當(dāng)前位置:單片機(jī)教程網(wǎng) >> STM32 >> 瀏覽文章
STM32單片機(jī)AT45DB642D驅(qū)動程序
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年08月21日   【字體:
* 51hei版權(quán)所有,未經(jīng)允許,不得發(fā)表及作為它用!
* File Name          : AT45DB642D.c
* Author             : XiaoShm
* Version            : V1.0
* Date               : 8/29/2012
* Description
* Last Modefly Date : 8/31/2012
#include "stm32f10x.h"
#include "stm32f10x_gpio.h"
#include "InitDevice.h"
#include"at45db642d.h"
//AT45DB有兩個(gè)緩沖區(qū)Buffer1和Buffer2 (SRAM),此處只使用buffer1
*opcode-操作碼
//讀取狀態(tài)的操作碼
#define Status_Register_Opcode   0xD7
//讀取ID的操作碼
#define Device_ID_Opcode         0x9F
//Write to buffer
#define Write_Data_to_Buffer1   0x84//0x84,0x87
//Write buffer to page
#define Write_Buffer1_to_Page_whin_Erase   0x83
//Continuous Array Read
#define Continuous_Array_Read_Command   0xe8//0x03//0x0b//0xe8
#define Deep_Power_Down 0xb9
#define Resume_from_Deep_Power_Down 0xab
#define Main_MemoryPage_to_Buffer1_Transfer 0x53
#define Auto_Page_Rewrite_through_Buffer1 0x58
#define Main_Memory_Page_Pro_Through_Buff1 0x82
#define DF_FullSize 0x7fffff//8M byte
#define DF_PageSize 0x400//頁大小
#ifdef TEST_AT45DB
#define TESTBASE 0X2000
u32 TestAddr = TESTBASE;
u8 TestBuffer[256] ={0};
#endif
//函數(shù)名稱:DF_SpiRxByte(void)
//輸入:
//輸出:
//函數(shù)功能:通過SPI接從AT45DB讀一字節(jié)數(shù)據(jù)
u8 DF_SpiRxByte(void)
u8 i = 0, rdat = 0;
for(i = 0; i < 8; i ++)
rdat <<= 1;
GPIO_SetBits(GPIOC, FSCK);
if(GPIO_ReadInputDataBit(GPIOC, FSDO))
rdat |= 0x01;
GPIO_ResetBits(GPIOC, FSCK);
return rdat;
//函數(shù)名稱:DF_SpiTxByte(u8 dat)
//輸入:data待寫入的數(shù)據(jù)
//輸出:
//函數(shù)功能:通過SPI接口向AT45DB寫入一字節(jié)數(shù)據(jù)
void DF_SpiTxByte(u8 dat)
  u8 i = 0, sdat = 0;
sdat = dat;
if(sdat & 0x80)
GPIO_SetBits(GPIOC, FSDI);
GPIO_ResetBits(GPIOC, FSDI);
sdat <<= 1;
//函數(shù)名稱:Enable_DFLASH(void)
//輸入:
//輸出:
//函數(shù)功能:使能FLASH(低電平使能)
void Enable_DFLASH(void)
    u8 i = 5;
  GPIO_ResetBits(GPIOC, FCS);
  while(i --);
//函數(shù)名稱:Disable_DFLASH(void)
//輸入:
//輸出:
//函數(shù)功能:禁止FLASH(高電平禁止)
void Disable_DFLASH(void)
  u8 i = 5;
  GPIO_SetBits(GPIOC, FCS);
  while(i --); //延長上一次高電平時(shí)間
//*Status Register Format:                                   *
//* bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 *
//* RDY/BUSY COMP   0     1     1     1     X     X   *
//* bit7 - 忙標(biāo)記,0為忙1為不忙。                               *
//*       當(dāng)Status Register的位0移出之后,接下來的時(shí)鐘脈沖序列將使SPI器件繼續(xù)*
//*       將最新的狀態(tài)字節(jié)送出。                               */
//* bit6 - 標(biāo)記最近一次Main Memory Page和Buffer的比較結(jié)果,0相同,1不同。   *
//* bit5                                               *
