用8051與1601LCD設計的計算器仿真原理圖如下:
部分匯編源碼預覽:
- ************ LABCENTER ELECTRONICS ************
- ************ Proteus VSM Sample Design Code ************
- ************ Integer Calculator ( 2K Code Limit) ************
- NAME KEYPAD
- ; This routine will read a character press from the keypad and return it in R7.
- ;Set up Segments for the Input Routine - No parameters.
- ?PR?input?KEYPAD SEGMENT CODE
- PUBLIC input
- ?DT?input?KEYPAD SEGMENT DATA
- RSEG ?DT?input?KEYPAD ; Local Variable Segment for Output Routine.
- KEY_ROW1 equ 0EFh
- KEY_ROW2 equ 0DFh
- KEY_ROW3 equ 0BFh
- KEY_ROW4 equ 07Fh
- keyflags: ds 16
- RSEG ?PR?input?KEYPAD ; Code Segment for Output Routine.
- input:
- keyscan:push DPH
- push DPL
- mov R0,#keyflags ; R0 addresses the key toggle bytes
- mov R1,#KEY_ROW1 ; R1 address the keyboard row address
- mov R2,#4 ; R2 counts rows
- ksrow: mov P2,R1 ; Set row address to port P2
- nop
- mov A,P1 ; Read column data from port P1
- mov R3,#4 ; R3 counts keys per row
- anl A,#3Fh
- ks0: rrc A ; Move next bit into carry
- mov R4,A ; R4 preserves the row data
- jc ks1 ; Jump if key not pressed
- mov A,@R0 ; Test if key already pressed
- mov @R0,#1 ; Flag pressed anyway
- jz ksnew ; Jump if key newly pressed
- jmp ks2
- ks1: mov @R0,#0 ; Flag key as not pressed
- ks2: inc R0 ; Loop for next key in this row
- mov A,R4
- djnz R3,ks0
- mov A,R1 ; Jiggle R1 to address next row
- rl A
- mov R1,A
- djnz R2,ksrow
- clr A
- mov R7,A ; Return zero - no (new) key press.
- jmp ksend
- ksnew: mov DPTR,#keycodes ; We've found a new key since last time:
- mov A,R0 ; The key flag address (ordinal) is in R0
- clr C
- subb A,#keyflags
- movc A,@A+DPTR
- mov R7,A ; Move the Key into R7 to be returned.
- ksend: mov P2,#0FFh
- pop DPL
- pop DPH
- ret
- ;Data tables for returned row bits
- keycodes:
- db '7','8','9', '/'
- db '4','5','6', '*'
- db '1','2','3', '-'
- db 'C','0','=', '+'
- END
復制代碼
完整源碼和仿真工程文件下載:
用8051與1601LCD設計的計算器.rar
(35.23 KB, 下載次數(shù): 30)
2017-4-5 22:04 上傳
點擊文件名下載附件
