+2]);
        w12864com(0x86);//日
        for(i=0;i<2;i++)
                w12864dat(we[i+4]);
        w12864com(0x88);//星期
        for(i=0;i<4;i++)
                w12864dat(we[i+6]);
        w12864com(0x9b);//溫度
                for(i=0;i<4;i++)
                        w12864dat(we[i+10]);
        w12864com(0x9f);//*C
                for(i=0;i<2;i++)
                        w12864dat(we[i+12]);
        w12864com(0x93);//:::
        for(i=0;i<1;i++)
                w12864dat(we[i+16]);
        w12864com(0x95);//:::
        for(i=0;i<1;i++)
uchar w1,w2,w3,m1;
void yan(uchar a)
        while(a--);
void fuwei()
        shu=1;
        shu=0;
        yan(60);
        shu=1;
        yan(8);
        while(!shu);
void xie_byte(uchar a)
        uchar i=0;
        for(i=8;i>0;i--)
                shu=1;
                _nop_();_nop_();
                shu = 0;
                _nop_();
                shu = a&0x01;
                yan(9);
                a>>=1;
uchar du_byte()
        uchar i,m;
        for(i=0;i<8;i++)
                shu=1;
                _nop_();_nop_();
                shu = 0; // 給脈沖信號
                m>>=1;
                _nop_();
                shu=1; // 給脈沖信號
                yan(1);
                if(shu)
                m|=0x80;
                yan(9);
        return m;
void jingdu()
        fuwei();
        xie_byte(0xfe);
        xie_byte(0xff);
        xie_byte(0xff);
        xie_byte(0x3f);
uchar du_bit()
        uchar dat=0;
        shu=1;
        _nop_();_nop_();
        shu=0;
        _nop_();_nop_();
        shu=1;
        _nop_();_nop_();
        _nop_();_nop_();
        dat=shu;
        return dat;
void read18b20()
                   fuwei();
                   xie_byte(0xcc);
                   xie_byte(0x44);
                   while(!du_bit());
                   fuwei();
                   xie_byte(0xcc);
                   xie_byte(0xbe);
                   w1=du_byte();
                   w2=du_byte();
                   w3=w1;
                   w1>>=4;
                   w2<<=4;
                   m1=w1+w2;
                   m1=m1/2;
                   w1=m1/10;   //十位
                   w2=m1%10;   //個位
                   w3&=0x0f;
                   w3*=6.25;
                   w3=w3/10;
        initinal();
        display();
        Write1302(0);//向1302寫指令
        WriteSet1302(0,0);
        jingdu();
        TMOD=0x11;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        EA=1;
        ET0=1;
        ET1=1;
        sc=1;
        j=1;
        fp=1;
//                delay(5);
                if(y==1)
                        display();
                        y=0;
                if(k==1)
                        if(ko==0)
                                w12864com(0x91);
                                w12864dat(0x41);
                        if(ko==1)
                                w12864com(0x91);
                                w12864dat(0x50);
                        w12864com(0x91);
                        w12864dat(0x02);
                if(aa==1)
                        w12864com(0x81);
                        for(a=0;a<2;a++)
                                w12864dat(0x20);
                        delay(80);
                        WriteSet1302(0x8e,0x00);
                        nian=ReadSet1302(0x8d);
                        WriteSet1302(0x8e,0x80);
                nian1=nian/10;
                nian2=nian%10;
                w12864com(0x81);
                for(a=0;a<2;a++)
                        if(a==0)
                                w12864dat(table[nian1]);
                        if(a==1)
                                w12864dat(table[nian2]);
                if(aa==2)
                        w12864com(0x83);
                        for(a=0;a<2;a++)
                                w12864dat(0x20);
                        delay(80);
                yue=ReadSet1302(0x89);
                yue1=yue/10;
                yue2=yue%10;
                w12864com(0x83);
                for(a=0;a<2;a++)
                        if(a==0)
                                w12864dat(table[yue1]);
                        if(a==1)
                                w12864dat(table[yue2]);
                if(aa==3)
                        w12864com(0x85);
                        for(a=0;a<2;a++)
                                w12864dat(0x20);
                        delay(80);
                ri=ReadSet1302(0x87);
                ri1=ri/10;
                ri2=ri%10;
                w12864com(0x85);
                for(a=0;a<2;a++)
                        if(a==0)
                                w12864dat(table[ri1]);
                        if(a==1)
                                w12864dat(table[ri2]);
                Conver_week();
                w12864com(0x8a);
                if(xq==0)//日
                 w12864dat(0xc8);
                 w12864dat(0xd5);
                if(xq==1)//一
                 w12864dat(0xd2);
                 w12864dat(0xbb);
                if(xq==2)//二
                 w12864dat(0xb6);
                 w12864dat(0xfe);
                if(xq==3)//三
                 w12864dat(0xc8);
                 w12864dat(0xfd);
                if(xq==4)//四
                        w12864dat(0xcb);
                        w12864dat(0xc4);
                if(xq==5)//五
                 w12864dat(0xce);
                 w12864dat(0xe5);
                if(xq==6)//六
                 w12864dat(0xc1);