//* bit4                                               *
//* bit3                                               *
//* bit2 - 這4位用來標(biāo)記器件密度,對于AT45DB041B,這4位應(yīng)該是0111,一共能標(biāo)記
//*       16種不同密度的器件。
//* bit1
//* bit0 - 這2位暫時(shí)無效
u8 DF_ReadStatus(void)
    u8 i = 0;
    Enable_DFLASH();
    DF_SpiTxByte(Status_Register_Opcode);
i = DF_SpiRxByte();/////////////////****************//////////////////
    Disable_DFLASH();
    return i;
//函數(shù)名稱:DF_Check_Busy_State(void)
//輸入:
//輸出:
//函數(shù)功能:讀取FLASH忙標(biāo)志位(最多判斷255次,不行還是返回且返回0)
u8 DF_Check_Busy_State(void)
  u8 state = 0;
  u8 i = 255;
  while(i)
        state = DF_ReadStatus();
  if(state & 0x80) break; //讀取的最高位0時(shí)器件忙
  --i;
DelayNInstruct(100);
  return i;
//*讀取FLASH的頁大小
//*返回1表示每一頁的大小為1024 bytes,否則為1056 bytes
u8 DF_Check_Page_Size(void)
  u8 Page_Size = 0;
  Page_Size = DF_ReadStatus();
  if(Page_Size & 0x01) return 1;
  return 0;
//函數(shù)名稱:DF_Deep_Power_Down(void)
//輸入:
//輸出:
//函數(shù)功能:使FLASH進(jìn)入DeepPowerDown模式
void DF_Deep_Power_Down(void)
Enable_DFLASH();
DF_SpiTxByte(Deep_Power_Down);
Disable_DFLASH();
//函數(shù)名稱:DFLASH_Resume_from_Deep_Power_Down(void)
//輸入:
//輸出:
//函數(shù)功能:將FLASH從DeepPowerDown模式喚醒
void DF_Resume_from_Deep_Power_Down(void)
Enable_DFLASH();
DF_SpiTxByte(Resume_from_Deep_Power_Down);
Disable_DFLASH();
//*配置FLASH頁大小為1024bytes
void DF_Configer_Binary_Page_Size(void)
u8 i = 0, j = 0;
u8 Power_of_Two_Page_Size_Command[4]={0x3d,0x2a,0x80,0xa6};
while(j < 5)
if(!DF_Check_Page_Size())
{//如果頁大小為1056 bytes,則配置為1024 bytes
DF_Check_Busy_State();
  Enable_DFLASH();
  for(i=0;i<4;i++)
  DF_SpiTxByte(Power_of_Two_Page_Size_Command[i]);//
  Disable_DFLASH();
DelayNmsTime(10);
DelayNmsTime(5);
DF_Deep_Power_Down();
DelayNmsTime(5);
DF_Resume_from_Deep_Power_Down();
DelayNmsTime(1);
{//已經(jīng)為1024則不用再配置
break;
j ++;
//*使能扇區(qū)保護(hù)
void DF_Enable_Sector_Protection(void)
  u8 Enable_Sector_Protection_Command[4]={0x3D,0x2A,0x7F,0xA9}; //使能扇區(qū)保護(hù)操作碼
  u8 i;
  Enable_DFLASH();
  for(i=0;i<4;i++)
  DF_SpiTxByte(Enable_Sector_Protection_Command[i]);//寫使能扇區(qū)保護(hù)操作碼
  Disable_DFLASH();
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:禁止扇區(qū)保護(hù)
void DF_Disable_Sector_Protection(void)
  u8 Disable_Sector_Protection_Command[4]={0x3D,0x2A,0x7F,0x9A};//禁止扇區(qū)保護(hù)操作碼
  u8 i;
  Enable_DFLASH();
  for(i=0;i<4;i++)
      DF_SpiTxByte(Disable_Sector_Protection_Command[i]);//寫禁止扇區(qū)保護(hù)操作碼
  Disable_DFLASH();
//函數(shù)名稱:
//輸入:各扇區(qū)保護(hù)字0---unprotected 0xff---protected,32byte refer to 32 sector
//輸出:
//函數(shù)功能:設(shè)置扇區(qū)保護(hù)  注意:會改變BUFFER1中的內(nèi)容
