查看: 2236|回復(fù): 1
求助:用按鍵鎖定數(shù)碼管顯示重量問(wèn)題?
ID:45225 發(fā)表于 2016-6-11 21:58 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
各位大神!我用STC12LE5A60S2單片機(jī)和HX711編寫了一個(gè)電子秤程序,我想通過(guò)一只按鍵按一次鎖定數(shù)碼管顯示的重量,再按一次解除鎖定,進(jìn)入正常顯示。我試了下,斷開hx711的DOUT或者PD_SCK或者同時(shí)斷開均可達(dá)到目的,但不知C程序如何編寫,試了很多方法均不行,敬請(qǐng)個(gè)位大神給點(diǎn)思路,謝謝。∠旅媸浅绦颍赫(qǐng)大家?guī)兔纯!謝謝指教!
#include<reg52.h>
#include<intrins.h>
uint Lheight;
uint compensate;
uchar discode[4]={0,0,0,0};
extern void LedDisplay(void);
sbit P10= P1^0;   //按鍵
sbit  hx711_dout=P3^6;
sbit  hx711_sck=P3^7;
extern unsigned char discode[4];
uchar  code Dis_7[10]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 };//0,1,2,3,4,5,6,7,8,9
uchar code scan_con[4]= {0xfe,0xfd,0xfb,0xf7 };
unsigned int ReadCount(void);
// 延時(shí) MS
void delay(uint x)
     uchar j;
    while(x--)
     for(j=0;j<125;j++)
//延時(shí) 500US
void delay500us(void)
    unsigned char a,b;
     for(b=7l;b>0;b--)
         for(a=2;a>0;a--);
//hx711 us延時(shí)
void delay_hx711_us(void)
   _nop_();
   _nop_();
//數(shù)碼管顯示
     uchar k;
    for(k=0;k<4;k++)
         P0=Dis_7[discode[k]];
         P2=scan_con[k];
         delay500us();
         P2=0xff;
// 按鈕
void ButtonScan(void)
   if(!P10)
      delay(10);
   if(!P10)
          compensate=ReadCount();//
//讀重量值,并A/D轉(zhuǎn)換,返回 (hx711驅(qū)動(dòng)程序)
        unsigned long Count;
        uint ADval;
        uchar i;
        hx711_dout=1;
        delay_hx711_us();
        hx711_sck=0;
        Count=0;
        while(hx711_dout)
        LedDisplay();
        for(i=0;i<24;i++)
                hx711_sck=1;
                Count=Count<<1;
                hx711_sck=0;
                if(hx711_dout)
                   Count++;
          hx711_sck=1;
          delay_hx711_us();
          Count=Count^0x800000;         //第25個(gè)脈沖下降沿來(lái)時(shí)轉(zhuǎn)換數(shù)據(jù)
          hx711_sck=0;
          ADval=(float)(Count>>8);
          return(ADval);
//分解
void discode0(void)
        discode[0]=Lheight%10;
        discode[1]=(Lheight%100)/10;
        discode[2]=(Lheight%1000)/100;
        discode[3]=(Lheight%10000)/1000;
//讀取重量值
void WeighWork(void)
     float Tempheight;
     uint a;
     a=ReadCount();
     if(a<=compensate)
            Lheight=0;             //校0
     else Lheight=a-compensate;
     discode0();                 //調(diào)用數(shù)值分解函數(shù)
     Lheight=discode[3]*1000+discode[2]*100+discode[1]*10+discode[0];
      Tempheight=(float)(Lheight/0.822);
     Lheight=(float)(Tempheight);   // 將Tempheight轉(zhuǎn)浮點(diǎn)型
void main(void)
        P10=1;
        delay(1000);
        compensate=ReadCount()+1;
//                 ReadCount();
                WeighWork();
                LedDisplay();
                ButtonScan();
相關(guān)帖子
ID:45225 發(fā)表于 2016-6-12 21:27 | 只看該作者
本帖最后由 fbzsn 于 2016-6-15 22:15 編輯
希望能得到大神們的幫助。▎(wèn)題已解決)
