查看: 2344|回復: 1
PS/2鍵盤使用,LCD_1602顯示
ID:99600 發(fā)表于 2015-12-25 12:42 | 顯示全部樓層 |閱讀模式
*  程序功能 : ps2鍵盤顯示演示實驗
*  應用軟件 :  KEIL U5
*  硬    件 :  W2041
*  創(chuàng)建時間 :  2015-12-19
SMC1602A(16*2)模擬口線接線方式
連接線圖:
       |LCM-----51   |        LCM-----51   |        LCM------51      |
       |DB0-----P0.0 |        DB4-----P0.4 |        RW-------P2.5    |
       |DB1-----P0.1 |        DB5-----P0.5 |        RS-------P2.6    |
       |DB2-----P0.2 |        DB6-----P0.6 |        E--------P2.7    |
       |DB3-----P0.3 |        DB7-----P0.7 |        VLCD接1K電阻到GND|
Keyboard接線
      PS/2--------51
      1 DATA------P3.4
      3 GND
      4 VCC
      5 CLK-------P3.3 接在51的外部中斷,觸發(fā)方式為低電平
本程序源碼只供學習參考,不得應用于商業(yè)用途,如有需要請聯(lián)系作者。
[注:AT89x51使用12M或11.0592M晶振,實測使用11.0592M]
#include <AT89X51.h>
#include "scancodes.h"
#include <string.h>
#include <intrins.h>
#include <stdio.h>
#define LCM_RS P2_5 //定義引腳
#define LCM_RW P2_6
#define LCM_E P2_7
#define LCM_Data P0
#define Busy 0x80 //用于檢測LCM狀態(tài)字中的Busy標識
#define Key_Data P3_4 //定義Keyboard引腳
#define Key_CLK  P3_3
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code www[] =   {" WWW.QLMCU.COM  "};
unsigned char code email[] = {" 0595-28011587  "};
unsigned char code input[] = {" Keyboard Test  "};
unsigned char code Cls[] =   {"                "};
static unsigned char IntNum = 0; //中斷次數(shù)計數(shù)
static unsigned char KeyV; //鍵值
static unsigned char DisNum = 0; //顯示用指針
static unsigned char Key_UP=0, Shift = 0;//Key_UP是鍵松開標識,Shift是Shift鍵按下標識
static unsigned char BF = 0; //標識是否有字符被收到
void main(void)
        unsigned char TempCyc;
        Delay400Ms(); //啟動等待,等LCM講入工作狀態(tài)
        LCMInit(); //LCM初始化
        Delay5Ms(); //延時片刻(可不要)
        DisplayListChar(0, 0, www);    //第一行顯示 WWW.QLMCU.COM
        DisplayListChar(0, 1, email);  //第一行顯示 0595-28011587
        for (TempCyc=0; TempCyc<10; TempCyc++)
        Delay400Ms(); //延時
        DisplayListChar(0, 0, input);  //第一行顯示 Keyboard Test
        DisplayListChar(0, 1, Cls);           //第二行清屏
        IT1 = 0; //設外部中斷1為低電平觸發(fā)
        EA = 1;
        EX1 = 1; //開中斷
        do
                        if (BF)
                                Decode(KeyV);
                                EA = 1; //開中斷
        while(1);
*********  LCM1602驅動程序  **************
//----------寫數(shù)據(jù)-----------------------------。!問題一直出在這里。!2006.03.18
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
//  LCM_E 必須是由 高 到 低 的電平變化。!
LCM_E = 1; //-----。!問題一直出在這里!。
_nop_();   //-----------------。。。!加上這四句即可!
_nop_();
LCM_E = 0;
//----------寫指令----------------------------!!問題一直出在這里!!!2006.03.18
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 1; //-----。。栴}一直出在這里。!
_nop_();   //-----------------!。。。〖由线@四句即可!
_nop_();
LCM_E = 0;
//讀狀態(tài)
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
_nop_();
LCM_E = 1;
_nop_();
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0x00;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(0x0C,1); // 顯示開及光標設置
//按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
WriteCommandLCM(X, 0); //這里不檢測忙信號,發(fā)送地址碼
WriteDataLCM(DData);
//按指定位置顯示一串字符  ***原來的遇到空格0x20就不顯示***
  unsigned char ListLength,j;
  ListLength = strlen(DData);
  Y &= 0x1;
      if (X <= 0xF) //X坐標應小于0xF
                    for(j=0;j<ListLength;j++)
             DisplayOneChar(X, Y, DData[j]); //顯示單個字符
             X++;
//5ms延時
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延時
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
///////////外部中斷 1 子程序,自動產生入口地址,使用第 0 組寄存器
void Keyboard_out(void) interrupt 2
        if ((IntNum > 0) && (IntNum < 9))
                        KeyV = KeyV >> 1; //因鍵盤數(shù)據(jù)是低>>高,結合上一句所以右移一位
                        if (Key_Data) KeyV = KeyV | 0x80; //當鍵盤數(shù)據(jù)線為1時為1到最高位
        IntNum++;
        while (!Key_CLK); //等待PS/2CLK拉高
        if (IntNum > 10)
                        IntNum = 0; //當中斷11次后表示一幀數(shù)據(jù)收完,清變量準備下一次接收
                        BF = 1; //標識有字符輸入完了
                        EA = 0; //關中斷等顯示完后再開中斷 (注:如這里不用BF和關中斷直接調Decode()則所Decode中所調用的所有函數(shù)要聲明為再入函數(shù))
void Decode(unsigned char ScanCode) //注意:如SHIFT+G為12H 34H F0H 34H F0H 12H,也就是說shift的通碼+G的通碼+shift的斷碼+G的斷碼
        if (!Key_UP)                //當鍵盤松開時
                        switch (ScanCode)
                                        case 0xF0 :        // 當收到0xF0,Key_UP置1表示斷碼開始
                                                Key_UP = 1;
                                        break;
                                        case 0x12 :        // 左 SHIFT
                                                Shift = 1;
                                        break;
                                        case 0x59 :        // 右 SHIFT
                                                Shift = 1;
                                        break;
                                        default:
                                                        if (DisNum > 15)
        DisplayListChar(0, 1, Cls);//清LCD第二行
        DisNum = 0;
                                                if(!Shift)        //如果SHIFT沒按下
        for (TempCyc = 0;(UnShifted[TempCyc][0]!=ScanCode)&&(TempCyc<59); TempCyc++); //查表顯示
        if (UnShifted[TempCyc][0] == ScanCode) DisplayOneChar(DisNum, 1, UnShifted[TempCyc][1]);
        DisNum++;
                                                else  //按下SHIFT
        for(TempCyc = 0; (Shifted[TempCyc][0]!=ScanCode)&&(TempCyc<59); TempCyc++); //查表顯示
        if (Shifted[TempCyc][0] == ScanCode) DisplayOneChar(DisNum, 1, Shifted[TempCyc][1]);
        DisNum++;
                                        break;
                        Key_UP = 0;
                        switch (ScanCode) //當鍵松開時不處理判碼,如G 34H F0H 34H 那么第二個34H不會被處理
                                                Shift = 0;
                                        break;
                                                Shift = 0;
                                        break;
        BF = 0; //標識字符處理完了
14-PS2鍵盤LCD顯示演示實驗.zip
61.9 KB, 下載次數(shù): 14, 下載積分: 黑幣 -5
PS/2
admin + 50 共享資料的積分獎勵!
ID:231918 發(fā)表于 2018-6-1 20:49 | 顯示全部樓層
留下買路財!  交黑幣
