查看: 3275|回復(fù): 1
請問大神:GY-530 VL53L0X連接arduino后寫入官方給的arduino程序后如何測距?
ID:177184 發(fā)表于 2017-3-22 08:59 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
GY-530 VL53L0X
寫入程序后出現(xiàn)
VLX53LOX test started.
----- START TEST ----
然后就沒有然后了,請問怎么測距?
arduino程序
#include <Wire.h>
#define VL53L0X_REG_IDENTIFICATION_MODEL_ID         0xc0
#define VL53L0X_REG_IDENTIFICATION_REVISION_ID      0xc2
#define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD   0x50
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x70
#define VL53L0X_REG_SYSRANGE_START                  0x00
#define VL53L0X_REG_RESULT_INTERRUPT_STATUS         0x13
#define VL53L0X_REG_RESULT_RANGE_STATUS             0x14
#define address 0x29
byte gbuf[16];
void setup() {
  // put your setup code here, to run once:
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Serial.println("VLX53LOX test started.");
void loop() {
  Serial.println("----- START TEST ----");
  test();
  Serial.println("----- END TEST ----");
  Serial.println("");
  delay(1000);
void test() {
  byte val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_REVISION_ID);
  Serial.print("Revision ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_MODEL_ID);
  Serial.print("Device ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("PRE_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
  val1 = read_byte_data_at(VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("FINAL_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  write_byte_data_at(VL53L0X_REG_SYSRANGE_START, 0x01);
  byte val = 0;
  int cnt = 0;
  while (cnt < 100) { // 1 second waiting time max
    delay(10);
    val = read_byte_data_at(VL53L0X_REG_RESULT_RANGE_STATUS);
    if (val & 0x01) break;
    cnt++;
  if (val & 0x01) Serial.println("ready"); else Serial.println("not ready");
  read_block_data_at(0x14, 12);
  uint16_t acnt = makeuint16(gbuf[7], gbuf[6]);
  uint16_t scnt = makeuint16(gbuf[9], gbuf[8]);
  uint16_t dist = makeuint16(gbuf[11], gbuf[10]);
  byte DeviceRangeStatusInternal = ((gbuf[0] & 0x78) >> 3);
  Serial.print("ambient count: "); Serial.println(acnt);
  Serial.print("signal count: ");  Serial.println(scnt);
  Serial.print("distance ");       Serial.println(dist);
  Serial.print("status: ");        Serial.println(DeviceRangeStatusInternal);
uint16_t bswap(byte b[]) {
  // Big Endian unsigned short to little endian unsigned short
  uint16_t val = ((b[0] << 8) & b[1]);
  return val;
uint16_t makeuint16(int lsb, int msb) {
    return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void write_byte_data(byte data) {
  Wire.beginTransmission(address);
  Wire.write(data);
  Wire.endTransmission();
void write_byte_data_at(byte reg, byte data) {
  // write data word at address and register
  Wire.write(reg);
  Wire.write(data);
void write_word_data_at(byte reg, uint16_t data) {
  byte b0 = (data &0xFF);
  byte b1 = ((data >> 8) && 0xFF);
  Wire.write(reg);
  Wire.write(b0);
  Wire.write(b1);
byte read_byte_data() {
  Wire.requestFrom(address, 1);
  while (Wire.available() < 1) delay(1);
  byte b = Wire.read();
  return b;
byte read_byte_data_at(byte reg) {
  //write_byte_data((byte)0x00);
  write_byte_data(reg);
  return b;
uint16_t read_word_data_at(byte reg) {
  Wire.requestFrom(address, 2);
  while (Wire.available() < 2) delay(1);
  gbuf[0] = Wire.read();
  gbuf[1] = Wire.read();
  return bswap(gbuf);
void read_block_data_at(byte reg, int sz) {
  int i = 0;
  Wire.requestFrom(address, sz);
  for (i=0; i<sz; i++) {
    gbuf = Wire.read();
uint16_t VL53L0X_decode_vcsel_period(short vcsel_period_reg) {
  // Converts the encoded VCSEL period register value into the real
  // period in PLL clocks
  uint16_t vcsel_period_pclks = (vcsel_period_reg + 1) << 1;
  return vcsel_period_pclks;
相關(guān)帖子
ID:815693 發(fā)表于 2022-3-28 19:47 | 只看該作者
我用的是單片機(jī),你現(xiàn)在怎么解決了?
