當(dāng)前位置:單片機教程網(wǎng) >> STM32 >> 瀏覽文章
MPU6050(初步調(diào)試代碼:度數(shù)相差1-2度)
作者:祥瑞曉曉   來源:不詳   點擊數(shù):  更新時間:2014年08月03日   【字體:
#define  YCC_GYRO_GLOBALS
#include "stm32f10x.h"
#include "main.h"
#include <stdio.h>
#include <math.h>
#include <string.h>
//定義MPU6050內(nèi)部地址********************
#define SMPLRT_DV    0x19 //采樣率分頻,典型值:0x07(125Hz)
#defineCONFIG0x1A //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG0x1B //陀螺儀自檢及測量范圍及高通濾波頻率,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define AX_H0x3B //儲存最近的X,Y,Z軸加速度計測量值
#defineAX_L0x3C
#defineAY_H0x3D
#defineAY_L0x3E
#defineAZ_H0x3F
#defineAZ_L0x40
#defineTEMP_H0x41 //儲存最近溫度傳感器的測量值
#define TEMP_L0x42
#define GX_H0x43 //儲存最近的X,Y,Z軸陀螺儀感應(yīng)器的測量值
#define GX_L0x44
#define GY_H0x45
#define GY_L0x46
#define GZ_H0x47
#define GZ_L0x48
#define PWR_M0x6B //電源管理,典型值:0x00(正常啟動)
#define FIFO_COUNT_H0x72 //必須按從高到低的順序讀取
#define FIFO_COUNT_L0x73
#define WHO_AM_I0x75 //IIC地址寄存器(默認(rèn)數(shù)值:0x68,只讀)
#defineMPU6050_Addr    0xD0  //定義器件在IIC總線中的從地址,根據(jù)ALT  ADDRESS地址引腳不同修改
//******角度參數(shù)************
static float Angle_x,Angle_y,Angle_z;  //小車最終傾斜角度
static float Accel_x,Accel_y,Accel_z;  //小車加速度計算角度
//加速度軸和陀螺儀軸的零點漂移,取4000個數(shù)據(jù)的平均值
#define Ax_offset 0x03D2
#define Ay_offset0xFED4
#define Az_offset0x5956
#define Gx_offset0x0011
#define Gy_offset0xFFE3
#define Gz_offset0xFFF5
#define PI3.14
#define gyro_time0.01  //s
//******卡爾曼參數(shù)************
float Q_angle=0.001;
float Q_gyro=0.003;
float R_angle=0.5;
float dt=0.01;                          //dt為kalman濾波器采樣時間;
float C_0 = 1.0;
float Q_bias, Angle_err;
float PCt_0, PCt_1, E;
float K_0, K_1, t_0, t_1;
float Pdot[4] ={0,0,0,0};
float PP[2][2] = { { 1, 0 },{ 0, 1 } };
typedef struct
float ax;
float ay;
float az;
float gx;
float gy;
float gz;
float temp;
}GYRO_INFO;
static GYRO_INFO gyro_info;
static void Single_Write(u8 register_add,u8 date)
I2C_Bus(I2C_DEV_MPU3050,I2CMD_IOTODEV,register_add,&date,1);
static s16 Single_Read(u8 register_add)
u16 temp;
u8 date[2];
I2C_Bus(I2C_DEV_MPU3050,I2CMD_DEVTOIO,register_add,date,2);
temp= (date[0]<<8)|date[1];
return (s16)temp;
void Gyro_Init()
   Single_Write(PWR_M, 0x00);   //重置所有寄存器,溫度傳感器失能
   Single_Write(SMPLRT_DV,0x07);//陀螺儀&加速度計采樣率,典型值:0x07(125Hz)
   Single_Write(CONFIG,0x06);   //低通濾波頻率,典型值:0x06(5Hz)
   Single_Write(GYRO_CONFIG,0x08);//(+-500deg/s
//   Single_Write(GYRO_CONFIG,0x18);//陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
   Single_Write(ACCEL_CONFIG,0x01);//加速度計(不自檢,2g)
//******讀取MPU3050數(shù)據(jù)****************************************
static u8 READ_MPU3050()
u8 power=0x40,ok;
s16 temp[3];
I2C_Bus(I2C_DEV_MPU3050,I2CMD_DEVTOIO,PWR_M,&power,1);
   if(power != 0x40)
      temp[0] = Single_Read(AX_H);
  temp[1] = Single_Read(AY_H);
  temp[2] = Single_Read(AZ_H);
       gyro_info.ax=(s16)(temp[0])/16384.00; //范圍為2g時,換算關(guān)系:16384 LSB/g
