查看: 5122|回復(fù): 1
熱敏電阻測溫仿真及AD1674單片機(jī)程序和pdf中文資料
下面是熱敏電阻的單片機(jī)測溫度的AD1674程序:(完整代碼和仿真工程文件及AD1674pdf中文資料請下載本帖最后的附件)
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <math.h>
  4. typedef unsigned char uchar;
  5. typedef unsigned int  uint;
  6. code        uint VOL[]={                343,        339,        339,        335,        332,        332,        328,        324,        320,        320,
  7.                                                         316,        312,        312,        308,        304,        300,        300,        296,        292,        292,
  8.                                                         289,        285,        285,        281,        277,        273,        273,        269,        265,        265,
  9.                                                         261,        257,        257,        253,        250,        250,        246,        242,        242,        238,
  10.                                                         234,        234,        230,        230,        226,        222,        222,        218,        218,        214,
  11.                                                         210,        210,        207,        207,        203,        199,        199,        195,        195,        191,
  12.                                                         191,        187,        187,        183,        179,        179,        175,        175,        171,        171,
  13.                                                         167,        167,        164,        164,        160,        160,        160,        156,        156,        152,
  14.                                                         152,        148,        148,        144,        144,        140,        140,        140,        136,        136,
  15.                                                         132,        132,        132,        128,        128,        125,        125,        125,        121,        121,
  16.                                                         121,        117,        113,        109,        109,        105,        101,        101,        97,                97,
  17.                                                         93,                89,                89,                85,                85,                82,                82,                78,                78,                74,
  18.                                                         74,                70,                70,                66,                66,                66,                62,                62,                58,                58,
  19.                                                         58,                54,                54,                54,                50,                50,                50,                46,                46,                46,
  20.                                                         42,                42,                42,                42,                39,                39,                39,                39,                35,                35};
  21. code        uint Temper[]={                100,        150,        200,        250,        300,        350,        400,        450,        500,        550,
  22.                                                         600,        650,        700,        750,        800,        850,        900,        950,        1000,        1050,
  23.                                                         1100,        1150,        1200,        1250,        1300,        1350,        1400,        1450,        1500,        1550
  24.                                                         1600,        1650,        1700,        1750,        1800,        1850,        1900,        1950,        2000,        2050,
  25.                                                         2100,        2150,        2200,        2250,        2300,        2350,        2400,        2450,        2500,        2550,
  26.                                                         2600,        2650,        2700,        2750,        2800,        2850,        2900,        2950,        3000,        3050,
  27.                                                         3100,        3150,        3200,        3250,        3300,        3350,        3400,        3450,        3500,        3550,
  28.                                                         3600,        3650,        3700,        3750,        3800,        3850,        3900,        3950,        4000,        4050,
  29.                                                         4100,        4150,        4200,        4250,        4300,        4350,        4400,        4450,        4500,        4550,