                 w12864dat(0xf9);
if(aa==4)
                w12864com(0x92);
                for(a=0;a<8;a++)
                        if(a==0)
                                w12864dat(0x20);
                        if(a==1)
                                w12864dat(0x20);
                                delay(40);
                        if(a==2)
                                w12864dat(0x20);
                        if(a==3)
                                fen=ReadSet1302(0x83);
                                fen1=fen/10;
                                fen2=fen%10;
                                w12864dat(table[fen1]);
                        if(a==4)
                                w12864dat(table[fen2]);
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                miao=ReadSet1302(0x81);
                                miao1=miao/10;
                                miao2=miao%10;
                                w12864dat(table[miao1]);
                        if(a==7)
                                w12864dat(table[miao2]);
if(aa==5)
                w12864com(0x92);
                for(a=0;a<8;a++)
                        if(a==0)
                                shi=ReadSet1302(0x85);
                                if(k==1)
                                         if(shi>=12)
                                                 ko=1;
                                                 if(shi>12)
                                                        pp=shi;
                                                         pp=pp-12;
                                                        shi1=pp/10;
                                                        shi2=pp%10;
                                                        shi1=shi/10;
                                                        shi2=shi%10;
                                                ko=0;
                                                shi1=shi/10;
                                                shi2=shi%10;
                                        shi1=shi/10;
                                        shi2=shi%10;
                                w12864dat(table[shi1]);
                        if(a==1)
                                w12864dat(table[shi2]);
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                w12864dat(0x20);
                        if(a==4)
                                w12864dat(0x20);
                                delay(40);
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                miao1=miao/10;
                                miao2=miao%10;
                        if(a==7)
if(aa==6)
                w12864com(0x92);
                for(a=0;a<8;a++)
                        if(a==0)
                                if(k==1)
                                         if(shi>=12)
                                                 ko=1;
                                                 if(shi>12)
                                                        pp=shi;
                                                         pp=pp-12;
                                                        shi1=pp/10;
                                                        shi2=pp%10;
                                                        shi1=shi/10;
                                                        shi2=shi%10;
                                                ko=0;
                                                shi1=shi/10;
                                                shi2=shi%10;
                                        shi1=shi/10;
                                        shi2=shi%10;
                        if(a==1)
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                fen1=fen/10;
                                fen2=fen%10;
                        if(a==4)
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                w12864dat(0x20);
                        if(a==7)
                                w12864dat(0x20);
                                delay(40);
                w12864com(0x92);
                for(a=0;a<8;a++)
                        if(a==0)
                                if(k==1)
                                         if(shi>=12)
                                                 ko=1;
                                                 if(shi>12)
                                                        pp=shi;
                                                         pp=pp-12;
                                                        shi1=pp/10;
                                                        shi2=pp%10;
                                                        shi1=shi/10;
                                                        shi2=shi%10;
                                                ko=0;
                                                shi1=shi/10;
                                                shi2=shi%10;
                                        shi1=shi/10;
                                        shi2=shi%10;
                        if(a==1)
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                fen1=fen/10;
                                fen2=fen%10;
                        if(a==4)
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                miao1=miao/10;
                                miao2=miao%10;
                        if(a==7)
                read18b20();
