查看: 3781|回復(fù): 2
求助 電子時(shí)鐘程序問(wèn)題 求指教
ID:193618 發(fā)表于 2017-4-25 22:06 | 顯示全部樓層 |閱讀模式
要求能實(shí)現(xiàn)年、月、日、星期、時(shí)、分、秒的顯示;
2.能實(shí)現(xiàn)調(diào)時(shí)功能;
3.能實(shí)現(xiàn)12/24小時(shí)制切換;
4.能實(shí)現(xiàn)8002200整點(diǎn)報(bào)時(shí)功能
錯(cuò)誤信息Build target 'Target 1'
assembling STARTUP.A51...
compiling 3333.c...
3333.C(1): error C251: illegal octal digit
3333.C(1): error C141: syntax error near '0c'
3333.C(1): error C129: missing ';' before 'year'
Target not created
程序如下:
0char year,month,day,week,miao,shi,fen,pshi;
uchar code table[]=" 20  -  -   ";//定義初始上電時(shí)液晶默認(rèn)顯示狀態(tài)
void delay(uint z)  //延時(shí)函數(shù)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void zhuanhuan()
        if(shi==0)
            pshi=12;
        if(shi<=12&&shi>=1)
            pshi=shi;
    if(shi>12)
            pshi=shi-12;
void di()//蜂鳴器發(fā)聲函數(shù)
        beep=0;
        delay(300);
        beep=1;
        delay(300);
void write_com(uchar com)//液晶寫命令函數(shù)
        lcdrs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)//液晶寫數(shù)據(jù)函數(shù)
        lcdrs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void _shi()        //寫"AM"、"PM"函數(shù)
   if(shi>=12)
         write_com(0x80+0x40+1);//寫出"PM"
         write_date('P');
         write_date('M');
         write_com(0x80+0x40+1);//寫出"AM"
         write_date('A');
         write_date('M');
void write_ymd(uchar add1,uchar date1)//寫年月日函數(shù)
        uchar shi,ge;
        shi=date1/10;//分解一個(gè)2位數(shù)的十位和個(gè)位
        ge=date1%10;
        write_com(0x80+add1);//設(shè)置顯示位置
        write_date(0x30+shi);//送去液晶顯示十位
        write_date(0x30+ge); //送去液晶顯示個(gè)位
void write_sfm(uchar add,uchar date)//寫時(shí)分秒函數(shù)
        uchar shi,ge;
        shi=date/10;//分解一個(gè)2位數(shù)的十位和個(gè)位
        ge=date%10;
        write_com(0x80+0x40+add);//設(shè)置顯示位置
void write_week(char week)           //寫液晶星期顯示函數(shù)
        write_com(0x80+12);
        switch(week)
                case 1:        write_date('M');delay(5);
                                write_date('O');delay(5);
                                write_date('N');
                                break;
                case 2:        write_date('T');delay(5);
                                write_date('U');delay(5);
                                write_date('E');
                                break;
                case 3:        write_date('W');delay(5);
                                write_date('E');delay(5);
                                write_date('D');
                                break;
                case 4:        write_date('T');delay(5);
                                write_date('H');delay(5);
                                write_date('U');
                                break;
                case 5:        write_date('F');delay(5);
                                write_date('R');delay(5);
                                write_date('I');
                                break;
                case 6:        write_date('S');delay(5);
                                write_date('A');delay(5);
                                write_date('T');
                                break;
                case 7:        write_date('S');delay(5);
                                write_date('N');
                                break;
void writeym()
   day=1;
   month++;
   if(month==13)
         month=1;
         year++;
         if(year==100)
            year=0;
         write_ymd(3,year);//年若變化則重新寫入
        write_ymd(6,month);//月若變化則重新寫入
void init()//初始化函數(shù)
   129行 uchar num;
        lcden=0;
        year=13;//初始化種變量值
        month=6;
        day=21;
        week=5;
        shi=13;
        fen=59;
        miao=58;
        count=0;
        s1num=0;
        s4num=0;
        write_com(0x38);//初始化1602液晶
錯(cuò)誤行        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);//設(shè)置顯示初始坐標(biāo)
        for(num=0;num<15;num++)//顯示年月日星期
                write_date(table[num]);
                delay(5);
                delay(5);
                write_com(0x80+0x40+6);//寫出時(shí)間顯示部分的兩個(gè)":"
                write_date(':');
                delay(5);
                write_com(0x80+0x40+9);
                write_date(':');
                delay(5);
        write_week(week);
        write_ymd(3,year);//分別送去液晶顯示
        write_ymd(6,month);
        write_ymd(9,day);
        write_sfm(10,miao);//分別送去液晶顯示
        write_sfm(7,fen);
        write_sfm(4,shi);
        TMOD=0x01;//設(shè)置定時(shí)器0工作模式1
        TH0=(65536-50000)/256;//定時(shí)器裝初值
        TL0=(65536-50000)%256;
        EA=1;        //開總中斷
        ET0=1;        //開定時(shí)器0中斷
        TR0=1;        //啟動(dòng)定時(shí)器0
void keyscan()//按鍵掃描函數(shù)
        if(s1==0)
                delay(5);
                if(s1==0)//確認(rèn)功能鍵被按下
                    s1num++;//功能鍵按下次數(shù)記錄
                        while(!s1);//釋放確認(rèn)
                        if(s1num==1)//第一次被按下時(shí)
                            TR0=0;  //關(guān)閉定時(shí)器
                                write_com(0x80+3);//光標(biāo)定位到年位置
                                write_com(0x0f); //光標(biāo)開始閃爍
                        if(s1num==2)//第二次按下光標(biāo)閃爍定位到月位置
