查看: 2728|回復(fù): 3
如何添加子函數(shù)
ID:190966 發(fā)表于 2017-4-19 13:54 | 只看該作者 回帖獎勵 |正序?yàn)g覽 |閱讀模式
2黑幣
怎么把下面兩個函數(shù)合在一起呢?
第一個函數(shù):
#include<reg51.h>
sbit csda=P2^2;
sbit wr=P2^1;
sbit s1=P3^2;
sbit s2=P3^3;
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
uchar timeCnt=0;
uchar k=0,p=0,delay=0;
uchar bxxz=0;pinglv=0;
uchar a=1,b=0,c=0,d=0;
//正弦波數(shù)據(jù)
uchar code zhengxian[64]={
135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
//方波數(shù)據(jù)報表
uchar code juxing[64]={
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
//鋸齒波數(shù)據(jù)
uchar code juchi[64]={
0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
//三角波數(shù)據(jù)
uchar code sanjiao[64]={
0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
void delay1()
相關(guān)帖子
ID:190966 發(fā)表于 2017-4-19 22:43 | 只看該作者
求大神搭救啊。。!
ID:190966 發(fā)表于 2017-4-19 13:56 | 只看該作者
#include<reg51.h>
sbit s2=P3^3;
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
uchar timeCnt=0;
void delay( unsigned int t)
uchar i,j;
for(i=t;i>0;i--)
for(j=250;j>0;j--);
void shanshuo1()
led1=0;
delay(5000);
led2=2;
delay(5000);
led3=1;
delay(5000);
void shanshuo2()
led2=0;
delay(5000);
led1=1;
delay(5000);
led3=1;
delay(5000);
void shanshuo3()
led3=0;
delay(5000);
led1=1;
delay(5000);
led2=1;
delay(5000);
void shanshuo4()
led1=0;
delay(5000);
led2=0;
delay(5000);
led3=1;
delay(5000);
void shanshuo5()
led2=0;
delay(5000);
led3=0;
delay(5000);
led1=1;
delay(5000);
if(s2==0)
timeCnt++;
if(timeCnt==6) timeCnt=0;
if(timeCnt==1) shanshuo1();
if(timeCnt==2) shanshuo2();
if(timeCnt==3) shanshuo3();
if(timeCnt==4) shanshuo4();
if(timeCnt==5) shanshuo5();
ID:190966 發(fā)表于 2017-4-19 13:55 | 只看該作者
#include<reg51.h>
sbit csda=P2^2;
sbit wr=P2^1;
sbit s1=P3^2;
sbit s2=P3^3;
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
uchar timeCnt=0;
//正弦波數(shù)據(jù)
//方波數(shù)據(jù)報表
//鋸齒波數(shù)據(jù)
//三角波數(shù)據(jù)
void delay1()                  //延時
        int a,b;
        for(a=1;a>0;a--)
        for(b=122;b>0;b--);
void int0() interrupt 0          //中斷處理,用于波型切換
        EX0=0;
        delay1();
        if(s1==0)
                bxxz++;
                if(bxxz==4)
                bxxz=0;
                switch(bxxz)
                        case 0 :
                                {a=1,b=0,c=0,d=0;}                //        正弦波
                                break;
                        case 1 :
                                {a=0,b=1,c=0,d=0;}                //方波
                                break;
                        case 2 :
                                {a=0,b=0,c=1,d=0;}                  // 鋸齒波
                                break;
                        case 3 :
                                {a=0,b=0,c=0,d=1;}                  //        三角波
                                break;
                delay1();
                while(!s1);
        while(!s1);
        EX0=1;
void int1() interrupt 2
        EX1=0;
        delay1();
        if(s2==0){
        p++;
        if(p==5)
        p=0;
        switch(p)
                case 1 :
                        pinglv=63;                //50Hz
                        break;
                case 2 :
                        pinglv=21;                //100Hz
                        break;
                case 3 :
                        pinglv=3;          //500Hz
                        break;
                        case 4 :
                        pinglv=0;          //1000Hz
                        break;
                default :
                        pinglv=150;                   //2000Hz
                        break;
                delay1();
                while(!s2);
        while(!s2);
        EX1=1;
        csda=0;
        wr=0;
        EA=1;
        IT0=1;
        EX0=1;
        IT1=1;
        EX1=1;
        pinglv=15;
                while(a)               //產(chǎn)生正弦波
                        delay=pinglv; //獲取周期數(shù)據(jù)
                        P0=zhengxian[k];          //數(shù)據(jù)數(shù)P0口進(jìn)行波形轉(zhuǎn)換
                        k++;
                        if(k==64)          //一個周期取64點(diǎn)波數(shù)據(jù)
                        k=0;
                        while(delay)  //延時處理
                    delay--;
                while(b)                   //產(chǎn)生方波
                        delay=pinglv;
                        P0=juxing[k];
                        k++;
                        if(k==64)
                        k=0;
                        while(delay)
                    delay--;
                while(c)                   //產(chǎn)生鋸齒波
                        delay=pinglv;
                        P0=juchi[k];
                        k++;
                        if(k==64)
                        k=0;
                        while(delay)
                            delay--;
                while(d)                         //產(chǎn)生三角波
                        delay=pinglv;
                        P0=sanjiao[k];
                        k++;
                        if(k==64)
                        k=0;
                        while(delay)
                    delay--;