                w12864com(0x9d);
                for(a=0;a<4;a++)
                        if(a==0)
                                w12864dat(table[w1]);
                        if(a==1)
                                w12864dat(table[w2]);
                        if(a==2)
                                w12864dat(we[17]);
                        if(a==3)
                                w12864dat(table[w3]);
                if(s1==0)
                        x=0;
                if(k1==0)
                        delay(2);
                        while(!k1==1);
                        s1++;
                        if(s1==5)
                                s1=0;
                if(s1==1)//設(shè)置時間
                        if(k2==0)
                                delay(2);
                                while(!k2==1);
                                aa++;
                                if(aa==7)
                                        s1=0;
                                        aa=0;
                w12864com(0x91);
                w12864dat(0x20);
                delay(50);
                if(s1==2)//定時
                        if((aa==1)||(aa==2)||(aa==3)||(aa==4)||(aa==5)||(aa==6))
                        {s1--;}
                        if(aa==0)
                                u=1;
                         dingshi();
                if(s1==0)//小時制設(shè)置
                        if(k2==0)
                                while(!k2==1);
                                m=1;
                                xiaoshi();
                if(s1==0)
                         if(k3==0)
                                while(!k3==1);
                                 w++;
                if(w==1)//開定時1
                        w12864com(0x8c);
                        w12864dat(0x41);
                        w12864dat(0x03);
                        w12864com(0x8e);
                        w12864dat(0x20);
                        w12864dat(0x20);
                                w12864com(0x97);
                                w12864dat(0x0e);
                        if(dshi==shi)
                                if(dfen==fen)
                                        if(dmiao==miao)
                                                if(cb==1)
                                                        TR0=1;
                                                if(cb==2)
                                                        TR1=1;
                                                        sh();
                if(w==2)//開定時2
                        w12864com(0x8c);
                        w12864dat(0x20);
                        w12864dat(0x20);
                        w12864com(0x8e);
                        w12864dat(0x42);
                        w12864dat(0x03);
                                w12864com(0x97);
                                w12864dat(0x0e);
                        if(eshi==shi)
                                if(efen==fen)
                                        if(emiao==miao)
                                                if(cb==1)
                                                        TR0=1;
                                                if(cb==2)
                                                        TR1=1;
                                                        sh();
                if(w==3)//定時雙開
                        w12864com(0x8c);
                        w12864dat(0x41);
                        w12864dat(0x03);
                        w12864com(0x8e);
                        w12864dat(0x42);
                        w12864dat(0x03);
                                w12864com(0x97);
                                w12864dat(0x0e);
                        if(dshi==shi)
                                if(dfen==fen)
                                        if(dmiao==miao)
                                                if(cb==1)
                                                        TR0=1;
                                                if(cb==2)
                                                        TR1=1;
                                                        sh();
                        if(eshi==shi)
                                if(efen==fen)
                                        if(emiao==miao)
                                                if(cb==1)
                                                        TR0=1;
                                                if(cb==2)
                                                        TR1=1;
                                                        sh();
                if(w==4)//定時關(guān)
                        w=0;
                        w12864com(0x8c);
                        w12864dat(0x20);
                        w12864dat(0x20);
                        w12864com(0x8e);
                        w12864dat(0x20);
                        w12864dat(0x20);
                        w12864com(0x97);//定時指示
                        w12864dat(0x20);
                if(aa==1)
                        if(k3==0)
                                while(!k3==1);
                                ss=nian;
                                ss++;
                                if(ss>=100)
                                {ss=0;}
                                WriteSet1302(0x8e,0x00);    //允許寫入
                                WriteSet1302(0x8c,ss);
                                WriteSet1302(0x90,0xa6);   //寫充電控制寄存器.
