查看: 2068|回復(fù): 0
經(jīng)典交通燈程序 只為學(xué)習(xí) 無任何意圖
ID:141089 發(fā)表于 2016-12-16 15:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit  ADDR3 = P1^3;
sbit  ENLED = P1^4;
unsigned char code LedChar[] = {  //數(shù)碼管顯示字符轉(zhuǎn)換表
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[7] = {  //數(shù)碼管+獨立LED顯示緩沖區(qū)
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
bit flag1s = 1;          //1秒定時標(biāo)志
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
void ConfigTimer0(unsigned int ms);
void TrafficLight();
    EA = 1;      //開總中斷
    ENLED = 0;   //使能數(shù)碼管和LED
    ADDR3 = 1;
        ConfigTimer0(1);  //配置T0定時1ms
    while (1)
        if (flag1s)  //每秒執(zhí)行一次交通燈刷新
            flag1s = 0;
            TrafficLight();
/* 配置并啟動T0,ms-T0定時時間 */
    unsigned long tmp;  //臨時變量
    tmp = 11059200 / 12;      //定時器計數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計算所需的計數(shù)值
    tmp = 65536 - tmp;        //計算定時器重載值
    tmp = tmp + 13;           //補(bǔ)償中斷響應(yīng)延時造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
/* 交通燈顯示刷新函數(shù) */
void TrafficLight()
    static unsigned char color = 2;  //顏色索引:0-綠色/1-黃色/2-紅色
    static unsigned char timer = 0;  //倒計時定時器
    if (timer == 0) //倒計時到0時,切換交通燈
        switch (color)  //LED8/9代表綠燈,LED5/6代表黃燈,LED2/3代表紅燈
            case 0:     //切換到黃色,亮3秒
                color = 1;
                timer = 2;
                LedBuff[6] = 0xE7;
                break;
            case 1:     //切換到紅色,亮30秒
                color = 2;
                timer = 29;
                LedBuff[6] = 0xFC;
                break;
            case 2:     //切換到綠色,亮40秒
                color = 0;
                timer = 39;
                LedBuff[6] = 0x3F;
                break;
            default:
                break;
    else  //倒計時未到0時,遞減其計數(shù)值
        timer--;
    LedBuff[0] = LedChar[timer%10];  //倒計時數(shù)值個位顯示
    LedBuff[1] = LedChar[timer/10];  //倒計時數(shù)值十位顯示
/* LED動態(tài)掃描刷新函數(shù),需在定時中斷中調(diào)用 */
void LedScan()
    static unsigned char i = 0;
    P0 = 0xFF;
    P1 = (P1 & 0xF8) | i;
    P0 = LedBuff[i];
    if (i < 6)
        i++;
        i = 0;
/* T0中斷服務(wù)函數(shù),完成LED掃描和秒定時 */
void InterruptTimer0() interrupt 1
    static unsigned int tmr1s = 0;
    TH0 = T0RH;
    TL0 = T0RL;
    LedScan();
    tmr1s++;
    if (tmr1s >= 1000)
        tmr1s = 0;
        flag1s = 1;
