專注電子技術(shù)學習與研究
當前位置:單片機教程網(wǎng) >> Arduino >> 瀏覽文章
Arduino打地鼠游戲
作者:huqin   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年04月22日   【字體:
 因為開了一個Arduino的課,所以自己做了一個利用Led和開關(guān)的小游戲,就是打地鼠游戲,只是地鼠用led燈代替了,打就用一個開關(guān)代替了,以后有時間將它做出來。這里介紹一下簡單的原理和程序設(shè)計。
因為Arduino的端口有限,我就只接了5盞燈和5個開關(guān)。
以下是代碼:
const int buttonPin1 = 2;
const int buttonPin2 = 3;
const int buttonPin3 = 4;
const int buttonPin4 = 5;
const int buttonPin5 = 6;
const int buttonPin = 7;
const int ledPin1 =  9;
const int ledPin2 =  10;
const int ledPin3 =  11;
const int ledPin4 =  12;
const int ledPin5 =  8;
int buttoni=0;
int buttoni1=0;
int buttoni2=0;
int buttoni3=0;
int buttoni4=0;
int buttoni5=0;
int switchi=0;
int ledi=0;
int uv=0;
int buttonState=0;
int bt=1;
int rdn=random(1, 6);
unsigned long time;
unsigned long time1;
unsigned long dtime1;
unsigned long dtime=1000;
void setup() {
 pinMode(ledPin1, OUTPUT);
 pinMode(ledPin2, OUTPUT);
 pinMode(ledPin3, OUTPUT);
 pinMode(ledPin4, OUTPUT);
 pinMode(ledPin5, OUTPUT);
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin3, INPUT);
  pinMode(buttonPin4, INPUT);
  pinMode(buttonPin5, INPUT);
void loop(){
   buttonState = digitalRead(buttonPin);
   if(buttonState==HIGH)
   {uv=1;
   dtime=1000;
   buttoni=0;
   bt=1;
   if(uv==1)
     int i;
     for(i=0;i<=2;i++){
     digitalWrite(ledPin1, HIGH);
      digitalWrite(ledPin2, HIGH);
      digitalWrite(ledPin3, HIGH);
       digitalWrite(ledPin4, HIGH);
        digitalWrite(ledPin5, HIGH);
        delay(1000);
       digitalWrite(ledPin1, LOW);
      digitalWrite(ledPin2, LOW);
      digitalWrite(ledPin3, LOW);
       digitalWrite(ledPin4, LOW);
        digitalWrite(ledPin5, LOW);
        delay(1000);
        if(i==2)
        uv=2;
   if(uv==2)
    if(bt==1){
      bt=0;
        switch (rdn) {
    case 1:
        break;
    case 2:
       break;
         case 3:
       break;
         case 4:
       break;
         case 5:
       break;
         time = millis();
      time1=millis();
      dtime1=time1-time;
         if(dtime1>=dtime&&bt==0){
     uv=3;
    buttoni1 = digitalRead(buttonPin1);
    buttoni2 = digitalRead(buttonPin2);
    buttoni3 = digitalRead(buttonPin3);
    buttoni4 = digitalRead(buttonPin4);
    buttoni5 = digitalRead(buttonPin5);
    if(buttoni1==HIGH)
    buttoni=1;
    if(buttoni2==HIGH)
    buttoni=2;
    if(buttoni3==HIGH)
    buttoni=3;
    if(buttoni4==HIGH)
    buttoni=4;
    if(buttoni5==HIGH)
    buttoni=5;
   if(buttoni!=0&&buttoni!=rdn)
   uv=3;
    if(buttoni==rdn)
      bt=1;
      dtime-=20;
      switch (buttoni) {
    case 1:
        break;
    case 2:
       break;
         case 3:
       break;
         case 4:
       break;
         case 5:
       break;
       rdn=random(1, 6);
       delay(dtime);
        time=millis();
        buttoni=0;
      if(uv==3)
        int i;
         for(i=0;i<=2;i++){
        delay(500);
        delay(500);
        if(i==2)
        uv=0;
開始時集體閃燈三次,每次按滅的間隔逐漸減少,開始時是1000毫秒,每按一次減少20毫秒。