                                WriteSet1302(0x8e,0x80);   //禁止寫入
                if(aa==2)
                        if(k3==0)
                                while(!k3==1);
                                ss=yue;
                                ss++;
                                if(ss>=13)
                                ss=1;
                                WriteSet1302(0x88,ss);
                if(aa==3)
                        if(k3==0)
                                while(!k3==1);
                                ss=ri;
                                ss++;
                                if((yue==1)||(yue==3)||(yue==5)||(yue==7)||(yue==8)||(yue==10)||(yue==12))
                                        if(ss>=32)
                                        ss=1;
                                if((yue==4)||(yue==6)||(yue==9)||(yue==11))
                                        if(ss>=31)
                                        ss=1;
                                if(yue==2)
                                        vv=nian%4;
                                        if(vv==0)
                                                if(ss>=30)
                                                        ss=1;
                                                if(ss>=29)
                                                        ss=1;
                                WriteSet1302(0x86,ss);
                if(aa==4)
                        if(k3==0)
                                while(!k3==1);
                                if(k==1)//12小時
                                        if(ko==1)//下午
                                                if(shi<12)
                                                        shi=shi+12;
                                                        ss=shi;
                                                ss=shi;
                                        ss=shi;
                                ss++;
                                if(ss>=24)
                                {ss=0;}
                                WriteSet1302(0x84,ss);
                if(aa==5)
                        if(k3==0)
                                while(!k3==1);
                                ss=fen;
                                ss++;
                                if(ss>=60)
                                {ss=0;}
                                WriteSet1302(0x82,ss);
                if(aa==6)
                        if(k3==0)
                                while(!k3==1);
                                ss=miao;
                                ss++;
                                if(ss>=60)
                                {ss=0;}
                                WriteSet1302(0x80,ss);
void dingshi()
        uchar e1,e2,f1,f2,g1,g2;
        uchar ee,ff,gg,z,es,ww,ab;
        uchar bb1,bb2,cc1,cc2,dd1,dd2;
        uchar bb3,bb4,cc3,cc4,dd3,dd4;
                 c=1;
                 ee=ff=gg=0;
                 e1=ee/10;
                 e2=ee%10;
                 f1=ff/10;
                 f2=ff%10;
                 g1=gg/10;
                 g2=gg%10;
        w12864com(0x00);
        delay(2);
        w12864com(0x98);//定時1
                for(z=0;z<4;z++)
                        w12864dat(uu[z]);
                 if(c==1)
                        w12864com(0x9c);
                        w12864dat(0x41);
                        w12864dat(0x03);
                        w12864com(0x9a);
                        w12864dat(table[1]);
                 if(c==2)
                        w12864com(0x9c);
                        w12864dat(0x42);
                        w12864dat(0x03);
                        w12864com(0x9a);
if(k==1)
        if(dshi>=12)
                w12864com(0x80);
                w12864dat(0x50);
                w12864com(0x80);
                w12864dat(0x41);
        if(eshi>=12)
                w12864com(0x90);
                w12864dat(0x50);
                w12864com(0x90);
                w12864dat(0x41);
if(c==1)
        if(k==1)
                if(dshi>=12)
                        if(dshi>12)
                                ab=dshi;
                                ab=ab-12;
                                 bb3=ab/10;
                                 bb4=ab%10;
         bb3=dshi/10;
         bb4=dshi%10;
         cc3=dfen/10;
         cc4=dfen%10;
         dd3=dmiao/10;
         dd4=dmiao%10;
if(c==2)
        if(k==1)
                if(eshi>=12)
                        if(eshi>12)
                                ab=eshi;
                                ab=ab-12;
                                 bb1=ab/10;
                                 bb2=ab%10;
         bb1=eshi/10;
         bb2=eshi%10;
         cc1=efen/10;
         cc2=efen%10;
         dd1=emiao/10;
         dd2=emiao%10;
        while(u)
                w12864com(0x88);
                w12864dat(0x03);
                delay(2);
                 if(c==1)
                        w12864com(0x9c);
                        w12864dat(0x41);
                        w12864dat(0x03);
                        w12864com(0x9a);
                        w12864com(0x91);
                        w12864dat(0x20);
                        w12864dat(0x20);
                        w12864com(0x81);
                        w12864dat(0x20);
                        w12864dat(0x10);
                 if(c==2)
                        w12864com(0x9c);
                        w12864dat(0x42);
                        w12864dat(0x03);
                        w12864com(0x9a);
                        w12864com(0x91);
                        w12864dat(0x20);
                        w12864dat(0x10);
                        w12864com(0x81);
                        w12864dat(0x20);
                        w12864dat(0x20);
                if(k2==0)
                        while(!k2==1);
                        x++;
                        if(x==4)
                                x=0;
                                u=0;
                                s1=0;
                                y=1;
                                if(c==1)
                                        w=1;
                                        dshi=ee;
                                        dfen=ff;
                                        dmiao=gg;
                                        delay(5);
                                if(c==2)
                                        w=2;
                                        eshi=ee;
                                        efen=ff;
                                        emiao=gg;
                                        delay(5);
                if(k==1)
                        if(es==0)