                                write_com(0x80+6);
                        if(s1num==3)//第三次按下光標(biāo)閃爍定位到日位置
                                write_com(0x80+9);
                        if(s1num==4)//第四次按下光標(biāo)閃爍定位到星期位置
                                write_com(0x80+12);
                        if(s1num==7)//第七次被按下時(shí)光標(biāo)定位到秒位置
                                write_com(0x80+0x40+10);
                        if(s1num==6)//第六次按下光標(biāo)閃爍定位到分位置
                                write_com(0x80+0x40+7);
                        if(s1num==5)//第五次按下光標(biāo)閃爍定位到時(shí)位置
                                write_com(0x80+0x40+4);
                        if(s1num==8)//第七次按下
                                s1num=0;//記錄按鍵數(shù)清零
                                write_com(0x0c);//取消光標(biāo)閃爍
                                TR0=1;        //啟動(dòng)定時(shí)器使時(shí)鐘開始走
        if(s1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
                if(s2==0)
                        delay(5);
                        if(s2==0)//增加鍵確認(rèn)被按下
                                while(!s2);//按鍵釋放
                                if(s1num==1)//若功能鍵第一次按下
                                        year++; //則調(diào)整年加1
                                        if(year==100)//若滿100后將清零
                                                year=0;
                                        write_ymd(3,year);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+3);//顯示位置重新回到調(diào)節(jié)處
                                if(s1num==2)//若功能鍵第二次按下
                                        month++;//則調(diào)整月加1
                                        if(month==13)//若滿12后將置一
                                                month=1;
                                        write_ymd(6,month);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+6);//顯示位置重新回到調(diào)節(jié)處
                251行錯(cuò)誤                }
                                if(s1num==3)//若功能鍵第三次按下
                                        day++;//則調(diào)整日加1
                                        if(year%4==0&&month==2)
                                            if(day==30)//若滿29后將置一
                                                day=1;
                                         if(year%4!=0&&month==2)
                                            if(day==29)//若滿28后將置一
                                                day=1;
                                         if(month!=2&&month!=4&&month!=6&&month!=9&&month!=11)
                                            if(day==32)//若滿31后將置一
                                                day=1;
                                         if(month==4||month==6||month==9||month==11)
                                                if(day==31)//若滿30后將置一
                                                day=1;
                                        write_ymd(9,day);;//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+9);//顯示位置重新回到調(diào)節(jié)處
                                if(s1num==4)//若功能鍵第四次按下
                                        week++;//則調(diào)整星期加1
                                        if(week==8)//若滿8后將置一
                                                week=1;
                                        write_week(week);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+12);//顯示位置重新回到調(diào)節(jié)處
                                if(s1num==7)//若功能鍵第七次按下
                                        miao++; //則調(diào)整秒加1
                                        if(miao==60)//若滿60后將清零
                                                miao=0;
                                        write_sfm(10,miao);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+0x40+10);//顯示位置重新回到調(diào)節(jié)處
                                if(s1num==6)//若功能鍵第二次按下
                                        fen++;//則調(diào)整分鐘加1
                                        if(fen==60)//若滿60后將清零
                                                fen=0;
                                        write_sfm(7,fen);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+0x40+7);//顯示位置重新回到調(diào)節(jié)處
                                if(s1num==5)//若功能鍵第五次按下
                                        shi++;
                                        if(shi==24)//若滿24后將清零
                                           shi=0;
                                           if(s4num==0)
                                              write_sfm(4,shi);;//每調(diào)節(jié)一次送液晶顯示一下
                                              write_com(0x80+0x40+4);//顯示位置重新回到調(diào)節(jié)處
                                           if(s4num==1)
                                                     zhuanhuan();
                                              _shi();
                                              write_sfm(4,pshi);;//每調(diào)節(jié)一次送液晶顯示一下
                if(s3==0)
                        delay(5);
                        if(s3==0)//確認(rèn)減小鍵被按下
                                while(!s3);//按鍵釋放
                                        year--;//則調(diào)整秒減1
                                        if(year==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為99
                                                year=99;