void DF_Program_Sector_Protection_Register(u8 *Sector_Protection_Register)
  u8 Program_Sector_Protection_Command[4]={0x3D,0x2A,0x7F,0xFC};//設(shè)置扇區(qū)保護(hù)操作碼
  u8 i;
  Enable_DFLASH();
  for(i=0;i<4;i++)
      DF_SpiTxByte(Program_Sector_Protection_Command[i]);//寫設(shè)置扇區(qū)保護(hù)操作碼
  for(i=0;i<32;i++)
      DF_SpiTxByte(Sector_Protection_Register[i]);//寫設(shè)置扇區(qū)保護(hù)數(shù)據(jù)
  Disable_DFLASH();
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:讀取扇區(qū)保護(hù)寄存器內(nèi)容(返回32個(gè)字節(jié),對應(yīng)32個(gè)扇區(qū)的情況)
void DF_Read_Sector_Protection_Register(u8 *Sector_Protection_Register)
  u8 Read_Sector_Protection_Register_Command[4]={0x32,0,0,0};
  u8 i;
  Enable_DFLASH();
  for(i=0;i<4;i++)//write
    DF_SpiTxByte(Read_Sector_Protection_Register_Command[i]);
  for(i=0;i<32;i++)//read
    Sector_Protection_Register[i] = DF_SpiRxByte();
  Disable_DFLASH();
//*取消所有扇區(qū)保護(hù)
//*返回1表示成功取消扇區(qū)所以保護(hù)
u8 DF_Cancel_Sector_Protection(void)
  u8 Sector_Protection_Register_for_Write[32]={0,0,0,0,0,0,0,0};//寫入0為去保護(hù)
  u8 Sector_Protection_Register_for_Read[32]={1,1,1,1,1,1,1,1};//防止默認(rèn)值為0
  u16 i;
  u8 j=1;
  //使能扇區(qū)保護(hù)
  DF_Enable_Sector_Protection();
  DF_Program_Sector_Protection_Register(Sector_Protection_Register_for_Write);
  //讀取扇區(qū)保護(hù)寄存器內(nèi)容
  DF_Read_Sector_Protection_Register(Sector_Protection_Register_for_Read);
  //判斷扇區(qū)保護(hù)寄存器內(nèi)容
  for(i=0;i<8;i++)
    if(Sector_Protection_Register_for_Read[i] != 0) j++;
  //禁止扇區(qū)保護(hù)
  DF_Disable_Sector_Protection();
  return j;
//函數(shù)名稱:DF_ContinusArrayRead(UIN32 readaddr,u8 *readbuff,u16 len)
//輸入:readaddr指定數(shù)據(jù)在FLASH中的存儲地址,指定數(shù)據(jù)的首地址,指定數(shù)據(jù)的長度
//輸出:readbuf指定數(shù)據(jù)暫存區(qū)的首地址
//函數(shù)功能:從FLASH主存readaddr地址處連續(xù)讀取len字節(jié)數(shù)據(jù)
void DF_ContinusArrayRead(u32 readaddr,u8 *readbuff,u16 len)
    u16 i;
    Enable_DFLASH();
    DF_SpiTxByte(Continuous_Array_Read_Command);
    DF_SpiTxByte((u8)((readaddr >> 16) & 0xff));
    DF_SpiTxByte((u8)((readaddr >> 8) & 0xff));
    DF_SpiTxByte((u8)(readaddr & 0xff));
    for(i = 0 ; i < 4 ; i ++)
        DF_SpiTxByte(0x00);
    for(i = 0 ; i < len ; i ++)
        readbuff[i] = DF_SpiRxByte();
    Disable_DFLASH();
//函數(shù)名稱:DF_BufferWrite(u8 bufferaddr,u8 *writebuff,u16 len)
//輸入:BUFFER中的起始地址, 待存數(shù)據(jù)的頭指針,待存數(shù)據(jù)的長度1~1024
//輸出:
//函數(shù)功能:將指定數(shù)據(jù)寫入從某個(gè)地址(0~1023)開始的BUFFER1中
void DF_BufferWrite(u16 bufferaddr,u8 *writebuff,u16 len)
    u16 i;
    Enable_DFLASH();
    DF_SpiTxByte(Write_Data_to_Buffer1);
    DF_SpiTxByte(0x00);
    DF_SpiTxByte((u8)((bufferaddr >> 8) & 0x03));