                                w12864com(0x89);
                                w12864dat(0x41);
                         if(es==1)
                                w12864com(0x89);
                                w12864dat(0x50);
                if(x==1)
                        if(k3==0)
                                while(!k3==1);
                                ee++;
                                if(ee>=24)
                                 ee=0;
                                if(k==1)
                                         if(ee==12)
                                                 es=1;
                                                e1=ee/10;
                                                e2=ee%10;
                                         if(ee<12)
                                                 es=0;
                                                e1=ee/10;
                                                e2=ee%10;
                                         if(ee>12)
                                                ww=ee;
                                                 ww=ww-12;
                                                e1=ww/10;
                                                e2=ww%10;
                                        e1=ee/10;
                                        e2=ee%10;
                                if(c==1)
                                        if(k==1)
                                                if(es==0)
                                                        w12864com(0x80);
                                                        w12864dat(0x41);
                                                if(es==1)
                                                        w12864com(0x80);
                                                        w12864dat(0x50);
                                        bb3=e1;
                                        bb4=e2;
                                if(c==2)
                                        if(k==1)
                                                if(es==0)
                                                        w12864com(0x90);
                                                        w12864dat(0x41);
                                                if(es==1)
                                                        w12864com(0x90);
                                                        w12864dat(0x50);
                                        bb1=e1;
                                        bb2=e2;
                if(x==2)
                        if(k3==0)
                                while(!k3==1);
                                ff++;
                                if(ff>=60)
                                 ff=0;
                                f1=ff/10;
                                f2=ff%10;
                                if(c==1)
                                        cc3=f1;
                                        cc4=f2;
                                if(c==2)
                                        cc1=f1;
                                        cc2=f2;
                if(x==3)
                        if(k3==0)
                                while(!k3==1);
                                gg++;
                                if(gg>=60)
                                 gg=0;
                                g1=gg/10;
                                g2=gg%10;
                                if(c==1)
                                        dd3=g1;
                                        dd4=g2;
                                if(c==2)
                                        dd1=g1;
                                        dd2=g2;
                w12864com(0x8a);
                for(a=0;a<8;a++)
                        if(a==0)
                                w12864dat(table[e1]);
                        if(a==1)
                                w12864dat(table[e2]);
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                w12864dat(table[f1]);
                        if(a==4)
                                w12864dat(table[f2]);
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                w12864dat(table[g1]);
                        if(a==7)
                                w12864dat(table[g2]);
                delay(50);
                if(x==1)
                        w12864com(0x8a);
                        for(a=0;a<8;a++)
                                if(a==0)
                                        w12864dat(0x20);
                                if(a==1)
                                        w12864dat(0x20);
                                if(a==2)
                                        w12864dat(we[16]);
                                if(a==3)
                                if(a==4)
                                if(a==5)
                                        w12864dat(we[16]);
                                if(a==6)
                                if(a==7)
                if(x==2)
                        w12864com(0x8a);
                        for(a=0;a<8;a++)
                                if(a==0)
                                if(a==1)
                                if(a==2)
                                        w12864dat(we[16]);
                                if(a==3)
                                        w12864dat(0x20);
                                if(a==4)
                                        w12864dat(0x20);
                                if(a==5)
                                        w12864dat(we[16]);
                                if(a==6)
                                if(a==7)
                if(x==3)
                        w12864com(0x8a);
                        for(a=0;a<8;a++)
                                if(a==0)
                                if(a==1)
                                if(a==2)
                                        w12864dat(we[16]);
                                if(a==3)
                                if(a==4)
                                if(a==5)
                                        w12864dat(we[16]);
                                if(a==6)
                                        w12864dat(0x20);
                                if(a==7)
                                        w12864dat(0x20);
                  delay(50);
                w12864com(0x92);
                for(a=0;a<8;a++)
                        if(a==0)
                                w12864dat(table[bb1]);
                        if(a==1)
                                w12864dat(table[bb2]);
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                w12864dat(table[cc1]);
