查看: 4138|回復(fù): 2
基于stm32的光立方灰度顯示程序
基于stm32的光立方灰度顯示程序
  1. #include "stm32f10x.h"
  2. #include "pwm.h"
  3. #include "spi.h"
  4. #define TOTALPeriod 1000
  5. #define LIGTHNESS_0  TOTALPeriod-(TOTALPeriod/100)
  6. #define LIGTHNESS_1  TOTALPeriod-(TOTALPeriod/100*5)
  7. #define LIGTHNESS_2  TOTALPeriod-(TOTALPeriod/100*20)
  8. #define LIGTHNESS_3  TOTALPeriod-(TOTALPeriod/100*40)
  9. #define LIGTHNESS_4  TOTALPeriod-(TOTALPeriod/100*90)
  10. u8 layer_cnt,light_cnt;
  11. char  frame_data[5][64]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00};
  12. unsigned int all_cnt;
  13. void TIM1_PWM_Init()
  14. {
  15.          GPIO_InitTypeDef GPIO_InitStructure;
  16.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  17.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  18.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
  19.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);  //使能GPIO外設(shè)時(shí)鐘使能
  20.
  21.    //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
  22.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM_CH1
  23.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復(fù)用推挽輸出
  24.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  25.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  26.         TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  27.         TIM_TimeBaseStructure.TIM_Period = TOTALPeriod; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值         80K
  28.         TIM_TimeBaseStructure.TIM_Prescaler =11; //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  12M
  29.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
  30.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  31.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  32.         TIM_OCStructInit(&TIM_OCInitStructure);
  33.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式1
  34.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  35.         TIM_OCInitStructure.TIM_Pulse = LIGTHNESS_0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  36.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
  37.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設(shè)TIMx
  38.         TIM_SelectOnePulseMode(TIM1, TIM_OPMode_Single);
  39.     TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主輸出使能
  40.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1預(yù)裝載使能
  41.
  42.         TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
  43.
  44.
  45. }
  46. void TIM2_Init()
  47. {
  48.
  49.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  50.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  51.         NVIC_InitTypeDef  NVIC_InitStructure;
  52.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//
  53.         TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  54.         TIM_TimeBaseStructure.TIM_Period = 250; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值
  55.         TIM_TimeBaseStructure.TIM_Prescaler =71; //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  1M
  56.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
  57.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  58.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  59.
  60.         TIM_ARRPreloadConfig(TIM2, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
  61.         TIM_ITConfig(TIM2, TIM_IT_Update,ENABLE);
  62.         /* Enable the USART1 Interrupt */
  63.         NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  64.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  65.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  66.         NVIC_Init(&NVIC_InitStructure);
  67.
  68.         TIM_Cmd(TIM2, ENABLE);  //使能TIM2
  69. }
  70. void delay(int cnt)
  71. {
  72.         while(cnt!=0) cnt--;
  73. }
  74.
  75. void display_layer( char ly,char* pdata)
  76. {        u8 i;
  77.
  78.
  79.
  80.         SPI2_ReadWriteByte(0x01<<ly);
  81.         for( i=0;i<8;i++)
  82.         {
  83.                 SPI2_ReadWriteByte(*(pdata+i));
  84.         }
  85.         GPIO_ResetBits(GPIOB,GPIO_Pin_11);
  86.         delay(100);
  87.         GPIO_SetBits(GPIOB,GPIO_Pin_11);
  88.
  89. }
  90. void set_lightness(u8 lg)
  91. {
  92.         switch(lg)
  93.         {
  94.                 case 0:
  95.                         TIM_SetCompare1(TIM1,LIGTHNESS_0);
  96.                   break;
  97.                 case 1:
  98.                         TIM_SetCompare1(TIM1,LIGTHNESS_1);
  99.                   break;
  100.                 case 2:
  101.                         TIM_SetCompare1(TIM1,LIGTHNESS_2);
  102.                   break;
  103.                 case 3:
  104.                         TIM_SetCompare1(TIM1,LIGTHNESS_3);
  105.                   break;
  106.                 case 4:
  107.                         TIM_SetCompare1(TIM1,LIGTHNESS_4);
  108.                   break;
  109.                 default:
  110.                         break;
  111.         }
  112.
  113. }
  114. void tim2_handler()
  115. {
  116.         if(layer_cnt>=8)
  117.         {
  118.                 layer_cnt=0;
  119.                 light_cnt++;
  120.                 if(light_cnt>=5)
  121.                         light_cnt=0;
  122.         }
  123.
  124.         display_layer(layer_cnt,frame_data[light_cnt]+layer_cnt*8);
  125.         set_lightness(light_cnt);
  126.         TIM_Cmd(TIM1, ENABLE);
  127.         layer_cnt++;
  128. }
  129. void TIM2_IRQHandler(void)
  130. {
  131.   if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
  132.   {
  133.           TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  134.                 tim2_handler();
  135.     all_cnt++;
  136.   }
  137. }
5_灰度顯示.rar
365.09 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
ID:243748 發(fā)表于 2018-2-25 21:44 來(lái)自觸屏版 | 只看該作者
有電路圖嗎?
