查看: 2762|回復(fù): 0
gokit遠(yuǎn)程控制
ID:186488 發(fā)表于 2017-4-11 00:39 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
<script type="text/javascript">
        var gizwitsws;
        $(document).ready(setDefault);
        function setDefault()
            $('#apiHost').val($.cookie('apiHost'));
            $('#commType').val($.cookie('commType'));
            $('#wechatOpenId').val($.cookie('wechatOpenId'));
            $('#gizwitsAppId').val($.cookie('gizwitsAppId'));
        function newObj()
            if (gizwitsws != null)
                alert("對(duì)象已被初始化,如需改變參數(shù),請(qǐng)刷新頁(yè)面.");
                return;
            var apiHost = $('#apiHost').val();
            var commType = $('#commType').val();
            var wechatOpenId = $('#wechatOpenId').val();
            var gizwitsAppId = $('#gizwitsAppId').val();
            gizwitsws = new GizwitsWS(apiHost, wechatOpenId, gizwitsAppId, commType);
            gizwitsws.onInit = onInit;
            gizwitsws.onConnected = onConnected;
            gizwitsws.onOnlineStatusChanged = onOnlineStatusChanged;
            gizwitsws.onReceivedRaw = onReceivedRaw;
            gizwitsws.onReceivedAttrs = onReceivedAttrs;
            gizwitsws.onError = onError;
            $.cookie('apiHost', apiHost);
            $.cookie('commType', commType);
            $.cookie('wechatOpenId', wechatOpenId);
            $.cookie('gizwitsAppId', gizwitsAppId);
            showScreen("初始化對(duì)象成功!");
        function init()
            gizwitsws.init();
            conndids = [];
            showScreen("已發(fā)送init指令!");
        function connect()
            var did = $('#did').val();
            gizwitsws.connect(did);
            showScreen("已發(fā)送connect指令!");
        function read()
            var did = $('#readDid').val();
            gizwitsws.read(did);
            showScreen("已發(fā)送read指令!");
        function writeCommand()
            var did = $('#writeDid').val();
            if ($('#commType').val() == "attrs_v4")
                var attrs = $('#command').val();
                try
                    gizwitsws.write(did, JSON.parse(attrs));
                    showScreen("已對(duì)設(shè)備" + did + "發(fā)送write指令: " + attrs);
                catch(e)
                    showError("數(shù)據(jù)格式錯(cuò)誤:" + e);
                var raw = $('#command').val();
                try
                    gizwitsws.send(did, JSON.parse(raw));
                    showScreen("已對(duì)設(shè)備" + did + "發(fā)送raw指令: " + raw);
                catch(e)
        function clearLog()
            $('#log').html("");
        // callback functions
        function onInit(devices)
            if (devices.length == 0)
                showScreen("沒(méi)有綁定的設(shè)備");
                for (var i = 0; i < devices.length; i++)
                    showScreen("==================================================");
                    showScreen("已綁定設(shè)備,did=" + devices[i].did);
                    showScreen("已綁定設(shè)備,mac=" + devices[i].mac);
                    showScreen("已綁定設(shè)備,product_key=" + devices[i].product_key);
                    showScreen("已綁定設(shè)備,is_online=" + devices[i].is_online);
                    showScreen("已綁定設(shè)備, dev_alias=" + devices[i].dev_alias);
                    showScreen("已綁定設(shè)備,remark=" + devices[i].remark);
                    addSelectOption('#did', devices[i].did, devices[i].did);
        function onConnected(did)
            addSelectOption('#readDid', did, did);
            addSelectOption('#writeDid', did, did);
            showScreen("與設(shè)備:" + did + "連接成功!");
        function onOnlineStatusChanged(value)
            showScreen("設(shè)備上下線通知,did=" + value.did);
            showScreen("設(shè)備上下線通知,is_online=" + value.is_online);
        function onReceivedRaw(value)
            var str = "收到設(shè)備" + value.did + "的Raw: [";
            for (var i = 0; i < value.raw.length; i++)
                str = str + value.raw[i] + ",";
            str = str.substr(0, str.length-1) + "]";
            showScreen(str);
        function onReceivedAttrs(value)
            var str = "收到設(shè)備" + value.did + "的Attrs: ";
            for (var key in value.attrs)
                str = str + key + ":" + value.attrs[key] + "; ";
            showScreen(str);
        function onError(value)
            showError(value.toString());
        // inner functions
        function showScreen(txt)
            $('#log').prepend('<p style="color: blue">' + txt + '</p>');
        function showError(txt)
            $('#log').prepend('<p style="color: red">' + txt + '</p>');
        function addSelectOption(selectId, value, text)
            if ($(selectId + ' option[value =' + value + ']').length == 0)
                $(selectId).append("<option value=" + value + ">" + text + "</option>");
    </script>
gizwits-wechat-js-sdk-master.zip
43.19 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
實(shí)現(xiàn)代碼