                        if(a==4)
                                w12864dat(table[cc2]);
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                w12864dat(table[dd1]);
                        if(a==7)
                                w12864dat(table[dd2]);
                w12864com(0x82);
                for(a=0;a<8;a++)
                        if(a==0)
                                w12864dat(table[bb3]);
                        if(a==1)
                                w12864dat(table[bb4]);
                        if(a==2)
                                w12864dat(we[16]);
                        if(a==3)
                                w12864dat(table[cc3]);
                        if(a==4)
                                w12864dat(table[cc4]);
                        if(a==5)
                                w12864dat(we[16]);
                        if(a==6)
                                w12864dat(table[dd3]);
                        if(a==7)
                                w12864dat(table[dd4]);
                if(k1==0)
                        delay(2);
                        while(!k1==1);
                        s1++;
                        if(s1==3)
                                c++;
                                if(c==2)
                                         es=0;
                                if(c==3)
                                        c=1;
                        if(s1==4)
                                x=0;
                                u=0;
                                y=1;
                                s1=0;
void xiaoshi()
        uchar tt;
        w12864com(0x00);
        delay(2);
                w12864com(0x82);
                for(tt=0;tt<6;tt++)
                        w12864dat(uu[tt+4]);
                w12864com(0x92);
                w12864dat(table[4]);
                for(tt=0;tt<6;tt++)
                w12864com(0x8a);
                for(tt=0;tt<4;tt++)
                        w12864dat(uu[tt+10]);
                delay(1);
                w12864com(0x9a);
                for(tt=0;tt<4;tt++)
                 delay(1);
                 if(sc==1)
                        w12864com(0x80);
                        w12864dat(0x12);
                        w12864com(0x88);
                        w12864dat(0x20);
                 if(sc==2)
                                w12864com(0x80);
                                w12864dat(0x20);
                                w12864com(0x99);
                                w12864dat(0x12);
                        if(j==1)
                                w12864com(0x81);
                                w12864dat(0x10);
                                w12864com(0x91);
                                w12864dat(0x20);
                        if(j==2)
                                w12864com(0x81);
                                w12864dat(0x20);
                                w12864com(0x91);
                                w12864dat(0x10);
                        if(fp==1)
                                w12864com(0x89);
                                w12864dat(0x10);
                                w12864com(0x99);
                                w12864dat(0x20);
                        if(fp==2)
                                w12864com(0x89);
                                w12864dat(0x20);
                                w12864com(0x99);
                                w12864dat(0x10);
        while(m)
           if(k2==0)
                           while(!k2==1);
                        sc++;
                         if(sc==3)
                         {sc=1;}
                if(k3==0)
                        while(!k3==1);
                        if(sc==1)
                                j++;
                                if(j==3)
                                {j=1;}
                        if(sc==2)
                                fp++;
                                if(fp==3)
                                {fp=1;}
                if(k1==0)
                        while(!k1==1);
                        y=1;
                        m=0;
                        s1=0;
                 if(sc==1)
                        w12864com(0x80);
                        w12864dat(0x12);
                        w12864com(0x88);
                        w12864dat(0x20);
                        if(j==1)
                                w12864com(0x81);
                                w12864dat(0x10);
                                w12864com(0x91);
                                w12864dat(0x20);
                                k=1;
                        if(j==2)
                                w12864com(0x81);
                                w12864dat(0x20);
                                w12864com(0x91);
                                w12864dat(0x10);
                                k=0;
                 if(sc==2)
                        w12864com(0x80);
                        w12864dat(0x20);
                        w12864com(0x88);
                        w12864dat(0x12);
                        if(fp==1)
                                w12864com(0x89);
                                w12864dat(0x10);
                                w12864com(0x99);
                                w12864dat(0x20);
                                cb=1;
                        if(fp==2)
                                w12864com(0x89);
                                w12864dat(0x20);
                                w12864com(0x99);
                                w12864dat(0x10);
                                cb=2;
void sh()
        uchar i;
        mb=1;
        w12864com(0x00);
        delay(2);
        w12864com(0x80);
        for(i=0;i<16;i++)
                w12864dat(tables[i]);
        w12864com(0x90);
        for(i=0;i<16;i++)
                w12864dat(tables[i+16]);
        w12864com(0x8b);
        for(i=0;i<4;i++)
                w12864dat(tables[i+32]);
        while(mb);
void time0() interrupt 1
        count++;
        if(count==20)//驗證時間為1s
                count=0;
                time++;
                if(time==20)
                        time=0;
                        TR0=0;
                D=~D;
                delay(30);
void t0() interrupt 3
        count++;
                count=0;
                time++;
                D=~D;
                delay(10);
                if(time==30)
                        time=0;
                        TR1=0;
                        mb=0;
                        y=1;
ID:1 發(fā)表于 2015-7-8 15:45 來自觸屏版 | 只看該作者
你這個程序運行能實現(xiàn)什么效果?