    DF_SpiTxByte((u8)(bufferaddr & 0xff));
    for(i = 0 ; i < len ; i ++ )
         DF_SpiTxByte(writebuff[i]);
    Disable_DFLASH();
//函數(shù)名稱:DF_BufferToMainMemoryWithErase(u16 pageaddr,u8 buffaddr,u8 *writebuff,u16 len)
//輸出:
//函數(shù)功能:將指定數(shù)據(jù)寫入從某個(gè)地址(0~1023)開始的BUFFER1中:包含2個(gè)動作,首先將
//指定數(shù)據(jù)寫入到BUFFER 1中,其中可以指定BUFFER中的起始寫入地址,此寫入動作不影響
//BUFFER中其它地址中的數(shù)據(jù),然后再將BUFFER中的整個(gè)數(shù)據(jù)寫入到某指定頁中(帶預(yù)擦除)。
void DF_BufferToMainMemoryWithErase(u16 pageaddr,u16 buffaddr,u8 *writebuff,u16 len)
    DF_BufferWrite(buffaddr,writebuff,len);
    Enable_DFLASH();
    DF_SpiTxByte(Write_Buffer1_to_Page_whin_Erase);
    DF_SpiTxByte((u8)((pageaddr >> 8) & 0x7f));
    DF_SpiTxByte((u8)(pageaddr & 0xfc));
    DF_SpiTxByte(0x00);
DelayNmsTime(40);
    Disable_DFLASH();
//函數(shù)名稱:DF_MainMemoryPageProgramThroughBuffer(u32 writeaddr, u8 *writebuff, u16 len)
//輸入:riteaddr---待寫入地址,writebuff數(shù)據(jù)指針,len數(shù)據(jù)長度
//輸出:
//函數(shù)功能:通過BUF1寫主存,包含動作:先將1-1024字節(jié)數(shù)據(jù)寫入BUF1,然后進(jìn)行
//BUF1到主存的帶擦除編程
void DF_MainMemoryPageProgramThroughBuffer(u32 writeaddr, u8 *writebuff, u16 len)
u16 i = 0;
Enable_DFLASH();
DF_SpiTxByte(Main_Memory_Page_Pro_Through_Buff1);
    DF_SpiTxByte((u8)((writeaddr >> 16) & 0xff));
    DF_SpiTxByte((u8)((writeaddr >> 8) & 0xff));
    DF_SpiTxByte((u8)(writeaddr & 0xff));
DelayNmsTime(40);
Disable_DFLASH();
//函數(shù)名稱:DF_MainMemoryPagetoBufferTransfer(u16 pageaddr)
//輸入:pageaddr
//輸出:
//函數(shù)功能:
void DF_MainMemoryPagetoBufferTransfer(u16 pageaddr)
Enable_DFLASH();
DF_SpiTxByte(Main_MemoryPage_to_Buffer1_Transfer);
    DF_SpiTxByte(0x00);
Disable_DFLASH();
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:
void DF_AutoPageRewriteThroughBuffer(u16 pageaddr)
Enable_DFLASH();
DF_SpiTxByte(Auto_Page_Rewrite_through_Buffer1);
    DF_SpiTxByte(0x00);
Disable_DFLASH();
DelayNmsTime(18);
//函數(shù)名稱:DF_Chip_Erase(void)
//輸入:
//輸出:
//函數(shù)功能:整片擦除FLASH全部內(nèi)容
void DF_Chip_Erase(void)
  u8 Chip_Erase_Command[4] = {0xC7,0x94,0x80,0x9A};//整片擦除操作碼
  u8 i;
  Enable_DFLASH();
    DF_SpiTxByte(Chip_Erase_Command[i]);
  Disable_DFLASH();
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:讀取制造ID,確認(rèn)是否有DATAFLASH存在,存在返回1,否則返回0
u8 DF_ReadManufactureIDInformation(void)
u8 i = 0;
u8 Idbuff[4] = {0};
    Enable_DFLASH();
    DF_SpiTxByte(Device_ID_Opcode);
        Idbuff[i] = DF_SpiRxByte();
    Disable_DFLASH();
if((Idbuff[0] == 0x1f) && (Idbuff[1] == 0x28))
return 1;
return 0;
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:初始化DataFlash,檢查制造ID,配置為1024字節(jié)每page,禁止扇區(qū)保護(hù)
void DF_Init(void)
u8 i = 0;
