這是一個讀取SD卡信息的程序
SD程序.rar
(2.53 MB, 下載次數(shù): 223)
2017-8-6 18:59 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
stm32單片機源程序如下:
- * @file USART/Printf/main.c
- * @author MCD Application Team
- * @version V3.3.0
- * @date 04/16/10
- * @brief Main program body
- * @copy
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2010 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "delay.h"
- #include <stdio.h>
- #include <stdlib.h>
- #include "sd.h"
- #include "usart.h"
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- USART_InitTypeDef USART_InitStructure;
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Private function prototypes -----------------------------------------------*/
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- * @param None
- * @retval None
- u8 SD_Buffer[512];//SD卡數(shù)據(jù)緩存區(qū)
- int main(void)
- u8 tmp;
- u16 mm,nn;
- u32 nummber,nummber_bak;
- //設(shè)置優(yōu)先級分組:搶占優(yōu)先級和響應(yīng)優(yōu)先級各2位
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- //設(shè)置向量表的位置和偏移:在FLASH中偏移為0
- NVIC_SetVectorTable(NVIC_VectTab_FLASH,0);
- //USART1初始化
- USART1_Init();
- //檢測當(dāng)前系統(tǒng)時鐘SystemCoreClock
- SystemCoreClockUpdate ();
- //檢測SD卡,失敗則2秒后繼續(xù)檢測
- while(SD_Init()!=0)
- printf("\r\n未檢測到SD卡!");
- delay_ms(SystemCoreClock,1000);
- printf("\r\n初始化SD卡成功!\r\n");
- //邏輯0扇區(qū)的物理扇區(qū)號
- nummber_bak=SD_GetLogic0();
- while(1)
- RxCounter1=0;
- printf("\r\n請發(fā)送要讀取的邏輯扇區(qū)號\r\n");
- do
- { //等待接收停止100mS
- tmp = RxCounter1;
- delay_ms(SystemCoreClock,100);
- }while(RxCounter1==0 || tmp!=RxCounter1);
- //將接收到的字符串轉(zhuǎn)換成數(shù)值
- RxBuffer1[RxCounter1]='\0';
- nummber=atol((const char *)RxBuffer1);
- if(SD_ReadBlock(SD_Buffer,nummber_bak+nummber,512)==0)//讀指定扇區(qū)
- printf("\r\n第%d邏輯扇區(qū)數(shù)據(jù):",nummber);
- for(mm=0;mm<32;mm++)
- printf("\r\n%03xH ",mm<<4);
- for(nn=0;nn<16;nn++)
- printf("%02x ",SD_Buffer[(mm<<3)+nn]);
- printf("\r\n");
- // while (1)
- // delay_ms(SystemCoreClock,1000);
- // printf("\r\n串口1測試程序");
- * @brief Retargets the C library printf function to the USART.
- * @param None
- * @retval None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_SendData(USART1, (uint8_t) ch); /*發(fā)送一個字符函數(shù)*/
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)/*等待發(fā)送完成*/
- return ch;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