  30.                                                         4600,        4650,        4700,        4750,        4800,        4850,        4900,        4950,        5000,        5050,
  31.                                                         5100,        5200,        5300,        5400,        5500,        5600,        5700,        5800,        5900,        6000,
  32.                                                         6100,        6200,        6300,        6400,        6500,        6600,        6700,        6800,        6900,        7000,
  33.                                                         7100,        7200,        7300,        7400,        7500,        7600,        7700,        7800,        7900,        8000,
  34.                                                         8100,        8200,        8300,        8400,        8500,        8600,        8700,        8800,        8900,        9000,
  35.                                                         9100,        9200,        9300,        9400,        9500,        9600,        9700,        9800,        9900,        10000};
  36. sbit STS=P1^0;
  37. sbit CE = P1^1;
  38. sbit CS=P1^2;
  39. sbit A0=P1^3;
  40. sbit RC=P1^4;
  41. sbit RS=P1^5 ;
  42. sbit RW=P1^6 ;
  43. sbit EN=P1^7 ;
  44. void delay_ms(uint z)
  45. {
  46.         uint x,y;
  47.         for(x=z;x>0;x--)
  48.                 for(y=110;y>0;y--);
  49. }
  50. uint AD1674_Read(void)
  51. {
  52.         uint temp;
  53.         uchar temp1,temp2;
  54.         CS=1;        //片選信號
  55.         CE=0;        //初始化,關(guān)閉數(shù)據(jù)采集
  56.         CS=0;
  57.         A0=0;
  58.         RC=0;
  59.         CE=1;//CE=1,CS=0,RC=0,A0=0啟動12位溫度轉(zhuǎn)換
  60.         _nop_();
  61.         while(STS==1);         //等待數(shù)據(jù)采集結(jié)束
  62.         CE=0;         //芯片使能關(guān)閉
  63.         RC=1;
  64.         A0=0;
  65.         CE=1;//CE=1,CS=0,RC=1,12/8=1,A0=0 允許高八位數(shù)據(jù)并行輸出
  66.         _nop_();
  67.         temp1=P0; //讀取轉(zhuǎn)換結(jié)果的高八位
  68.         CE=0;  //芯片使能關(guān)閉
  69.         RC=1;
  70.         A0=1;
  71.         CE=1;//CE=1,CS=0,RC=1,12/8=0,A0=1 允許低四位數(shù)據(jù) 并行輸出
  72.         _nop_();
  73.         temp2=P0;         //讀取轉(zhuǎn)換結(jié)果的第四位
  74.         temp=((temp1<<4)|(temp2&0X0F));          //高位和低位合成實(shí)際溫度,temp2為PO口的高四位
  75.         return (temp);           //還回轉(zhuǎn)換結(jié)果,右移四位是因?yàn)閠emp2為P0口的高四位
  76. }
  77. /*** 寫數(shù)據(jù)***/
  78. void w_dat(unsigned char dat)
  79. {
  80.         RS = 1;
  81.         //EN = 0;
  82.         P2 = dat;
  83.         delay_ms(5);
  84.         RW = 0;
  85.         EN = 1;
  86.         EN = 0;
  87. }
  88. /*** 寫命令***/
  89. void w_cmd(unsigned char cmd)
  90. {
  91.         RS = 0;
  92. //        EN = 0;
  93.         P2 = cmd;
  94.         delay_ms(5);
  95.         RW = 0;
  96.         EN = 1;
  97.         EN = 0;
  98. }
  99. /*** 發(fā)送字符串到LCD***/
  100. void w_string(unsigned char addr_start, unsigned char *p)
  101. {
  102.         unsigned char *pp;
  103.
  104.         pp = p;
  105.         w_cmd(addr_start);
  106.         while (*pp != '\0')
  107.         {
  108.                 w_dat(*pp++);
  109.         }
  110. }
  111. /*** 初始化1602****/
  112. void Init_LCD1602(void)
  113. {
  114.         EN = 0;
  115.         w_cmd(0x38);  // 16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
  116.         w_cmd(0x0C);  // 顯示器開、光標(biāo)開、光標(biāo)允許閃爍
  117.         w_cmd(0x06);  // 文字不動,光標(biāo)自動右移
  118.         w_cmd(0x01);  // 清屏
  119. }
  120. void process(uint date,uchar add)
  121. {
  122.         uchar A[7];
  123.         A[0]=date/1000%10+'0';
  124.         A[1]=date/100%10+'0';
  125.         A[2]='.';
  126.         A[3]=date/10%10+'0';
  127.         A[4]=date%10+'0';
  128.         A[5]='C';
  129.         w_string(add,A);
  130. }
  131. void main()
  132. {
  133.         uchar i,flag=0;
  134.         uint result,temp1,temp2;
  135.         float        res;
  136.         Init_LCD1602();
  137.
  138.         w_string(0x80,"Temper:");
  139.
  140.         while (1)
  141.         {
  142.                  res=(float)(AD1674_Read());
  143.                  result=(uint)((res/2048.0-1.0)*500.0);
  144.
  145.                  temp1=abs(result-VOL[0]);
  146.                  for(i=1;i<150;i++)
  147.                  {
  148.                          temp2=abs(result-VOL[i]);
  149.                         if(temp1>=temp2)
  150.                         {
  151.                                 temp1=temp2;
  152.                                 flag=i;
  153.                         }
  154.
  155.                  }
  156.
  157.                  process(Temper[flag],0x80+7);
  158.         }
  159. }
熱敏電路的仿真工程文件及AD1674的pdf中文資料等資料下載:
熱敏電阻測溫.zip (259.77 KB, 下載次數(shù): 46)
ID:310363 發(fā)表于 2018-5-1 00:32 | 只看該作者
好東西,值得學(xué)習(xí)。。。。