GPIO_ResetBits(GPIOC, FSCK);//AT45DB選擇SPI方式0
i = DF_Check_Busy_State();
if(DF_ReadManufactureIDInformation())
DF_Configer_Binary_Page_Size();
i = DF_Cancel_Sector_Protection();
{//未檢測到DF,則給出提示報(bào)警信息
i = 0;
while(i < 50)
i ++;
BeepTim = 100;
//函數(shù)名稱:SaveDataToFlash(u32 *pBuffer, u32 cnt, u32 addr)
//輸入:pBuffer-數(shù)據(jù)緩沖區(qū)首址,cnt-寫入字節(jié)數(shù),WriteAddr-保存地址
//輸出:保存成功與否
//函數(shù)功能:將任意字節(jié)(小于0X800000)數(shù)據(jù)保存入FLASH任意地址
u8 SaveDataToFlash(u8 *pBuffer, u32 sizlen, u32 WriteAddr)
u32 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
u16 paddr = 0;
if(WriteAddr + sizlen >= DF_FullSize)
{//如果 超出地址
return 0;
  Addr = WriteAddr % DF_PageSize;
  count = DF_PageSize - Addr;
  NumOfPage =  sizlen / DF_PageSize;
  NumOfSingle = sizlen % DF_PageSize;
/* If WriteAddr is DF_PageSize aligned  */
  if(Addr == 0)
  {//地址為整頁起始地址
    /* If sizlen < DF_PageSize */
    if(NumOfPage == 0)
    {//不夠一頁
      paddr = (u16)((WriteAddr >> 8) & 0xfffc);//查找頁地址
DF_MainMemoryPagetoBufferTransfer(paddr);
DF_MainMemoryPageProgramThroughBuffer(WriteAddr,pBuffer,NumOfSingle);
DF_AutoPageRewriteThroughBuffer(paddr);
    /* If sizlen > DF_PageSize */
    {//超出一頁
      while(NumOfPage--)
      {//先寫整頁
DF_MainMemoryPageProgramThroughBuffer(WriteAddr,pBuffer,DF_PageSize);
        WriteAddr +=  DF_PageSize;
        pBuffer += DF_PageSize;
      }//再寫余下部分
      if(NumOfSingle!=0)
  /* If WriteAddr is not DF_PageSize aligned  */
  {//起始地址非整頁地址
    if(NumOfPage== 0)
    {//不超過一頁
if(NumOfSingle > count)
{//產(chǎn)生跨頁
DF_MainMemoryPageProgramThroughBuffer(WriteAddr,pBuffer,count);
NumOfSingle -= count;
WriteAddr += count;
pBuffer += count;
{//不產(chǎn)生跨頁
    {//超過一頁
      sizlen -= count;
if(count != 0)
        WriteAddr += count;
        pBuffer += count;
      while(NumOfPage--)
      if(NumOfSingle != 0)
return 1;
//函數(shù)名稱:GetFlashData(u32 readdr, u8 *pBuffer, u16 sizlen)
//輸入:readdr-讀取地址,pBuffer-讀取數(shù)據(jù)緩存地址,sizlen-數(shù)據(jù)字節(jié)數(shù)
//輸出:
//函數(shù)功能:從FLASH任意(0-0X7FFFFF)地址讀取任意字節(jié)(0-65535)數(shù)據(jù)
u8 GetFlashData(u32 readdr, u8 *pBuffer, u16 sizlen)
if(readdr + sizlen >= DF_FullSize)
{//如果 超出地址
return 0;
DF_ContinusArrayRead(readdr,pBuffer,sizlen);
return 1;
//函數(shù)名稱:
//輸入:
//輸出:
//函數(shù)功能:測試讀寫DATAFLASH
void Test_At45db642d(void)
#ifdef TEST_AT45DB
u16 paddr = 0;
u8 i = 0;
    if(TestAddr < TESTBASE + 0x2000)
for(i = 0; i < 32; i ++)
TestBuffer[i] = i;
paddr = (u16)((TestAddr >> 8) & 0xfffc);
DF_MainMemoryPageProgramThroughBuffer(TestAddr,TestBuffer,32);
  for(i = 0; i < 250; i ++)
TestBuffer[i] = 0;
DF_ContinusArrayRead(TestAddr-32,TestBuffer,96);
TestAddr += 32;
#endif