                                        month--;//則調(diào)整分鐘減1
                                        if(month==0)//若減到負(fù)數(shù)則將其重新設(shè)置為59
                                                month=12;
                                if(s1num==3)//若功能鍵第二次按下
                                        day--;//則調(diào)整日加1
                                            if(day==0)//若滿29后將置一
                                                day=29;
                                            if(day==0)//若滿28后將置一
                                                day=28;
                                            if(day==0)//若滿31后將置一
                                                day=31;
                                                if(day==0)//若滿30后將置一
                                                day=30;
                                if(s1num==4)//若功能鍵第二次按下
                                        week--;//則調(diào)整小時(shí)減1
                                        if(week==0)//若減到負(fù)數(shù)則將其重新設(shè)置為23
                                                week=7;
                                if(s1num==7)//若功能鍵第一次按下
                                        miao--;//則調(diào)整秒減1
                                        if(miao==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為59
                                                miao=59;
                                        fen--;//則調(diào)整分鐘減1
                                        if(fen==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為59
                                                fen=59;
                                if(s1num==5)//若功能鍵第二次按下
                                        shi--;
                                        if(shi==-1)//若滿24后將清零
                                           shi=23;
                                           if(s4num==0)
                                           if(s4num==1)
                              zhuanhuan();
                                              _shi();
        if(s1num==0)
          if(s4==0)
                delay(5);
                if(s4==0)//確認(rèn)功能鍵被按下
                    s4num++;//功能鍵按下次數(shù)記錄
                        while(!s4);//釋放確認(rèn)
                        if(s4num==1)//第一次被按下時(shí)
                            zhuanhuan();
                                _shi();
                                write_sfm(4,pshi);
                        if(s4num==2)//第二次按下
                                s4num=0;//記錄按鍵數(shù)清零
                                write_date(' ');
                                write_date(' ');
                                write_sfm(4,shi);
void main()//主函數(shù)
        init();//首先初始化各數(shù)據(jù)
        while(1)//進(jìn)入主程序大循環(huán)
                keyscan();//不停的檢測(cè)按鍵是否被按下
                if(s1num!=0)
                   led=0;
                   led=miao%2;
                if((shi>7&&shi<23)&&(fen==0)&&(miao==0))
                 di();
void timer0() interrupt 1//定時(shí)器0中斷服務(wù)程序
        TH0=(65536-50000)/256;//再次裝定時(shí)器初值
        count++;                //中斷次數(shù)累加
        if(count==20) //20次50毫秒為1秒
                count=0;
                miao++;
                if(miao==60)//秒加到60則進(jìn)位分鐘
                        miao=0;//同時(shí)秒數(shù)清零
                        fen++;
                        if(fen==60)//分鐘加到60則進(jìn)位小時(shí)
                                fen=0;//同時(shí)分鐘數(shù)清零
                                shi++;
                                if(shi==24)//小時(shí)加到24則小時(shí)清零
                                        shi=0;
                                        week++;
                                           if(week==8)
                                               week=1;
                                           write_week(week);//星期若變化則重新寫入
                                        day++;
                                           if(year%4==0&&month==2)//判斷是否為閏年的2月
                                              if(day==30)
                                                     writeym();
                                                  write_ymd(9,day);//日若變化則重新寫入
                                           if(year%4!=0&&month==2)//判斷是否為平年的2月
                                              if(day==29)
                                                     writeym();
                                              if(day==32)
                                                     writeym();
                                              if(day==31)
                                                     writeym();
                                if(s4num==1)
                                     zhuanhuan();
                                         _shi();
                                     write_sfm(4,pshi);//12小時(shí)制小時(shí)若變化則重新寫入
                                else write_sfm(4,shi);//24小時(shí)制小時(shí)若變化則重新寫入
                        write_sfm(7,fen);//分鐘若變化則重新寫入
                write_sfm(10,miao);//秒若變化則重新寫入
相關(guān)帖子
ID:7485 發(fā)表于 2017-4-26 21:36 | 顯示全部樓層
這是全部的程序?
許多東西都沒(méi)定義,當(dāng)然編譯通不過(guò)。
ID:193618 發(fā)表于 2017-4-27 11:00 | 顯示全部樓層
ahshmj 發(fā)表于 2017-4-26 21:36
這是全部的程序?
我不怎么會(huì) 但還是謝謝