  gyro_info.ay=(s16)(temp[1])/16384.00; //角度較小時,x=sinx得到角度(弧度), deg = rad*180/3.14
  gyro_info.az=(s16)(temp[2])/16384.00; //因為x>=sinx,故乘以1.3適當(dāng)放大
  gyro_info.gx=(s16)(Single_Read(GX_H)-Gx_offset)/65.5;///16.4;
  gyro_info.gy=(s16)(Single_Read(GY_H)-Gy_offset)/65.5;///16.4;
  gyro_info.gz=(s16)(Single_Read(GZ_H)-Gz_offset)/65.5;///16.4;
/*   Accel_x = atan(gyro_info.ay/gyro_info.az)*180/PI;
  Accel_y = atan(gyro_info.ax/gyro_info.az)*180/PI;*/
  Accel_x =asin((s16)(temp[0]-Ax_offset)/16384.00)*180/PI;
  Accel_y =asin((s16)(temp[1]-Ay_offset)/16384.00)*180/PI;
  Accel_z =asin((s16)(temp[2]-Az_offset)/16384.00)*180/PI;
  ok=1;
   Gyro_Init();
ok=0;
   return ok;
/*************傾角計算(卡爾曼濾波融合)********************/
//Kalman濾波,20MHz的處理時間約0.77ms;
void Kalman_Filter(float Accel,float* Gyro,float* outAngle)//,float*outAngleDot)
//static float Angle,AngleDot;
*outAngle+=(*Gyro - Q_bias) * dt; //先驗估計
Pdot[0]=Q_angle - PP[0][1] - PP[1][0]; // Pk-先驗估計誤差協(xié)方差的微分
Pdot[1]=- PP[1][1];
Pdot[2]=- PP[1][1];
Pdot[3]=Q_gyro;
PP[0][0] += Pdot[0] * dt;   // Pk-先驗估計誤差協(xié)方差微分的積分
PP[0][1] += Pdot[1] * dt;   // =先驗估計誤差協(xié)方差
PP[1][0] += Pdot[2] * dt;
PP[1][1] += Pdot[3] * dt;
Angle_err = Accel -*outAngle;//zk-先驗估計
PCt_0 = C_0 * PP[0][0];
PCt_1 = C_0 * PP[1][0];
E = R_angle + C_0 * PCt_0;
K_0 = PCt_0 / E;
K_1 = PCt_1 / E;
t_0 = PCt_0;
t_1 = C_0 * PP[0][1];
PP[0][0] -= K_0 * t_0; //后驗估計誤差協(xié)方差
PP[0][1] -= K_0 * t_1;
PP[1][0] -= K_1 * t_0;
PP[1][1] -= K_1 * t_1;
*outAngle+= K_0 * Angle_err; //后驗估計
Q_bias+= K_1 * Angle_err; //后驗估計
*Gyro = *Gyro - Q_bias; //輸出值(后驗估計)的微分=角速度
//*outAngle=*outAngle;
//*outAngleDot=AngleDot;
/******************互補濾波**********************************
*補償原理是取當(dāng)前傾角和加速度獲得傾角差值進行放大,然后與
* 陀螺儀角速度疊加后再積分,從而使傾角最跟蹤為加速度獲得的角度
* 0.5為放大倍數(shù),可調(diào)節(jié)補償度;gyro_time為系統(tǒng)周期10ms
 void Angle_Calcu(void)
READ_MPU3050();
Kalman_Filter(Accel_y,&gyro_info.gx,&Angle_x);
    Kalman_Filter(Accel_x,&gyro_info.gy,&Angle_y);
//Kalman_Filter(Angle_z,Accel_z,gyro_info.gz);
//Angle_x = Angle_x +(((Accel_y-Angle_x)*0.5 + gyro_info.gx)*gyro_time);
//Angle_y = Angle_y +(((Accel_x-Angle_y)*0.5 + gyro_info.gy)*gyro_time);
//Angle_z = Angle_z +(((Accel_x-Angle_y)*0.5 + gyro_info.gy)*gyro_time);
#ifdef DEBUG_MODE
void Gyro_Report()
float* p;
u8 i,len,temp[50];
char str1[2]={'a','g'};
char str2[3]={'x','y','z'};
float Angle[3];
p=(float*)(&gyro_info);
//p=(s16*)(&gyro_offset);
Angle[0]=Angle_x;
Angle[1]=Angle_y;
Angle[2]=Angle_z;
if(I2C_Probe(I2C_DEV_MPU3050)==1)
for(i=0;i<6;i++)
if(i<3)  len=sprintf((char*)temp,"%c%c:%.2f",str1[0],str2[i],*p++);
else     len=sprintf((char*)temp,"%c%c:%.2f",str1[1],str2[i-3],*p++);
Host_Report_Event(HOST_EVENT_DEBUG,temp,len);
for(i=0;i<3;i++)
len=sprintf((char*)temp,"Angle%c:%.2f",str2[i],Angle[i]);
#endif
void Gyro_Main()
Angle_Calcu();
