查看: 2896|回復: 1
四位數(shù)碼管+protues仿真
ID:109895 發(fā)表于 2016-3-20 22:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include        "reg51.h"
#include        "stdio.h"
char        code        cDISP_HexTo7Seg[16]        =
                {0x3F, 0x06, 0x5B, 0x4F,     0x66, 0x6D, 0x7D, 0x07,
                 0x7F, 0x6F, 0x77, 0x7C,     0x39, 0x5E, 0x79, 0x71};
char        code        cDISP_Bit4[4]        =
                {0xE0,        0xD0,        0xB0,        0x70};
char        data        vDISP_SegValue[4]        =        {0x06,0x5B,0x4F,0x66};
char        data        vDISP_Blink[4]        =        {0,0,0,0};
unsigned        char        vDISP_Index,        vDISP_BlinkCnt;
void        DISP_Init(void)
        //初始化TimerA
        TH0        =        0xF0;
        TL0        =        0xBE;
        TMOD        =        0x01;
        ET0        =        1;
        TR0        =        1;
void        DISP_BitNum(char D0, char D1, char D2, char D3)
        vDISP_SegValue[0]        =        cDISP_HexTo7Seg[D0 & 0x0F];
        if        (D0        &        0x80)
                vDISP_SegValue[0]        |=        0x80;
        vDISP_SegValue[1]        =        cDISP_HexTo7Seg[D1 & 0x0F];
        if        (D1        &        0x80)
                vDISP_SegValue[1]        |=        0x80;
        vDISP_SegValue[2]        =        cDISP_HexTo7Seg[D2 & 0x0F];
        if        (D2        &        0x80)
                vDISP_SegValue[2]        |=        0x80;
        vDISP_SegValue[3]        =        cDISP_HexTo7Seg[D3 & 0x0F];
void        DISP_Integer(int        Value,        char        BitPos)
        char        D0,        D1, D2, D3;
        if        (Value        >        9999)
                Value        =        9999;
        D0        =        0;
        while        (Value        >        999)
                D0++;
                Value        -=        1000;
        if        (BitPos        ==        3)
                D0        |=        0x80;
        D1        =        0;
        while        (Value        >        99)
                D1++;
                Value        -=        100;
        if        (BitPos        ==        2)
                D1        |=        0x80;
        D2        =        0;
        D3        =        Value;
        while        (D3        >        9)
                D2++;
                D3        -=        10;
        if        (BitPos        ==        1)
                D2        |=        0x80;
        DISP_BitNum(D0,        D1, D2, D3);
void        DISP_SetBlink(char D0, char D1, char D2, char D3)
        vDISP_Blink[0]        =        D0;
        vDISP_Blink[1]        =        D1;
        vDISP_Blink[2]        =        D2;
        vDISP_Blink[3]        =        D3;
void        MN_T0_ISR(void)                        interrupt        1        using        1
        TH0        =        0xF0;
        TL0        =        0xBE;
        P3        =        0xFF;
        vDISP_BlinkCnt++;
        vDISP_BlinkCnt        &=        0x7F;
        if        (vDISP_Blink[vDISP_Index]        &&        (vDISP_BlinkCnt        <        0x3F))
                P2        =        0;
                P2        =        vDISP_SegValue[vDISP_Index];
        P3        =        cDISP_Bit4[vDISP_Index];
        vDISP_Index++;
        vDISP_Index        &=        3;
#include        "reg51.h"
#include        "DisplayUnit.h"
void        main(void)
        DISP_Init();
        DISP_Integer(5678,2);
        DISP_SetBlink(0,0,1,1);
        EA        =        1;
        while        (1)
ID:1 發(fā)表于 2016-3-20 22:39 | 只看該作者
樓主你好 仿真文件呢?
Powered by 單片機教程網
