求大神賜教用矩陣鍵盤設(shè)計的密碼鎖的仿真+程序
下面是仿真原理圖:
2017-4-22 21:43 上傳
單片機源代碼:
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit key1=P3^4;
- sbit D1=P1^0;
- sbit dula=P2^6;
- sbit wela=P2^7;
- void delay(uint z);
- void display(uchar num);
- uchar code table[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- uchar temp=0,num=1,temp1;
- void display(uchar temp1 );
- void init();
- uchar keyscan();
- void main()
- init();
- while(1)
- temp1=keyscan();
- display(temp1);
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- wela=1;
- P0=0xfe;
- wela=0;
- dula=1;
- P0=table[temp1-1];
- dula=0;
- delay(10);
- void init() //初始化數(shù)碼管,
- wela=1;
- P0=0xfe;
- wela=0;
- dula=1;
- P0=0;
- dula=0;
- uchar keyscan()
- P3=0xfe; //初始化P3口,檢測鍵盤第一行
- temp=P3;
- temp=temp&0xf0; //檢測高四位。
- while(temp!=0xf0)
- delay(5); //消除抖動。
- temp=P3;
- while(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xee:num=1;break;
- case 0xde:num=2;break;
- case 0xbe:num=3;break;
- case 0x7e:num=4;break;
- while(temp!=0xf0) //這就是還處于按住不放,
- temp=P3; //如果松開了按鍵,
- temp=temp&0xf0; //與后的值將會和0xf0相等。從而跳出while循環(huán)
- P3=0xfd; //初始化P3口,檢測鍵盤第2行
- temp=P3;//程序版權(quán):51黑電子論壇
- while(temp!=0xf0)
- delay(5);
- temp=P3;
- while(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xed:num=5;break;
- case 0xdd:num=6;break;
- case 0xbd:num=7;break;
- case 0x7d:num=8;break;
- P3=0xfb; //初始化P3口,檢測鍵盤第3行
- temp=P3;
- while(temp!=0xf0)
- delay(5);
- temp=P3;
- while(temp!=0xf0)
- temp=P3; //````````````
- switch(temp)
- case 0xeb:num=9;break;
- case 0xdb:num=10;break;
- case 0xbb:num=11;break;
- case 0x7b:num=12;break;
- P3=0xf7; //初始化P3口,檢測鍵盤第4行
- temp=P3;
- while(temp!=0xf0)
- delay(5);
- temp=P3;
- while(temp!=0xf0)
- switch(temp)
- case 0xe7:num=13;break;
- case 0xd7:num=14;break;
- case 0xb7:num=15;break;
- case 0x77:num=16;break;
- temp=temp&0xf0; //按位與后的值將會和0xf0相等。從而跳出while循環(huán)
2017-4-22 21:43 上傳
下載:
矩陣鍵盤protues仿真實驗.rar
(52.5 KB, 下載次數(shù): 73)
2017-4-22 11:58 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
